I am trying to make Bi-Directional Counter using two Ultrasonic sensor.The count will be shown on LCD Screen if count>0 then the lights and other electronics item will Turn ON otherwise if count<0 then they will be Turned OFF.Basically i'm making a classroom automation system in which if a person enters in class then the count will get increment and then the lights and fan inside the class will get Turn ON. Similarly when a person leaves from class then the count will decrease and if no one is there inside class then all lights and fan will Turn OFF.In this i am using two ultrasonic sensor which are placed next to each other facing in same direction and then it is connected to a arduino . I have made two type of a code which i have attached with this post:
In both of them i facing some problems:
1.The value of count gets increment when a person enters(Passes by both Ultrasonic sensors) but when a persons exit the room then it is not doing the decrement in the count.
2.If a person is passing after a particular delay then only increment is happening otherwise no effect.
Please help me out with this.
#include<LiquidCrystal.h>
LiquidCrystal lcd(13,12,11,10,9,8);
const int trigPin1 = 5;
const int echoPin1 = 4;
const int trigPin2 = 7;
const int echoPin2 = 6;
double duration1;
double distance1;
double duration2;
double distance2;
int people = 0,count=0;
int delaytime = 20;
double doorWidth = 20;
boolean current_state1=false,previous_state1=false;
boolean current_state2=false,previous_state2=false;
int relay=0;
lcd.begin(16,2);
lcd.print("Visitor Counter");
Serial.println("Visitor Counter");
delay(2000);
pinMode(trigPin1, OUTPUT);
pinMode(echoPin1,INPUT);
pinMode(trigPin2, OUTPUT);
pinMode(echoPin2, INPUT);
pinMode(relay, OUTPUT);
digitalWrite(relay,LOW);
lcd.clear();
lcd.print("Person In Room:");
Serial.println("Person in room:");
void DisplayPeople()
if (people > 0)
digitalWrite(relay, LOW);
else if(people <= 0)
Serial.println("People count: ");
lcd.setCursor(0,1);
delay(100);
lcd.print(people);
Serial.print("People=");
Serial.print(people);
Serial.print("\n");
delay(100);
myloop: while(1)
Serial.println("Inside while");
Serial.print("Person Inside:");
Serial.println(count);
people=count;
DisplayPeople();
digitalWrite(trigPin1, LOW);
delayMicroseconds(2);
digitalWrite(trigPin1, HIGH);
delayMicroseconds(10);
duration1 = pulseIn(echoPin1, HIGH);
//Serial.print("Duration1 of US1:");
// Serial.println(duration1);
distance1 = duration1 * 0.034 / 2;
Serial.print("Distance1 of US1:");
Serial.println(distance1);
if(distance1<=10)
Serial.println("Inside while if distance1<=10");
current_state1= true;
digitalWrite(trigPin2, LOW);
digitalWrite(trigPin2, HIGH);
duration2 = pulseIn(echoPin2, HIGH);
distance2 = duration2 * 0.034 / 2;
Serial.print("Distance1 of US2:");
Serial.println(distance2);
if(distance2<=10)
Serial.println("Inside while if distance2<=10");
current_state2=true;
if(current_state1!=previous_state1)
if(current_state1==true)
double dis2=0,dur2=0;
delay(50);
dur2 = pulseIn(echoPin2, HIGH);
dis2 = dur2 * 0.034 / 2;
Serial.print("Distance2 of US2 inside CS1:");
Serial.println(dis2);
if(dis2<=10)
Serial.println("Inside dis2<=10 count++");
count++;
goto myloop;
if(current_state2!=previous_state2)
if(current_state2==true)
double dis1=0,dur1=0;
delay(50);
dur1 = pulseIn(echoPin2, HIGH);
dis1 = dur1 * 0.034 / 2;
Serial.print("Distance1 of US1 inside CS2:");
Serial.println(dis1);
if(dis1<=10)
Serial.println("Inside if dis1<=10,count--");
count--;
if(count<0)
count=0;
goto myloop;
/lcd.print("Person in room:"+count);
Serial.print("Person in room count:");
people=count;
DisplayPeople();/
freshcode.ino (3.96 KB)
Overall_sample.ino (770 Bytes)
