Hello, I've had some luck using the I2C_anything Library to send multiple floating variables from an ESP32 Master to 2 slave arduino Nano's. In the example below, the first slave is sending AC current readings to the ESP.
Master ESP32 code;
#include <Wire.h>
#include<I2C_Anything.h>
float x1;
float x2;
double c1;
float c2;
Wire.begin();
void loop(){
transmission();
void transmission(){
Wire.requestFrom(0x08, 8);
I2C_readAnything(x1);
I2C_readAnything(c1);
Serial.println("Data received from Slave1...!");
Serial.println(x1, 2);
Serial.println(c1, 2);
Wire.requestFrom(0x09, 8);
I2C_readAnything(x2);
I2C_readAnything(c2);
Serial.println("Data received from Slave2...!");
Serial.println(x2, 2);
Serial.println(c2, 2);
delay(100);
Slave Arduino 1
#include <Wire.h>
#include "EmonLib.h" // Include Emon Library
EnergyMonitor emon1; // Create an instance
float x1;
double c1;
emon1.current(1, 111.1);
Wire.begin(0x08);
Wire.onRequest(sendEvent);
double Irms = emon1.calcIrms(1480);
x1 = 19.36;
c1 = Irms;
delay(100);
void sendEvent(int howMany)
I2C_writeAnything(x1);
I2C_writeAnything(c1);
that code was manipulated from here; [I2C] Master Code For Master Arduino Connected to 3 Slave Arduino Unos - Networking, Protocols, and Devices - Arduino Forum
However, I was wondering if there was any way to be able to send additional floating variables from the ESP32 back to the Slaves using I2C, so there is bidirectional communication? Perhaps there's another thread out there with someone achieving this that I could be linked to?
thank you!
