Hi all, I am trying to send messages back and forth using seemingly a clone of Robotdyn Mega WIFI. Arduino Mega and NodeMCU ESP8266 are on the same board. So, I tried to send data from mega to esp8266 using serial 3 port (of mega). I have followed a sample project I've found in the internet, but it doesn't work. Here are the codes:
code for Mega
int i = 0;
float load[] = {40.9, 37.9, 29.3, 39.1, 34.9, 36.5, 37.2, 34.5, 27.2, 22.2, 31.3};
String msgsent = "";
Serial3.begin(115200 );
Serial.println("start");
if (i < 11) {
msgsent = "Load: " + String(load[i]);
Serial3.println(msgsent); // debugging purpose
Serial.print("from mega ->");
Serial.println(msgsent);
delay(100);
if (Serial3.available()) {
Serial.print("<"); // debugging purpose
String msg="";
while (Serial3.available()) {
msg += char(Serial3.read());
delay(50);
Serial.println(msg);
i++;
Yes, I am aware of that. Do you have any better suggestions?
I just realize that in the sample programs I have, all of them are using one direction only. Even the solution from red_car didn't work again after change a little bit into this:
It didn't work because you violated the rules for the types of parameters that you can pass to 'write()'. Please read the documentation on Serial in the Reference section on this site.
// if any character is received
if (Serial.available() > 0)
// then read one character and write back the same character
Serial.write(Serial.read());
I wrote another code, this time I tried to find out whether full duplex communication can be made using this board. I started writing in one direction first, from ESP to Mega, and then I found out, just like you said, timing is very crucial.
this is esp8266 part
#include <ESP8266WiFi.h>
#include <ESP8266WebServer.h>
#include <ArduinoJson.h>
char* ssid = "--";
char* password = "--";
bool lsendIP = true;
bool lsendData = true;
float load[] = {40.9, 37.9, 29.3, 39.1, 34.9, 136.5, 37.2, 34.5, 27.2, 22.2, 3331.3};
int i = 0;
// connecting to wifi network!
WiFi.begin(ssid,password);
while(WiFi.status()!=WL_CONNECTED)
// prepare serial communication
// send IP Address first!
DynamicJsonDocument doc(256);
if (lsendIP) {
lsendIP = false;
doc["type"] = "501";
doc["ip-address"] = WiFi.localIP().toString();
serializeJson(doc,Serial);
Serial.flush();
delay(200);
if (lsendData) {
if (i > 10) {
lsendData = false;
// send data continuosly
doc["type"] = "503";
doc["seq"] = i;
doc["load"] = load[i];
i++;
Serial.flush();
delay(200);
I have to add delay(200) and flush() to make sure the data goes thru the serial port and then read by mega.
this is arduino mega part..
//#include <SPI.h>
int i = 0;
String msgO = "";
float xdata = [];
if (Serial3.available() > 0) {
// there is data in the buffer?
String msgI;
const char* ipdr;
delay(100);
Serial.print("getting response ->");
Serial.println(Serial3.available());
while(Serial3.available() > 0) {
msgI += Serial3.readString();
Serial.println(msgI);
// parsing JSON format
DeserializationError error = deserializeJson(doc,msgI);
int xseq;
float xdat;
if(!error) {
if (doc["type"]=="501") {
ipdr = doc["ip-address"];
Serial.print("IP Address: ");
Serial.println(ipdr);
} else if(doc["type"]=="503") {
xseq = doc["seq"];
xdat = doc["load"];
Serial.print("Seq #: ");
Serial.print(xseq);
Serial.print(", data: ");
Serial.println(xdat);
As you said, the timing-based reception is not good, but I can't find another way of doing this. Later I try to implement a 'turn-based' communication between those 2 components (to form a simple hand-shaking mechanism). Any thought?
I think you did not understand. What I am saying is, timing must not be crucial. Successful and robust serial communication is event based, not interval based. Nowhere should you have any code that cares whether a character is available or unavailable at any arbitrary time.
I do understand what you are trying to say about robust serial communication. And that's true. I am not an expert in Arduino, I am just a beginner. I just need some articles or sample codes to give me a clear direction to go. All videos I saw on youtube basically use the same technique, I just copied from them. Perhaps a link or two will certainly help a lot. Thanks in advance.
