Big doubts in Arduino Flex Sensor Project
Good afternoon,
We have a school project that involves: arduino Uno, Flex Sensor 2.2, Resistors and 3 LEDs (green, yellow and red).
The Led´s should light up according to the flexion of the sensor, however there is always an error in the programming when testing.
Our function (tested on Tinkercad) is as follows:
#LedPin green 9
#LedPin yellow 5
#LedPin red 2
void setup ()
pinMode (yellow, OUTPUT);
pinMode (green, OUTPUT);
pinMode (red, OUTPUT);
Serial.begin (9600);
void loop ()
int sensor, degrees;
sensor = analogRead (0);
degrees = map (sensor, 768, 853, 0, 90);
Serial.print ("analog input:");
Serial.print (sensor, DEC);
Serial.print ("degrees:");
Serial.println (degrees, DEC);
if (sensor <580)
digitalWrite (yellow, LOW);
digitalWrite (green, HIGH);
digitalWrite (red, LOW);
else if ((sensor> 580) && (sensor <650))
digitalWrite (green, LOW);
digitalWrite (yellow, HIGH);
digitalWrite (red, HIGH);
delay (100);
Can anyone help us?
Thank you!
Moderator edit:
</mark> <mark>[code]</mark> <mark>
</mark> <mark>[/code]</mark> <mark>
tags added.
@natachavalador, do not hijack. Thread split.
#define green 9
#define yellow 5
#define red 2
Describe the error(s) and post the messages.
Please read and follow the instructions in the "How to get the best out of the forum" post.
