Big Easy Driver + AccelStepper + Matlab Serial Connection (Mega Board)
I am trying to control 4 motors using Matlab serial connection.
I am using 4 Big Easy Drivers v1.2 (BED) with Wantai Motors 57BYGH420 .
http://www.wantmotor.com/ProductsView.asp?id=160&pid=75&sid=80
The BED are in the simplest configurations right now. Motor wires, 12V power, Ground, Step, Enable, Ground.
The Arduino code compiles and uploads to a mega board, but when I send bytes from Matlab nothing happens.
My main goal is to send 4 step values to the Arduino from Matlab in one array. Therefore the Arduino only needs to do a Serial.read() once, and then it parses the Array into individual values for each motor.
Does anyone have any ideas on what I am doing wrong or a different method of sending code from Matlab to the Big Easy Driver.
Here is the Arduino Code...
*Note: I used part of this code for a CNC machine that used MakerBot drivers/libraries and adapted it for AccelStepper/Big Easy Driver.
// Attach AccelStepper Library
#include <AccelStepper.h>
// Assign Stepper Motors motor(wiring,step, direction)
AccelStepper XMotor(1,4,5);
AccelStepper TopWheel(1,6,7);
AccelStepper BottomWheel(1,8,9);
AccelStepper ZMotor(1,10,11);
// Introduce variables
int		gLineBuffIdx	=	0;
char		gLineBuffer[80];
boolean 	gValidDataReceived	=	false;
boolean		gSendResponseWhenDone	=	false;
// Define Number of Motors in System
#define kMaxMotors      4
// Defines the length of array read into serial [0 0 0 0]
int      gMotorPosition[kMaxMotors];
// Set Up
  int    ii;
  // Initialize Machine to not run the motors.
  // Start serial connection
  delay(200);
  // Initialize Motor Speed, Max Speed. (steps/second)
  // Max Speed given: Imax=2A, L = 2.5H, V=3.6V, Steps/rev=3200steps
  //Maz Speed= .113 revs/second --> 361.6 steps/second
  XMotor.setMaxSpeed(315);
  TopWheel.setMaxSpeed(315);
  BottomWheel.setMaxSpeed(315);
  ZMotor.setMaxSpeed(315);
  XMotor.setSpeed(250);
  TopWheel.setSpeed(250);
  BottomWheel.setSpeed(250);
  ZMotor.setSpeed(250);
//  XMotor.setCurrentPosition();
  // Run Function
  Run();
void    Run(void)
  //Define Motor Positions In the array
  #define  XNextPosition        0
  #define  TopNextPosition      1
  #define  BottomNextPosition   2
  #define  ZNextPosition        3
      // Run Serial function
      CheckSerialInput();
      if (gValidDataReceived)
        if (gMotorPosition[XNextPosition] == 1)
          XMotor.moveTo(gMotorPosition[XNextPosition] );
        TopWheel.moveTo(gMotorPosition[TopNextPosition]);
        BottomWheel.moveTo(gMotorPosition[BottomNextPosition]);
        ZMotor.moveTo(gMotorPosition[ZNextPosition]);
//	[12 36 50 100]
int ParseOneLine(char *lineBuffer)
int		myStringLen;
int		tt;
char	theChar;
int		valueCounter;
char	valueString[16];
int		valueCharIdx;
//	Serial.print("ParseOneLine ");
//	Serial.print(lineBuffer);
	myStringLen		=	strlen(lineBuffer); //string length is equal to 9
	tt				=	0;
	valueCounter	=	0;
	valueCharIdx	=	0;
        // Loop stores the step number in the motor location of array
        // gMotorPosition[counter]
	while(tt <= myStringLen)
		theChar	=	lineBuffer[tt];
		if ((theChar == 0x20) || (theChar == 0x5d)) //0x20 is hex for space 0x5d=]
			valueString[valueCharIdx]	=	0;	//*	null terminate the string
			if (valueCounter < kMaxMotors)
				gMotorPosition[valueCounter]	=	atoi(valueString);	//string to an integer (this is the vector of integers we are looking for)
//				Serial.print("value = ");
//				Serial.println(gMotorPosition[valueCounter]);
				valueCounter	+=	1;
				valueCharIdx	=	0;	// reset for next variable
				gValidDataReceived	=	true;
		else if (theChar == 0x5b)	// hex for [
		else // this will be when string character is a number
			valueString[valueCharIdx]	=	theChar;
			valueCharIdx	+=	1;
		tt	+=	1;
//	for (tt=0; tt<3; tt++)
//		Serial.println(gMotorPosition[tt]);
//	Serial.println("ParseOneLine exit");
//Read from matlab
void	CheckSerialInput()
char	theChar;
	// send data only when you receive data:
	if (Serial.available() > 0)
		// read the incoming byte:
                // 0x0d, 0x0a, 0x20 are ASCII code for Carriage REturn, New Line, and Space respectively
		theChar = Serial.read();
                Serial.println(theChar);
		if ((theChar == 0x0d) || (theChar == 0x0a))	//*	is it a Carriage Return wait until you get the whole line to put in array
			//*	we have the END OF LINE (CR = 0x0d = Carriage Return)	(/n = 0x0a = newline
			gLineBuffer[gLineBuffIdx]	=	0;	//*	null terminate the line
//			Serial.println(gLineBuffer);
			ParseOneLine(gLineBuffer);
			gLineBuffIdx	=	0;				//* reset index back to 0 (start of line)
		else if (theChar >= 0x20)	//*	0x20 is the HEX value for the CHAR SPACE
			//*	its a regular character, store it in the line buffer
                        // Store output from matlab as gLineBuffer
			gLineBuffer[gLineBuffIdx]	=	theChar;
			gLineBuffIdx	+= 1;
Matlab Output:
global obj1
obj1 = instrfind('Type', 'serial', 'Port', 'COM3', 'Tag', '');
% Create the serial port object if it does not exist
% otherwise use the object that was found.
if isempty(obj1)
    obj1 = serial('COM3');
    fclose(obj1);
    obj1 = obj1(1);
end
fopen(obj1);
go_X = 500;
go_Top = 500;
go_Bottom = 500;
go_Z = 500;
fprintf(obj1, sprintf('[%f %f %f %f]',go_X, go_Top, go_Bottom, go_Z));
If you need any other infromation let me know. Any help is GREATLY appreciated.
TestMotors.m (421 Bytes)
sketch_nov07a (3).zip (1.8 KB)
Nonsense. One Serial.read() == one character. You can't possibly get 4 stepper values AND a delimiter in one character.
