Hi guys,
I have make a really nice project. I put an endless amount of time in it and it is working now. It ALMOST works. ![]()
In this video you can see a 3D printed fish feeder which is driven by an ESP32. The components are:
stepper motor NEMA 17 (turning the wheel)
1LDR (to avoid collisions by accident)
1fork light barrier (to set zero point/starting position) (not really seen in this video)
1*SG90 servo (for emptying the boxes)
So, my problem is, it seems to work fine. But after a few actions, the feeder does not move to zero position anymore and it ends up in not choosing the correct boxes anymore.
To be honest, I am a very bad coder. I put codes together from examples and often ask questions in this forum.
No the moment has come, I am lost in this bloody mess of a code.
Maybe there are some guys, who has the time and the patience to have a look at the code and give me advices what I have to change. Maybe there are things in this code which are not needed.
Here it is...
//letzte Änderung: if (executed == false && lightVal > 500) von 300 auf 500 gesetzt, da es immer schon bei 400 war. scheint aber wohl netzteil abhängig zu sein.
//letzte Änderung 15.06.22: Servo beschleunigt
#include <AccelStepper.h>
#include <Servo.h>
#include "WiFi.h"
#include <PubSubClient.h>
#include <WiFiUdp.h>
#include <NTPClient.h> // include NTPClient library
#include <time.h> // time() ctime()
// Define NTP properties
#define NTP_ADDRESS "de.pool.ntp.org" // change this to whatever pool is closest (see ntp.org)
#define MY_TZ "CET-1CEST,M3.5.0/02,M10.5.0/03" //Timezone
time_t now; // this is the epoch
tm tm; // the structure tm holds time information in a more convient way
String t = "";
#define dirPin 33
#define stepPin 32
#define motorInterfaceType 1
#define SERVO_PIN 26 // ESP32 pin GIOP26 connected to servo motor
String temp = ""; //temporär
String packet = "";
String received = "";
#define onoffpin 16 //servo on off pin
Servo servoMotor;
//WIFI
const char *ssid = "fghjfghj";
const char *password = "fghjfghj";
const char* deviceName = "esp32_feeder";
String command;
const int MS1 = 14;
const int MS2 = 13;
const int MS3 = 12;
int MOTOR_STEPS = 200;
// Create a new instance of the AccelStepper class:
AccelStepper stepper = AccelStepper(motorInterfaceType, stepPin, dirPin);
const int buttonPin = 4; // the number of the pushbutton pin
int buttonState = 0; // variable for reading the pushbutton status
#define LED1 18
#define LED2 5
#define LED3 23 //white
const int sensorPin = 35; //photoelectric pin
int LDRValue; //LDR Value
int lightInit; // initial value
int lightVal; // light reading
bool nulled = false;
bool executed = false;
bool going = false;
bool activated = true;
unsigned long previousMillisLED = 0; // will store last time LED3 was updated
unsigned long intervalLED = 45000; // interval at which to switch off LED3 (milliseconds)
const int g1 = 280;
const int g2 = 175;
const int g3 = 65;
const int g4 = -40;
const int g5 = -145;
int counteryellow = 0;
const int MotorStepyellow[5] = {g1, g2, g3, g4, g5};
const int b1 = -250;
const int b2 = -360;
const int b3 = -460;
const int b4 = -570;
const int b5 = -675;
int counterblue = 0;
const int MotorStepblue[5] = {b1, b2, b3, b4, b5};
const int s1 = -786;
const int s2 = 705;
const int s3 = 600;
const int s4 = 490;
const int s5 = 380;
int counterblack = 0;
// Variables for publish counter via mqtt
String counterblack_str;
String counterblue_str;
String counteryellow_str;
char black[5];
char blue[5];
char yellow[5];
const int MotorStepblack[5] = {s1, s2, s3, s4, s5};
char buffer[40]; // added for monitor reading
const char* mqtt_server = "192.168.178.44";
const int mqttPort = 1883;
const char* mqttUser = "dfghdghd";
const char* mqttPassword = "dfghdhg";
//mqtt ende
// WiFi connect timeout per AP. Increase when connecting takes longer.
const uint32_t connectTimeoutMs = 5000;
unsigned long previousMillis = 0; // will store last time updated
const long interval = 30000; // interval at which to run muss 15000 sein
unsigned long previousMillisLED1 = 0; // will store last time LED1 was updated
unsigned long intervalLED1 = 1000; // interval at which to blink (milliseconds)
int LED1State = LOW;
WiFiClient espClient;
PubSubClient client(espClient);
void nullposition() {
//digitalWrite(LED3, HIGH); // 04062022
stepper.enableOutputs();
LDRValue = analogRead(A0); // read analog input pin 0
lightVal = analogRead(sensorPin);
Serial.println("check fork light barrier");
Serial.println(lightVal);
stepper.setMaxSpeed(200);
if (executed == false && lightVal > 700) {
stepper.runToNewPosition(-100);
Serial.println("detection positive --> repositioning");
executed = true;
// delay(2000);
stepper.moveTo(4000);
while (lightVal < 700 && nulled != true && LDRValue > 3000) {// Full speed up to 300
stepper.run();
lightVal = analogRead(sensorPin); // read the current light levels
stepper.stop(); // Stop as fast as possible: sets new target
stepper.runToPosition();
stepper.setCurrentPosition(0); //set steppercounter to 0 aufter reaching endstop switch
if (LDRValue > 3000) {
Serial.println(LDRValue); // prints the value read
Serial.println("moved on to null position"); // prints the value read
nulled = true;
Serial.println("null position set");
Serial.println(stepper.currentPosition());
stepper.disableOutputs();
if (LDRValue < 3000) {
Serial.println("light barrier interrupted");
Serial.println("move to empty position again");
moveemptyposition();
// delay(10);
servoMotor.attach(SERVO_PIN); // attaches the servo on ESP32 pin
lightInit = analogRead(sensorPin);
Serial.println(lightInit);
pinMode(onoffpin, OUTPUT);
digitalWrite(onoffpin, LOW);
pinMode(buttonPin, INPUT); //initialize the pushbutton pin as an input
pinMode(LED1, OUTPUT);
pinMode(LED2, OUTPUT);
pinMode(LED3, OUTPUT);
digitalWrite(LED1, LOW);
digitalWrite(LED2, LOW);
stepper.setPinsInverted(false, false, true);
stepper.setEnablePin(25);
pinMode(MS1, OUTPUT);
pinMode(MS2, OUTPUT);
pinMode(MS3, OUTPUT);
digitalWrite(MS1, HIGH);
digitalWrite(MS2, HIGH);
digitalWrite(MS3, HIGH);
setup_wifi();
client.setServer(mqtt_server, mqttPort);
client.setCallback(callback);
reconnect();
configTzTime(MY_TZ, NTP_ADDRESS);
ntp();
// Set the maximum speed and acceleration:
stepper.setMaxSpeed(200); //(1000)
stepper.setAcceleration(800); //(1000)
nullposition();
void callback(char* topic, byte* payload, unsigned int length) {
String sTopic = String(topic);
Serial.print("topic empfangen: ");
Serial.println(String(topic));
if (sTopic == "aqua/feeder") {
activated = true;
temp = "";
for (int i = 0; i < length; i++) {
temp += ((char)payload[i]);
received = temp;
Serial.println(received);
moveposition();
void setup_wifi() {
WiFi.begin(ssid, password);
Serial.println("Connecting to WiFi..");
Serial.println("Connected to the WiFi network");
void reconnect() {
if (WiFi.status() != WL_CONNECTED) {
Serial.println("WiFi not connected!");
void setup_wifi();
// Loop until we're reconnected
while (!client.connected()) {
Serial.print("Attempting MQTT connection...");
char clientid[25];
snprintf(clientid, 25, "WIFI-Display-%08X", "12345"); //this adds the mac address to the client for a unique id
Serial.print("Client ID: ");
Serial.println(clientid);
if (client.connect(clientid)) {
Serial.println("connected");
client.subscribe("aqua/feeder");
Serial.print("failed, rc=");
Serial.print(client.state());
Serial.println(" try again in 5 seconds");
// Wait 1 second before retrying
void moveposition() {
if (received == "blue") {
if ( counterblue < 5 ) {
MOTOR_STEPS = MotorStepblue[counterblue++];
sprintf ( buffer, "Counter: %d \t MotoStepValues blue: %d", counterblue, MOTOR_STEPS);
Serial.println(buffer);
if (counterblue == 5) {
counterblue = 0;
else {
Serial.println("bullshit");
if (received == "yellow") {
MOTOR_STEPS = MotorStepyellow[counteryellow++];
sprintf ( buffer, "Counter: %d \t MotoStepValues yellow: %d", counteryellow, MOTOR_STEPS);
if (counteryellow == 5) {
counteryellow = 0;
if (received == "black") {
MOTOR_STEPS = MotorStepblack[counterblack++];
sprintf ( buffer, "Counter: %d \t MotoStepValues black: %d", counterblack, MOTOR_STEPS);
if (counterblack == 5) {
counterblack = 0;
if (received != "black" && received != "yellow" && received != "blue" ) {
// nulled = false;
MOTOR_STEPS = 0;
nulled = false;
executed = false;
nullposition();
executed = true;
//MOTOR_STEPS = command.toInt();
if (nulled == true) {
Serial.println("fahren");
stepper.moveTo(MOTOR_STEPS);
while (stepper.currentPosition() != MOTOR_STEPS) {
stepper.run();
//Serial.println(stepper.currentPosition());
nulled = false;
//stepper.disableOutputs();
if (received == "black" || received == "yellow" || received == "blue" ) {
empty();
else {
nulled = false;
executed = false;
nullposition();
void empty()
digitalWrite(onoffpin, HIGH);
// rotates from 110 degrees to 0 degrees
/* for (int pos = 110; pos >= 0; pos -= 1) {
servoMotor.write(pos);
delay(20); // waits 15ms to reach the position - last value 20
for (int pos = 0; pos <= 110; pos += 1) {
// in steps of 10 degree
for (int pos = 110; pos >= -50; pos -= 1) {
delay(1); // waits 15ms to reach the position - last value 20
for (int pos = -50; pos <= 110; pos += 1) {
delay(5); // waits 15ms to reach the position - last value 20
delay(3); // waits 15ms to reach the position - last value 20
//delay(5000);
void moveemptyposition() {
MOTOR_STEPS = stepper.currentPosition() - 350;
stepper.run();
// Serial.println(stepper.currentPosition());
nulled = false;
nullposition();
unsigned long currentMillisLED = millis();
if ((currentMillisLED - previousMillisLED > intervalLED)&& activated == true) {
// save the last time you blinked the LED
previousMillisLED = currentMillisLED;
digitalWrite(LED3, LOW);
activated = false;
buttonState = digitalRead(buttonPin);
if (Serial.available()) {
command = Serial.readStringUntil('\n');
command.trim();
Serial.print("you have typed: ");
Serial.println(command);
if (command.equals("99")) {
//Serial.println("go to null position");
nulled = false;
nullposition();
else if (command.equals("999")) {
empty();
else {
moveposition();
if (WiFi.status() == WL_CONNECTED) { //blink blue LED1 while wifi is connected
unsigned long currentMillisLED1 = millis();
if (currentMillisLED1 - previousMillisLED1 > intervalLED1) {
// save the last time you blinked the LED1
previousMillisLED1 = currentMillisLED1;
LED1State = !LED1State;
// if the LED1 is off turn it on and vice-versa:
if (LED1State == HIGH) {
intervalLED1 = 3000;
digitalWrite(LED1, HIGH);
intervalLED1 = 100;
if (buttonState == HIGH) {
counterblack = 0;
counterblue = 0;
counteryellow = 0;
digitalWrite(LED2, HIGH);
else {
reconnect();
if (currentMillis - previousMillis >= interval) {
Serial.print("counteryellow jetzt: ");
Serial.println(counteryellow);
Serial.print("counterblack jetzt: ");
Serial.println(counterblack);
Serial.print("counterblue jetzt: ");
Serial.println(counterblue);
Serial.println("publish werte zu smartphone");
Serial.println("check fork light barrier in loop");
ntp();
//Preparing for mqtt send
counteryellow_str = String(counteryellow); //converting ftemp (the float variable above) to a string
counteryellow_str.toCharArray(yellow, counteryellow_str.length() + 1); //packaging up the data to publish to mqtt whoa...
counterblack_str = String(counterblack); //converting Humidity (the float variable above) to a string
counterblack_str.toCharArray(black, counterblack_str.length() + 1); //packaging up the data to publish to mqtt whoa...
counterblue_str = String(counterblue); //converting Humidity (the float variable above) to a string
counterblue_str.toCharArray(blue, counterblue_str.length() + 1); //packaging up the data to publish to mqtt whoa...
client.publish("aqua/feeder/counteryellow", yellow);
client.publish("aqua/feeder/counterblack", black);
client.publish("aqua/feeder/counterblue", blue);
// client.publish("aqua/feeder/zeit", t.c_str());
client.loop();
void convert2Json()
// Temperature in Celsius
packet = "";
packet.concat(("{\"temp\": "));
// packet.concat(temperature);
packet.concat("}");
Serial.println(packet);
//client.publish("sensors/room/aqua", packet.c_str());
Serial.println("sensors/room/aqua published");
void ntp()
//Seperate the components of the time/date for using it to trigger the event of setzero()".
time(&now); // read the current time
localtime_r(&now, &tm); // update the structure tm with the current time
/* Serial.print("year:");
Serial.print(tm.tm_year + 1900); // years since 1900
Serial.print("\tmonth:");
Serial.print(tm.tm_mon + 1); // January = 0 (!)
Serial.print("\tday:");
Serial.print(tm.tm_mday); // day of month
Serial.print("\thour:");
Serial.print(tm.tm_hour); // hours since midnight 0-23
Serial.print("\tmin:");
Serial.print(tm.tm_min); // minutes after the hour 0-59
Serial.print("\tsec:");
Serial.print(tm.tm_sec); // seconds after the minute 0-61*
Serial.print("\twday");
Serial.println(tm.tm_wday); // days since Sunday 0-6
// date = String(tm.tm_mday) + "." + String(tm.tm_mon + 1) + "." + String(tm.tm_year + 1900);
// savedate = String(tm.tm_mon + 1) + String(tm.tm_year + 1900) + ".csv";
t = String(tm.tm_hour) + ":" + String(tm.tm_min) + ":" + String(tm.tm_sec);
if (tm.tm_isdst == 1) // Daylight Saving Time flag
Serial.print("\tDST");
Serial.print("\tstandard");
