I had initially purchased an Arduino with the intent to use it to control 2 or more pwm drivers for LEDs, variable fade in and out timing for sunrise and sunset application. I want to be able to utilize a menu to change the fade in/out timing, and peak output to the drivers. I have an LCD screen, three buttons and some LEDs, and I'm learning as much as I can as fast as I can. Unfortunately I am on a time schedule and after spending a week going through the forums, reading other's posts, and going all over the internet I have not been able to find any code that I can apply to my situation. The only one I have found is for the Arduino 0015... kinda old. (Just out of curiosity, can I upload the 0015 library onto my new Uno?
Feel free to reply in any form you wish; criticism, assistance, an example of a code you may have used... etc.
#include "Wire.h"
#define DS1307_ADDRESS 0x68 // This is the I2C address
const int Blue1Pin = 3;
const int Blue2Pin = 5;
const int White3Pin = 6;
const int White4Pin = 9;
const unsigned long HOUR = 60 * 60;
const unsigned long MINUTE = 60;
const int TARGET_BRIGHTNESS = (255 * 3) / 4; // Target brightness is 3/4 of full
Wire.begin();
byte bcdToDec(byte val) {
// Convert binary coded decimal to normal decimal numbers
return ( (val/16*10) + (val%16) );
///// Get time from RTC into RTCHour, RTCMinute, RTCSecond
// Set the register pointer to 0 (Second)
Wire.beginTransmission(DS1307_ADDRESS);
Wire.write((byte)0);
Wire.endTransmission();
// Read Second, Minute, and Hour
Wire.requestFrom(DS1307_ADDRESS, 3);
int RTCSecond = bcdToDec(Wire.read());
int RTCMinute = bcdToDec(Wire.read());
int RTCHour = bcdToDec(Wire.read() & 0b111111); //24 hour time
unsigned long time = RTCHour * HOUR + RTCMinute * MINUTE + RTCSecond; // Time in seconds
analogWrite(Blue1Pin, brightness(time, 7*HOUR, 17*HOUR));
analogWrite(Blue2Pin, brightness(time, 7*HOUR+30*MINUTE, 16*HOUR+30*MINUTE));
analogWrite(White3Pin, brightness(time, 8*HOUR, 15*HOUR));
analogWrite(White4Pin, brightness(time, 9*HOUR, 14*HOUR));
byte brightness(unsigned long time, unsigned long fadeUpStart, unsigned long fadeDownStart)
// Mid day, light is at maximum brightness
if (time >= fadeUpStart + 2*HOUR && time <= fadeDownStart)
return TARGET_BRIGHTNESS;
// Dawn: fade up the light
if (time >= fadeUpStart && time <= fadeUpStart + 2*HOUR) // Fading up
unsigned long seconds = time - fadeUpStart; // Number of seconds into the fade time
return TARGET_BRIGHTNESS * seconds / (HOUR*2); // Fade up based on portion of interval completed.
// Evening: Fade down the light
if (time >= fadeDownStart && time <= fadeDownStart + 2*HOUR) // Fading down
unsigned long seconds = (fadeDownStart + (HOUR*2)) - time; // Number of seconds remaining in the fade time
return TARGET_BRIGHTNESS * seconds / (HOUR*2); // Fade down based on portion of interval left.
// The remaining times are night and the lights is off
return 0; // Shouldn't get here
This is a great starting point, and I was looking for stuff just like this online. One problem I'm banging my head against right now is how to integrate a menu into this fade in and out. The menu needs to be able to alter the time of day, change the intensity of the peak day light and change the times at which the lights turn on and reach their peak. Moonlight isn't necessary. I have figured out how to program the relays. It's the menu I need help on now. Thanks johnwasser! That looks super neat and simple compared to the garbage I was writing!
I would like for the menu to be run by 3 buttons. A menu button to jump from one menu to the next e.g. (Change Time, Change Channel 1 Intensity, Change Channel Two Intensity, Change ramp up/down time for the two channels... etc) Then two buttons for increasing, decreasing values.
Anyone used a menu like this before, or know someone who has any help would be great! Thanks!
Do you have a picture or a sketch of the circuit diagram/adruino circuit scheme? I'm trying to do this for a middle school project but can't find a visual aid.
