Can give it a shot a little later.
Thanks CrossRoads, id really appreciate it.
Ok, maybe something like this
#include <SPI.h>
// code for an 36 x 24 array (12 RGB LEDs, 24 columns) as an example
// not all code parts shown, just the highlights
// set up an array for the cathode drives
byte cathodeslower[ ] = {
0x01, 0x02, 0x04, 0x08, 0x10, 0x20, 0x40, 0x80, 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0}; // walking 1 for lower 8 NPNs
byte cathodesmid[ ] = {
0,0,0,0,0,0,0,0, 0x01, 0x02, 0x04, 0x08, 0x10, 0x20, 0x40, 0x80, 0,0,0,0,0,0,0,0}; //walking for mid 8 NPNs ????????
byte cathodeshigher[ ] = {
0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0x01, 0x02, 0x04, 0x08, 0x10, 0x20, 0x40, 0x80}; // walking 1 for upper 8 NPNs
byte anodes1 [12]; // array to hold 1st 3rd of RGB info, like red?
byte anodes2 [12]; // array to hold 2nd 3rd of RGB info, like blue?
byte anodes3 [12]; // array to hold 3rd 3rd of RGB info, like green?
byte columncount;
byte oe = 12;
unsigned long updateTime = 0;
unsigned long exampleTime = 0;
byte Red = 0; // arrays go from 0 to 11
byte Green = 12;
byte Blue = 12;
void setup(){
pinMode (oe, OUTPUT);
digitalWrite (oe, HIGH);
SPI.begin;
void loop(){
// set up for blink without delay operation
if (millis() >=updateTime){
// yes, set up for next update
updateTime = updateTime +2; // update a column every 2 milliseconds, 16 columns at ~24 Hz rate
digitalWrite (oe, HIGH); // turn off display
SPI.transfer (anodes1[columncount]); // update anodes
SPI.transfer (anodes2[columncount]); // update anodes
SPI.transfer (anodes3[columncount]); // update anodes
SPI.transfer (cathodeslower[columncount]); // turn on a cathode
SPI.transfer (cathodesmid[columncount]); // turn on a cathode
SPI.transfer (cathodeshigher[columncount]); // turn on a cathode
digitalWrite (oe, LOW); //turn display back on
columncount = columncount + 1; // update for next column
if (columncount == 24){
columncount = 0;
} // reset if reach the end
} //end display refresh
// now the fun part, for you!
// read buttons, or whatever processing you plan to do for patterns, etc.,
// and update anodes1, anodes2, anode3 as needed
if (millis() >= exampleTime){
exampleTime = exampleTime + 500; // 1/2 second changes
if (Red < 12){
anodes1[Red] = 0; // turn off prior LED
Red = Red + 1; // set up for next LED
if (Red == 12){ // if at last LED, set up next color
Blue = 0;
else {
anodes1[Red] = 1; // turn on next LED
if (Blue<12){
anodes2[Blue] = 0;
Blue = Blue + 1;
if (Blue == 12){
Green = 0;
else{
anodes2[Blue] = 1;
if (Green <12){
anodes3[Green] = 0;
Green = Green + 1;
if (Green == 12){
Red = 0;
else{
anodes3[Green] = 1;
} // end void loop
Thanks, I'll give it a try tomarrow.
PHEW. ok sorry about the delay, lots of stuff to do and all that. I FINALLY got some lights on! (just spend 2 1/2 hours doing some trial and error and working my way up on code) Minus 2 leds that need replacing and what i think to be a MOSFET that might be troubled, it works perfectly! you can see in the pics the column that needs replacing, and the 2 leds that are out, one has a blue out, the other has a red. Unfortunately your code didnt work... I tried some manipulations but i really dont know what i am doing, its like trying to build the Eiffel Tower out of legos while wearing boxing gloves. But hey, who doesnt love to learn? I worked my way up to this code:
#include <SPI.h>
const int oe = 10;
byte chip1 = 0xFF;
byte chip2 = 0xFF;
byte chip3 = 0xFF;
byte chip4 = 0xFF;
byte chip5 = 0xFF;
unsigned int time = 500;
void setup(){
SPI.begin();
pinMode(oe, OUTPUT);
digitalWrite(oe, LOW);
void loop(){
SPI.transfer(0);
SPI.transfer(0);
SPI.transfer(0x80);
SPI.transfer(chip5);
SPI.transfer(chip4);
SPI.transfer(chip3);
SPI.transfer(chip2);
SPI.transfer(chip1);
delayMicroseconds(time);
SPI.transfer(0);
SPI.transfer(0);
SPI.transfer(0x40);
SPI.transfer(0);
SPI.transfer(0);
SPI.transfer(0x20);
SPI.transfer(0);
SPI.transfer(0);
SPI.transfer(0x10);
SPI.transfer(0);
SPI.transfer(0);
SPI.transfer(0x08);
SPI.transfer(0);
SPI.transfer(0);
SPI.transfer(0x04);
SPI.transfer(0);
SPI.transfer(0);
SPI.transfer(0x02);
SPI.transfer(0);
SPI.transfer(0);
SPI.transfer(0x01);
SPI.transfer(0);
SPI.transfer(0x80);
SPI.transfer(0);
SPI.transfer(0);
SPI.transfer(0x40);
SPI.transfer(0);
SPI.transfer(0);
SPI.transfer(0x20);
SPI.transfer(0);
SPI.transfer(0);
SPI.transfer(0x10);
SPI.transfer(0);
SPI.transfer(0);
SPI.transfer(0x08);
SPI.transfer(0);
SPI.transfer(0);
SPI.transfer(0x04);
SPI.transfer(0);
SPI.transfer(0);
SPI.transfer(0x02);
SPI.transfer(0);
SPI.transfer(0);
SPI.transfer(0x01);
SPI.transfer(0);
SPI.transfer(0x80);
SPI.transfer(0);
SPI.transfer(0);
SPI.transfer(0x40);
SPI.transfer(0);
SPI.transfer(0);
SPI.transfer(0x20);
SPI.transfer(0);
SPI.transfer(0);
SPI.transfer(0x10);
SPI.transfer(0);
SPI.transfer(0);
SPI.transfer(0x08);
SPI.transfer(0);
SPI.transfer(0);
SPI.transfer(0x04);
SPI.transfer(0);
SPI.transfer(0);
SPI.transfer(0x02);
SPI.transfer(0);
SPI.transfer(0);
SPI.transfer(0x01);
SPI.transfer(0);
SPI.transfer(0);
Ewwwww, isnt that gross?? Do you know a basic way to shorten it? Fortunately the SPI is working, i started
with shiftOut(), but there was a ton of flickering, i tried messing with the output enabler, but no good.
now then; what suggestions do you have for learning how to make more complicated animations? Your code seems like it would work, and i have a BASIC understanding of it. Maybe you could revise it? I'll keep trying to expand my knowledge and fix those minor hardware issues. Thank you so much for all your help so far! and thanks for directing me towards the SPI,
none of that shiftOut nonsense
great advice.
Use a loop. Use an array of what your patterns are.
Funnily enough I'm helping someone else out with SPI and shift registers:
http://arduino.cc/forum/index.php/topic,103839
I haven't tried patterns (I don't have dozens of LEDs wired up) but it would be simple enough to do, depending on the effect you are after.
Thanks Nick, the thread didnt really help but Mikes webpage on arrays was nice. Im looking for something like what CrossRoads is doing, set up something like a blinkwithoutdelay program at the beginning (or end?) of the loop that cycles the gnd MOSFETS so it really only displays one column at a time, but thanks to persistance of vision we see a whole image. I have it doing that now with 500 microsecond delays between SPI transfers, that seems to be fast enough. So if my math is correct (and i dont think it is) that would be a refresh time of about ~83 Hz? doesnt really matter, but i also want to be able to punch that in at the top of the whole thing, like right now. Anyway kinda ranting, the main thing i am having trouble with is understyanding how to set up that first main part that cycles through the columns. Thanks!
Paranemertes,
I think you have the right idea - your code is like the long hand version of the array lookups I had in a loop.
So if you had a for:next loop that went from 0 to 23,
for (x = 0; x<24; x=x+1){
and each of these was an array of 24 bytes
SPI.transfer(0); >> SPI.transfer(lower_cathode[x]);
SPI.transfer(0x10); >> SPI.transfer(middle_cathode[x]);
SPI.transfer(0); >> SPI.transfer(upper_cathode[x]);
SPI.transfer(chip5); >> SPI.transfer(chip5_anode[x]);
SPI.transfer(chip4); >> SPI.transfer(chip4_anode[x]);
SPI.transfer(chip3); >> SPI.transfer(chip3_anode[x]);
SPI.transfer(chip2); >> SPI.transfer(chip2_anode[x]);
SPI.transfer(chip1); >> SPI.transfer(chip1_anode[x]);
then every time thru the for:next loop it would cycle thru all the data in the arrays.
and during the 500uS ontime you could do whatever logic you wanted, reading buttons, updating chip5/4/3/2/1 array values, etc.
void loop(){
unsigned long startTime = micros();
while (micros() - startTime <=500){
// read buttons, update array, etc
} // end while
// 'while' finally expires, the display refresh runs the next x
} // end for:next, 0:23
} // end loop
Ok great,i think we are off to a good start, still cant get anything to light up with the shorter code though. got those bad leds fixed and the faulty mosfet out of there so the hardware is 100% now. I gave a shot at trying to turn on all the colors at once with some of your new stuff and some guessing on my part (its really like boxing gloves and legos) unfortunately it didnt do anything.
#include <SPI.h>
byte lower_cathode[ ] = {
byte middle_cathode[ ] = {
byte upper_cathode[ ] = {
//are these arrays neccesary?
byte chip5 [8]; //holds green 9-12
byte chip4 [8]; //holds green 1-8
byte chip3 [8]; //holds blue 5-12
byte chip2 [8]; //holds red 9-12 and blue 1-4
byte chip1 [8]; //holds red 1-8
byte chip5_value = 0xFF; //chip values
byte chip4_value = 0xFF;
byte chip3_value = 0xFF;
byte chip2_value = 0xFF;
byte chip1_value = 0xFF;
byte columncount;
byte oe = 10;
byte Green = 12;
byte Blue = 12;
int x = 0;
int i = 0;
void setup(){
SPI.begin();
void loop(){
for (x = 0; x < 24; x++){
SPI.transfer(chip5[x]);
SPI.transfer(chip4[x]);
SPI.transfer(chip3[x]);
SPI.transfer(chip2[x]);
SPI.transfer(chip1[x]);
while (micros() - startTime <= 500){
for(i = 0; i < 12; i++){
SPI.transfer(chip5[chip5_value]);
SPI.transfer(chip4[chip4_value]);
SPI.transfer(chip3[chip3_value]);
SPI.transfer(chip2[chip2_value]);
SPI.transfer(chip1[chip1_value]);
} // end while
} //end first for
} // end loop
this confuses me just a bit, could you possibly show me those 24 byte arrays? What im after is all leds on throughout the table, no fancy animations, no bling, just all on. thanks! really happy with how this is coming along.
So you basically have this (see schematic):
5 8-bit registers down the left side to drive to 36 anodes of the 12 RGB LEDs.
3 8-bit registers across the bottom controlling MOSFETs, one per each column of 24 LEDs.
You will basically have 8 arrays that hold the data to write to those registers.
(you could do it other ways, I find this easiest to visualize implement)
Going down the side, you have 24 byte arrays for each of the 5 anode drivers. These are your Red, Green, Blue data
So, chip5[ 0 ] to chip5[ 23 ], same for chip4, chip3, chip2, chip1
Going across, you have 24 byte arrays for each of the 3 cathode drivers.
So, left_cathode [ 0 ] to leftcathode [ 23 ], same for mid_cathode, and right_cathode (or whatever we called them).
Now to cycle thru the array, you'll count from 0 to 23 and output data from a particular array into that driver.
void loop(){
for (x =0; x<24; x=x+1){
SPI.transfer (chip5 [x] ); // send the data from chip5 array position x into the chip5 shift register
SPI.transfer (chip4 [x] ); // send the data from chip4 array position x into the chip4 shift register
SPI.transfer (chip3 [x] ); // send the data from chip3 array position x into the chip3 shift register
SPI.transfer (chip2 [x] ); // send the data from chip2 array position x into the chip2 shift register
SPI.transfer (chip1 [x] ); // send the data from chip1 array position x into the chip1 shift register
// now the anodes are set with their highs & lows, turn on the cathode driver
SPI.transfer (left_cathode [x] ); // the data in these, 1,2,4,8,10,20,40,80, is set so that only 1 at a time is driven
SPI.transfer (mid_cathode [x] );
SPI.transfer (right_cathode [x] );
delayMicroseconds (500); // let the column shine a bit
} // now you've gone thru all 24 columns
// now tweak the data on chip1[ ], chip2[ ], chip3[ ], chip4[ ] and chip5[ ] to make the display change
// its late, I can't think of a pattern, do something simple for now:
if (millis()>=previousMillis){ // time to update the displays!
previousMillis = previousMillis + 500); // change every 1/2 second
color = color+1; // define color as an int
if (color == 256){color = 0;} // reset back to 0
for (x=0; x<24; x=x+1){
chip5[x] = color; // cycle thru from 0 to 255
chip4[x] = color;
chip3[x] = color;
chip2[x] = color;
chip1[x] = color;
] // end loop
Your are correct about the shift registers, 8 8 bits, all daisy chained. first 5 control anodes, last 3 control MOSFETs and cathodes. Im still a little confused about your reasoning for the arrays. I understand where you get 24 byte from, thats understandable, but why a 24 byte array for each chip? the chips are handling specific colors on their own, this is how they are wired currently:
chip1 = r1-r8
chip2 = r9-12/b1-b4
chip3 = b5-12
chip4 = g1-g8
chip5 = g9-12/ 4 unused pins
chip6 = 1-8 mosfets
chip7 = 9-16 mosfets
chip8 = 17-24 mosfets
So why do i need a 24 byte array if they only are dealing with 8 outputs? (sorry, big learning curve for me i guess) Ill give your code a try and see if i can make something work. Also, what about this part:
If you dont mind, could you explain this a bit more to me? Thank you
okey dokey, well i just tried this:
#include <SPI.h>
byte left_cathode[ ] = {
byte mid_cathode[ ] = {
byte right_cathode[ ] = {
//set up array for anodes
byte chip5 [24]; //holds green 9-12
byte chip4 [24]; //holds green 1-8
byte chip3 [24]; //holds blue 5-12
byte chip2 [24]; //holds red 9-12 and blue 1-4
byte chip1 [24]; //holds red 1-8
int x = 0;
int previousMillis = 0;
void setup(){
SPI.begin();
void loop(){
SPI.transfer(chip5 [x] ); // send the data from chip5 array position x into the chip5 shift register
SPI.transfer(chip4 [x] ); // send the data from chip4 array position x into the chip4 shift register
SPI.transfer(chip3 [x] ); // send the data from chip3 array position x into the chip3 shift register
SPI.transfer(chip2 [x] ); // send the data from chip2 array position x into the chip2 shift register
SPI.transfer(chip1 [x] ); // send the data from chip1 array position x into the chip1 shift register
SPI.transfer(left_cathode [x] ); // the data in these, 1,2,4,8,10,20,40,80, is set so that only 1 at a time is driven
SPI.transfer(mid_cathode [x] );
SPI.transfer(right_cathode [x] );
delayMicroseconds(500); // let the column shine a bit
if (millis() >= previousMillis){ // time to update the displays!
previousMillis = (previousMillis + 500); // change every 1/2 second
int color = color + 1; // define color as an int
chip4[x] = color;
chip3[x] = color;
chip2[x] = color;
chip1[x] = color;
}// end loop
no big suprise, it didnt work. I think we are getting closer though. Check that code, i might have made a dumb mistake.
yeah.. i know what you mean, i think we are both night owls...
Let me format that for you:
#include <SPI.h>
int x = 0;
void setup(){
SPI.begin();
void loop(){
if (color == 256){
color = 0;
chip4[x] = color;
chip3[x] = color;
chip2[x] = color;
chip1[x] = color;
}// end loop
Now, how many chips do you have? 192?
Each SPI.transfer shifts out (best not leave out the F eh?) 8 bits, so you are sending out 24 * 8 * 8 bits. That's 1536 bits. Do you have 1536 LEDs?
I don't see you latching the data anywhere.
Sorry man, my knowledge of this is limited, i thought 24 was a bit high, i thought 8 for each chip. Youll have to talk to Rob about the 24 byte thing. Do you mean the output enabler as latching?
Well if there is still confusion on how the anodes are wired, try this:
chip1:
q1 = r1
q2 = r2
q3 = r3
q4 = r4
q5 = r5
q6 = r6
q7 = r7
q8 = r8
chip2:
q1 = r9
q2 = r10
q3 = r11
q4 = r12
q5 = b1
q6 = b2
q7 = b3
q8 = b4
chip3:
q1 = b5
q2 = b6
q3 = b7
q4 = b8
q5 = b9
q6 = b10
q7 = b11
q8 = b12
chip4:
q1 = g1
q2 = g2
q3 = g3
q4 = g4
q5 = g5
q6 = g6
q7 = g7
q8 = g8
chip5:
q1 = g9
q2 = g10
q3 = g11
q4 = g12
q5 = //
q6 = //
q7 = //
q8 = //
I was just thinking that maybe that part about cycling the cathodes should be at the bottom of the loop, so you set up what you want the anodes to be set at at the beginning, then go and send out that info along with the first cathode, then it goes back to the top and the anodes info changes(or doesn't, depending on the pattern) then the bottom tells it to ground cathode 2 and so on, when it gets to the end, rinse and repeat. I'll give it a shot, but who knows what will happen.
Well i kind of feel like im just talking t myself now, but i tried this and i cannot figure out why it doesn't work. It should be the short hand version of my bigger one, its just supposed to turn everything on and leave it, but it doesn't. Can anyone think of why? thanks.
// code for a 36 x 24 array (12 RGB LEDs, 24 columns)
#include <SPI.h>
byte cathode6[ ] = { //chip 6, first 3rd of display
0x80, 0x40, 0x20, 0x10, 0x08, 0x04, 0x02, 0x01, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0
byte cathode7[ ] = { //chip 7, second 3rd of display
0, 0, 0, 0, 0, 0, 0, 0, 0x80, 0x40, 0x20, 0x10, 0x08, 0x04, 0x02, 0x01, 0, 0, 0, 0, 0, 0, 0, 0
byte cathode8[ ] = { //chip 8, third 3rd of display
0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0x80, 0x40, 0x20, 0x10, 0x08, 0x04, 0x02, 0x01
int columncount = 0;
byte oe = 10;
void setup(){
SPI.begin();
void loop(){
columncount = columncount++; // update for next column
columncount = 0;
//we have to transfer out the cathodes first
SPI.transfer(cathode8[columncount]);
SPI.transfer(cathode7[columncount]);
SPI.transfer(cathode6[columncount]);
//transfer out those colors
SPI.transfer(chip5_value);
SPI.transfer(chip4_value);
SPI.transfer(chip3_value);
SPI.transfer(chip2_value);
SPI.transfer(chip1_value);
} // end void loop
Paranemertes:
I'm not clear as to what is wrong. Can you be more explicit about "it doesn't work"? Does nothing light up? The wrong things? The wrong colours?
I'm not familiar with the chips you are using, but usually you "latch" or "commit" the data you have sent to the chip.
yeah, sorry. when i say 'it doesn't work' its when nothing is lighting up. that comment was only because i felt weird posting 3 times in a row. but anyhow i did some debugging on that last bit i posted and it prints all the values i want it to be sending out. but for some reason the pins don't do anything. as for the IC just assume they are 8 bit shift registers, 8 in total, daisy chained. (they are 74hc574's with q1 wired to d2, q2 to d3 and so on, so they act just like shift registers) Do you know why that code wont work? I've gotten some long-hand stuff to work:
#include <SPI.h>
const int oe = 10;
byte chip1 = 0x00;
byte chip2 = 0x00;
byte chip3 = 0x00;
byte chip4 = 0x00;
byte chip5 = 0x00;
unsigned int time = 2000;
long randNum1;
long randNum2;
long randNum3;
long randNum4;
long randNum5;
void setup(){
SPI.begin();
randomSeed(analogRead(0));
void loop(){
randNum1 = random(0,255);
randNum2 = random(0,255);
randNum3 = random(0,255);
randNum4 = random(0,255);
randNum5 = random(0,255);
chip1 = randNum1;
chip2 = randNum2;
chip3 = randNum3;
chip4 = randNum4;
chip5 = randNum5;
SPI.transfer(0); //8
SPI.transfer(0); //7
SPI.transfer(0x80); //6
SPI.transfer(0);
SPI.transfer(0);
SPI.transfer(0x40);
SPI.transfer(0);
SPI.transfer(0);
SPI.transfer(0x20);
SPI.transfer(0);
SPI.transfer(0);
SPI.transfer(0x10);
SPI.transfer(0);
SPI.transfer(0);
SPI.transfer(0x08);
SPI.transfer(0);
SPI.transfer(0);
SPI.transfer(0x04);
SPI.transfer(0);
SPI.transfer(0);
SPI.transfer(0x02);
SPI.transfer(0);
SPI.transfer(0);
SPI.transfer(0x01);
SPI.transfer(0);
SPI.transfer(0x80);
SPI.transfer(0);
SPI.transfer(0);
SPI.transfer(0x40);
SPI.transfer(0);
SPI.transfer(0);
SPI.transfer(0x20);
SPI.transfer(0);
SPI.transfer(0);
SPI.transfer(0x10);
SPI.transfer(0);
SPI.transfer(0);
SPI.transfer(0x08);
SPI.transfer(0);
SPI.transfer(0);
SPI.transfer(0x04);
SPI.transfer(0);
SPI.transfer(0);
SPI.transfer(0x02);
SPI.transfer(0);
SPI.transfer(0);
SPI.transfer(0x01);
SPI.transfer(0);
SPI.transfer(0x80);
SPI.transfer(0);
SPI.transfer(0);
SPI.transfer(0x40);
SPI.transfer(0);
SPI.transfer(0);
SPI.transfer(0x20);
SPI.transfer(0);
SPI.transfer(0);
SPI.transfer(0x10);
SPI.transfer(0);
SPI.transfer(0);
SPI.transfer(0x08);
SPI.transfer(0);
SPI.transfer(0);
SPI.transfer(0x04);
SPI.transfer(0);
SPI.transfer(0);
SPI.transfer(0x02);
SPI.transfer(0);
SPI.transfer(0);
SPI.transfer(0x01);
SPI.transfer(0);
SPI.transfer(0);
Paranemertes,
Do you really have all 8 shift registers daisy chained?
Or do you have chain of five 74AC574 for the anodes, and a chainof three 74HC595's for the cathodes?
This will work a lot better if they are seperate.
Can you post the schematic for the control logic?
I believe what the design was intended to do is this:
Start with the cathodes all off. Shift 0's into them as part of setup.
Then in loop:
shift data into the '574s (which are wired up like shift registers).
then shift out the cathode data for column, and use the 74HC595 latch pin to make it show up at the HC595 output.
Then turn off off the cathodes.
Shift out the next set of anode data.
repeat 22 more times.
so pseudocode:
void loop(){
for (x=0 to 23) { // 24 columns, equivalent of 36 LEDs per column,anodes addressed as 5 bytes (last 4 not connected)
SPI.transfer 5 bytes of anode data // no latch needed, 574 is wired like a single stage shift register
// turn on the cathode for that column
digitalWrite (cathode latch pin Low)
SPI.transfer 3 bytes of cathode data
digitalWrite (cathode latch pin High) // rising edge latches the data into the '595 outputs
delay (500uS)
// now turn off the cathodes
SPI.transfer (3 bytes of 0)
} // next x
// manipulate the 5 anode bytes
} //end void loop
If you really have all 8 daisy chained together, may have to rethink this a little. Ideally they would be 2 seperate chains, so the anode data is not being changed while the cathode are being turned on & off.
