Biggest LCD that can be used with Lilypad?
Hi All,
Which is the biggest LCD screen that can be controlled using Lilypad.? What are options for the LCD screen?
Please help.
Regards, Samarth.
Hi All,
Also I want to show some images on LCD?
Is it possible? Because Lilypad does not have that much memory to store image(I guess).
Please help.
Regards, Samarth.
Lillypad has the same interface pins available as a standard arduino so anything that works with a typical Arduino board will also work with a Lilypad.
But in terms of "Biggest" there is no limit. If you have enough dollars you could interface the Lilypad with something as large as a FootBall stadium jumbotron using messages over a serial port.
It isn't clear what you are wanting/needing since you have not specified any parameters such as cost targets, needed pixel geometries, voltages (3v vs 5v), interfaces needed (serial, parallel etc) etc...
Here are two libraries that can be used on fairly inexpensive LCDs that are readily available: glcd: http://www.arduino.cc/playground/Code/GLCDks0108 http://code.google.com/p/glcd-arduino/
u8glib: http://code.google.com/p/u8glib/
And then there are ready made solutions such as: http://www.sparkfun.com/products/9351
--- bill
