I've made a repository @Github for those of you that can't download the code... ![]()
Have fun!! And don't forget, if you improve on the code post it back so everyone can benefit from it ![]()
Looks like this would fit the bill!
Love your work by the way. Has inspired me.
Going to modify your code to work with a flood and drain system.
Might be a stupid question but what is the thread size/type on the solenoid valves ?
I bought the ones you linked to but am having trouble sourcing the right type of connecters for plumbing into a garden hose.
Thanks in advance
mlmunro:
No stupid question ![]()
Actually I don't know. Took the part with me to a plumbing store and asked for connectors and tubing that would fit the part ![]()
I'll check later on this evening and see if I can measure it with my calliper...
Today I had the time to measure the thread of the solenoid valve. Inside of the thread is 19.54mm and outside of the thread is 20.56mm. Hopefully you have enough information with this... ![]()
Excellent. Thanks. Have found all the right bits. Now just need to find some time to put it all together. ![]()
Hi Billie, I have been following for a while and love your work.It's taken me a while but i am starting to get all the pieces but i am a little stuck on the code side and was wondering if you could help me out?? I tried searching but i cant make seance of it.
In file included from sketch_may23a.cpp:43:
C:\Users\Ashley Harwood\Desktop\arduino-1.0\libraries\EEPROMEx/EEPROMEx.h:23:20: error: EEPROM.h: No such file or directory
sketch_may23a:45: error: no matching function for call to 'ITDB02::ITDB02(int, int, int, int, int)'
C:\Users\Ashley Harwood\Desktop\arduino-1.0\libraries\ITDB02/ITDB02.h:18: note: candidates are: ITDB02::ITDB02(int, int, int, int, int, int, int, int, int, int, int, int)
C:\Users\Ashley Harwood\Desktop\arduino-1.0\libraries\ITDB02/ITDB02.h:15: note: ITDB02::ITDB02(const ITDB02&)
sketch_may23a.cpp: In function 'void graphSetup()':
sketch_may23a:157: error: no matching function for call to 'ITDB02::TouchInitial(int)'
C:\Users\Ashley Harwood\Desktop\arduino-1.0\libraries\ITDB02/ITDB02.h:30: note: candidates are: void ITDB02::TouchInitial()
sketch_may23a:158: error: 'class ITDB02' has no member named 'setPrecision'
sketch_may23a:158: error: 'PREC_HI' was not declared in this scope
sketch_may23a.cpp: In function 'void graphLoop()':
sketch_may23a:487: error: 'class ITDB02' has no member named 'dataAvailable'
Hello,
You are missing the EEPROMEx library...
Hi again, All fixed now after learning how to read the code it was easier to fix my mistakes ![]()
I am having a devil of a time finding the EEPROM library. Also I can't get the sketch to compile as it says EEPROM not declared in this scope. Using 1.05 IDE.
Andrew
Antennas:
I am having a devil of a time finding the EEPROM library. Also I can't get the sketch to compile as it says EEPROM not declared in this scope. Using 1.05 IDE.Andrew
Hi Andrew,
I haven't tested the code with the 1.05 IDE. I already mentioned that it will work with IDE version 1.0
Also the error you get would be the same one as other people here on this thread are having trouble with...Namely the EEPROMEx should also be installed. This is an extension to the EEPROM library which is already there... So please read the entire thread, because then you'll find the link to the EEPROMEx library...It's not that far away!... ![]()
I have the EEPROMex library installed. I will have to check to make sure it's in the right place or that it's named properly. Thanks.
So I found that the name of the library is EEPROMEx and as downloaded it was EEPROMex. So I changed the name in the code to the proper one but it still doesn't work. It says 'class EEPROMClass' has no member named 'readFloat'. This must be a library issue but unsure how to fix.
EDIT***
So I copied the files from github EEPROMBackupVar.h and EEPROMVar.h into the EEPROMEx folder and it worked after that. I had tried to add the EEPROM.h but I had to remove it to make it work.
So it seems to be functioning so far.
Andrew
That's very strange indeed. I have no such library installed... Probably the maker of the library upgraded the old one...
Still glad to hear that it's working now. ![]()
Hello Billie,
Really nice project
that's exactly what I'm looking for
As I just started with all the arduino and the project is not really a beginner project I'm not sure about to handle things.
Can you explain me how to measure the ph plus the more important thing is to adjust it automatically if it goes over or under the set point ?
What will I need for this ?
Greetings
Hello Tonno,
Reading the pH is fairly simple as the Phidgets 1130 outputs an analog signal which can be converted to a pH. You just do an anologRead on the pin which connects to the Phidgets and run this calculation --> 0.0178 * sensorValue - 1.889
What outputs is the current pH value at a constant temperature of 25ยฐC...
Dosing is not that easy. I work with a Setpoint and a Hysteris. The setpoint is the pH I would like to have and the hysteris is the amount the pH can deviate from this point.
Explaining how the code works is not that simple, but here goes...
I first check if the pH is above or below the setpoint. Then change a variable according to that so the program knows if it's a base or acid that needs to be added. Note: If your plants are healthy and absorbing nutrients the pH can only go up. That's because plants use the negative ions for nutrient absorption...
Let's assume the pH is above the setpoint. The program now checks if the pH is above the hysteris. If so, dosing will start (which is a small peristaltic pump) until the pH reaches the setpoint. If the setpoint is reached then dosing will stop and the variable is set to 0 again.
This repeats constantly...
I hope this helps ![]()
Great looking project, and some unusual measurements, Billie. Really appreciate you sharing so much detail and info from your project.
When it comes to plant "food", do you have different products (or chemical makeups) for different plants, or use a more generic style food?
In a closed water+nutrition loop (vs nature where it's pretty open), is it possible an element (say nitrogen) could become depleted and require an increase, or do you find this is not an issue?
Hello aarondc,
Thanks for the nice comment ![]()
To answer your first question...I make my own nutrient mix with the help of HydroBuddy. This program makes all sort of calculations and returns me a list of Macro and Micro nutrients and their weight in grams needed to make a predefined amount of nutrient mix...
If you understand Dutch, I've made a basic usage tutorial here
I have all sorts of recipes in HydroBuddie's database. So I can make a nutrient mix for almost every crop you can imagine...
You probably have some experience with hydroponics...Because of your second question ![]()
Yes, singular nutrients (macro or micro) can get depleted. To measure one single substance one would need fairly expensive probes and that's beyond my hobby budget ![]()
You could measure the EC value of a mix, but that still wouldn't tell you which substance is getting low. I do measure the EC value (with a pen for the moment, but I'm working on a improved version of my controller), but this is to know how much concentration of nutrients are in my 200L tank...
To make sure I always have the right amount of singular nutrients in my tank (read: the recipe is still as it should be...) I do a nutrient change every 14 to 30 days. The waste goes to my conifers and grapevines...They also like the readily available nutrients ![]()
Thanks again.
I know nothing of hydroponics, but I worked for a year in a lab developing a LIMS that extracted mass spectrometer data from plant, soil and water samples for determining optimum custom-made fertilizer (chelates?) for farmers and the like.
I was wondering if you could (or would) measure discrete elements - the lab worked on 3 macro (N,P,K) and 14 micro, from memory, including things like copper and cobalt, etc. It was fascinating. N,P,K ratios were critical, but the micro elements could have a major impact on yield and plant health as well. And each crop type was different.
When I looked at sensors for those sorts of things, you are right, they were off the scale in terms of costs vs what a hobbyist would spend on a discrete component. Crazy.
I had to google EC value - but of course that makes sense. Electrolytes. Nice.
Thanks for the hydrobuddy link too - that's great.
I have no garden here, nice sunny back yard but the garden space is full of bark and succulents, in a rental, so when I saw your project I immediately thought - hey, fresh veges!! I will be looking at this more closely in the coming weeks.
Hi Billie,
Thanks for the quick reply ![]()
Is the pH Meter all the time into the water to measure the pH?
I had some information which sad that letting the ph probe all the time in the liquid will cause damage?
Perhaps this is wrong I only want to confirm it.
And second question : basically I only need one ph Probe and two peristaltic Pumps to setup a pH measure and adjustment station?
I have a Arduino UNO Board with max. 5V on the Digital Output with max. 30mA
I have found those two things now: http://www.aliexpress.com/item/Free-shipping-6V-DC-DIY-Dosing-pump-Peristaltic-dosing-Head-For-Aquarium-Lab-Analytical-water/1003369174.html
http://www.aliexpress.com/item/PH-Electrode-Probe-BNC-Connector-for-Aquarium-PH-Controller-Meter-Sensor-NI5L/938643629.html
Do I can connect them directly to the board or do I need a extra power supply ?
And as I have rad you divided the code so I can just take the part that fits?
And last but not least
: Why do you use a DC 9V plug for your arduino ? I thought 5V is max
Greetings
BillieBricks:
Hello Tonno,Reading the pH is fairly simple as the Phidgets 1130 outputs an analog signal which can be converted to a pH. You just do an anologRead on the pin which connects to the Phidgets and run this calculation --> 0.0178 * sensorValue - 1.889
What outputs is the current pH value at a constant temperature of 25ยฐC...Dosing is not that easy. I work with a Setpoint and a Hysteris. The setpoint is the pH I would like to have and the hysteris is the amount the pH can deviate from this point.
This repeats constantly...I hope this helps
