Binary and laeding zero's
this question is bound to have been asked before but I could not find it in the search...
Is there a way to print the leading zero's of a byte?
If I try :
byte v=17; Serial.println(v,BIN);
it prints : 10001
I would like it to print : 00010001
byte aByte = 0b00010001;
  printByte(aByte);
  printByte(00000001);
void printByte(byte theByte)
  for (int bit = 7; bit >= 0; bit--)
    Serial.print(bitRead(theByte, bit));
Thanks,
I already feared a loop would be the only solution...
Kevin77:
Thanks,
I already feared a loop would be the only solution…
a template would allow you to print any size object:
template <class T> T printByte (T arg)
  size_t size = sizeof(arg) * 8;
  Serial.print(F("0b"));
  for (size_t i = 0; i < size; i++)
    T mask = (T)1 << (size - i - 1);
    Serial.print(arg & mask? "1" : "0");
  uint32_t my32 = 0xFF00FF00;
  uint16_t my16 = 0x01AA;
  uint8_t my8 = 0xF0;
  printByte(my32);
  printByte(my16);
  printByte(my8);
A nice challenge to do it without a loop, note this is not fast or so.
Could be made faster with help of seven if statements (but that is in fact an unrolled loop)
void printBin(uint8_t n)
  char zeroos[] = "00000000";
  if (n == 0)
    Serial.print(zeroos);
    return;
  int leadingZeros = floor(log(n)/log(2)) + 1;  //  length of a binary number > 0
  Serial.print(&zeroos[leadingZeros]);
  Serial.print(n, BIN);
  Serial.println(__FILE__);
  for (int i=0; i<256; i++)
    printBin(i);
  Serial.println("done...");
void loop() {}
// END OF FILE
There's no point avoiding the loop. If your code doesn't have a loop, then the print function has to loop through the characters.
