binary clock +temperature 7segment + rtc
hi comunity!
i would like some help with one project i'm trying to built....
So ... i have a 7segment thermometer with 2 shift registers with an rgb led no show me some events from my pc (one old project of mine)
and a 8*8 matrix led with max7219 +rtc binary clock ,built a week ago....
So im trying to merge those two, to reclaim back one of my arduinos...
the code im using for the thermometer is this
#include <OneWire.h>
#include <DallasTemperature.h>
// pin setups
int latchPin = 9;
int clockPin = 10;
int dataPin = 8;
int tempPin = 7;
int ledg = 5;
int ledb = 4;
int ledr = 3;
// librraries for connecting to sensor
OneWire oneWire(tempPin);
DallasTemperature tempSens(&oneWire);
boolean blink = false; // holds our current state
int state;
int INTERVAL = 100; // led blink rate in milliseconds
int de = 100;
// characters for displaying on 7-seg display 0-9
byte numberSet[12] = {
 B01111101,B01000100,B01111010,B01101110,B01000111,B00101111,
 B00111111,B01100100,B01111111,B01101111 ,B00000010, B00000000
  // init serial
//  Serial.begin(9600);
  // init temp sensor
  tempSens.begin();
  // set pin modes for shift registors
  pinMode(latchPin, OUTPUT);
  pinMode(clockPin, OUTPUT);
  pinMode(dataPin, OUTPUT);
  pinMode(ledg, OUTPUT);
  pinMode(ledb, OUTPUT);
  pinMode(ledr, OUTPUT);
  tempSens.requestTemperatures();
  float t = tempSens.getTempCByIndex(0);
//  Serial.println(t);
  if (t>=10){
  // cast to float (only have 2 digits to use on display)
  int rT = (int)t;
  // get units of temp
  int units = rT % 10;
  // get tens value of temp
  rT = rT/10;
  int tens = rT % 10;
  displayNumb(units, tens);
  delay(100);
  else if (t>=0 && t<10){
    int rT = (int)t;
  int tens = 11;
  delay(100);
  else if (t<0){
    double d = t;
    d = -d;
    int rT = (int)d;
  int tens = 10;
  delay(100);
   if(Serial.available() > 0)
    blink = Serial.read();// 48 is 0 is ASCII
//  if(digitalRead(bPin) == LOW) // button pressed
//    blink = false;
 // msg
  if(blink == 50) {
    state = 1;
   digitalWrite(ledr, HIGH);   // turn the LED on (HIGH is the voltage level)
  delay(de);               // wait for a second
  digitalWrite(ledr, LOW);    // turn the LED off by making the voltage LOW
 digitalWrite(ledg, HIGH);   // turn the LED on (HIGH is the voltage level)
  digitalWrite(ledg, LOW);    // turn the LED off by making the voltage LOW
 digitalWrite(ledb, HIGH);   // turn the LED on (HIGH is the voltage level)
  digitalWrite(ledb, LOW);    // turn the LED off by making the voltage LOW
  else   //on
    if(blink == 49) {
      state = 2;
   else   //off
      if(blink == 48) {
       state = 3;
 else //network error
   if(blink == 51) {
    state = 1;
  delay(50);               // wait for a second
void displayNumb(int a, int b) {
  // get the code for the numbers
  byte bitsB = numberSet[a];
  byte bitsA = numberSet[b];
  // set ready to shift out
  digitalWrite(latchPin, LOW);
  // shift units
  shiftOut(dataPin, clockPin, bitsA);
  // shift tens
  shiftOut(dataPin, clockPin, bitsB);
  // shift out data
  digitalWrite(latchPin, HIGH);
// shift the data out to the shift registors
void shiftOut(int myDataPin, int myClockPin, byte myDataOut) {
  int i=0;
  int pinState;
  digitalWrite(myDataPin, 0);
  digitalWrite(myClockPin, 0);
  // iterate over each bit in the myDataOut byte
  for (i=7; i>=0; i--)  {
    if ( myDataOut & (1<<i) ) {
      pinState= 1;
    else {
      pinState= 0;
    digitalWrite(myDataPin, pinState);
    digitalWrite(myClockPin, 1);
and the code for the rtc binary clock is this
  Wiring for the MAX72xx LED matrix:
    Pin D12 is connected to the DIN (DataIn)
    Pin D11 is connected to CS (LOAD)
    Pin D13 is connected to the CLK
  DS3231RTC (I2C bus)
    Nano A4 to sca, A5 to scl.
#include <DS1307RTC.h>
#include <Time.h>
#include <Wire.h>
#include "LedControl.h"
//Pin definition constants
const int mDataIn=12, mLoad=11, mClk=13;  //Max7219 LED matrix
int h1, h2, m1, m2, s1, s2, d1, d2, mo1, mo2; // Each digit
int tChange; //Scratch used during change time via pushbutton
// Matrix library instance
LedControl lc=LedControl(mDataIn, mClk, mLoad,1); //Pin assignments and number of matrices (1)
  // Initialize pushbutton pins as input:
  // Remove comments to set the system time to a hard-coded date and time,
  // then set the RTC from the system time.
  //        Hr Min Sec  dd mm  yyyy
  // setTime(19, 43, 30, 8, 12, 2014);
  // RTC.set(now());  //set the RTC from the system time
  // Notify Arduimo that the RTC is the external time provider
  setSyncProvider(RTC.get);
  //Initialize the MAX72XX in power-saving mode.
  lc.shutdown(0,false);
  lc.setIntensity(0,1); // Set brightness to a low value
  lc.clearDisplay(0); // Clear the display
  delay(100); // Wait after initializing display
  //Isolate hours, minutes, seconds, one digit to each LED matrix column.
  h1=n1(hour());
  h2=n2(hour());
  m1=n1(minute());
  m2=n2(minute());
  s1=n1(second());
  s2=n2(second());
  d1=n1(day());
  d2=n2(day());
  mo1=n1(month());
  mo2=n2(month());
  // Cast as (change integer to) byte, write to LED row.
  // (Row runs from pin to pin on model used.)
  lc.setRow(0,0,byte(h1));
  lc.setRow(0,1,byte(h2));
  lc.setRow(0,3,byte(m1));
  lc.setRow(0,4,byte(m2));
  lc.setRow(0,6,byte(s1));
  lc.setRow(0,7,byte(s2));
  int n1(int num)  // Function to isolate first digit of 2-digit integer
    num = num / 10; //Integer division by 10 (discard remainder)
    return num;
  int n2(int num)  // Function to isolate second digit of 2-digit integer
    num = num % 10; //Modulo division by 10 (keep remainder only)
    return num;
the merged code is this...
  DS3231RTC (I2C bus)
#include <Time.h>
#include <Wire.h>
const int mDataIn=12, mLoad=11, mClk=6;  //Max7219 LED matrix
// pin setups
int latchPin = 9;
int clockPin = 10;
int dataPin = 8;
int tempPin = 7;
int ledg = 5;
int ledb = 4;
int ledr = 3;
int state;
int de = 100;
  tempSens.begin();
  h1=n1(hour());
  h2=n2(hour());
  m1=n1(minute());
  m2=n2(minute());
  s1=n1(second());
  s2=n2(second());
    return num;
    return num;
  if (t>=10){
  int rT = (int)t;
  rT = rT/10;
  int tens = rT % 10;
  delay(100);
    int rT = (int)t;
  int tens = 11;
  delay(100);
  else if (t<0){
    double d = t;
    d = -d;
    int rT = (int)d;
  int tens = 10;
  delay(100);
//    blink = false;
 // msg
  if(blink == 50) {
    state = 1;
  else   //on
    if(blink == 49) {
      state = 2;
   else   //off
      if(blink == 48) {
       state = 3;
   if(blink == 51) {
    state = 1;
  // shift units
  // shift tens
  // shift out data
  int i=0;
  int pinState;
      pinState= 1;
    else {
      pinState= 0;
So.. if i compile it i get no erros... But i doesn't work (obviously with such a mess...) and it drives me crazy!
So any suggestions please?
But i doesn't work
For some definition of work. The code does something. We can't see what it does. You expect it to do something. We can't guess what.
Im sorry about that... let me explain better .So i have a thermometer with 2 7segments driver from 2 shift registers and a rgb led witch read from serial 4 different states (on - alarm - cycle- off) . in one arduino . i also have a binary clock with real time clock shield (led matrix+max7419+rtc) connected to another arduino.
Since i have spare port in my first project i thought if it was possible to merge those two projects so i can use only one arduino ,so i merge the codes.What im trying to do is to read from my sensor the temperature and "shift " it out in the 7segments at the same time send data to my binary clock and also read from serial events...
I hope i was clear enough...
No. The code you posted does something. You have not explained what it does. It's hard to get from point a (the code you have now) to point b (the code that actually does what you want) without knowing where point a is.
thank you for your time but i understand well i explained the purpose and there are comments in the code.. so i dont know what else i can do...
    return num;
I think that you are missing a closing brace.
Besides, this is simple enough that you don't need to create a function just for this. You could use:
h1=(hour())/10; // tens digit of hours
h2=(hour())%10; // ones digit of hours
and so forth for the minutes and seconds.
