Hi All
I am using a modified version of the binary clock code from here (http://www.instructables.com/id/Arduino-Powered-Binary-Clock/?ALLSTEPS)
I am using it with an RTC instead of the little up/down buttons that you have to use each time. Currently I read the time from the RTC only in the setup() function and the code just takes it from there - looping around and checking if 1000ms have passed each time.
This strikes me as being rather inefficient. Is there a way of using interrupts to have the chip idling most of the time, and only "waking up" once a second to update the time if required?
I believe I can configure the RTC module to output a 1Hz square wave on it's currently unused "SQW" pin - could that drive the interrupt or could I save a wire and use an internal timer?
Looking forward to your hints!
My code FYI:
#include <Wire.h>
#include <RTClib.h>
An open-source binary clock for Arduino.
Based on the code from by Rob Faludi (http://www.faludi.com)
Code under (cc) by Daniel Spillere Andrade, www.danielandrade.net
http://creativecommons.org/license/cc-gpl
RTC_DS1307 rtc;
int second, minute, hour;
int munit,hunit;
for (int i=1; i <= 13; i++) {
pinMode(i, OUTPUT);
Wire.begin();
rtc.begin();
DateTime now = rtc.now();
second = now.second();
minute = now.minute();
hour = now.hour();
static unsigned long lastTick = 0; // set up a local variable to hold the last time we moved forward one second
// (static variables are initialized once and keep their values between function calls)
// move forward one second every 1000 milliseconds
if (millis() - lastTick >= 1000) {
lastTick = millis();
second++;
// move forward one minute every 60 seconds
if (second >= 60) {
minute++;
second = 0; // reset seconds to zero
// move forward one hour every 60 minutes
if (minute >=60) {
hour++;
minute = 0; // reset minutes to zero
if (hour >=24) {
hour=0;
munit = minute%10; //sets the variable munit and hunit for the unit digits
hunit = hour%10;
// minute units
// LED 1 binary 1
if(munit == 1 || munit == 3 || munit == 5 || munit == 7 || munit == 9) {
digitalWrite(1, HIGH);
digitalWrite(1,LOW);
// LED 2 binary 2
if(munit == 2 || munit == 3 || munit == 6 || munit == 7) {
digitalWrite(2, HIGH);
digitalWrite(2,LOW);
//LED 3 binary 4
if(munit == 4 || munit == 5 || munit == 6 || munit == 7) {
digitalWrite(3, HIGH);
digitalWrite(3,LOW);
//LED 4 binary 8
if(munit == 8 || munit == 9) {
digitalWrite(4, HIGH);
digitalWrite(4,LOW);
//minutes tens
if((minute >= 10 && minute < 20) || (minute >= 30 && minute < 40) || (minute >= 50 && minute < 60)) {
digitalWrite(5, HIGH);
digitalWrite(5,LOW);
if(minute >= 20 && minute < 40) {
digitalWrite(6, HIGH);
digitalWrite(6,LOW);
if(minute >= 40 && minute < 60) {
digitalWrite(7, HIGH);
digitalWrite(7,LOW);
//hour units
if(hunit == 1 || hunit == 3 || hunit == 5 || hunit == 7 || hunit == 9) {
digitalWrite(8, HIGH);
digitalWrite(8,LOW);
if(hunit == 2 || hunit == 3 || hunit == 6 || hunit == 7) {
digitalWrite(9, HIGH);
digitalWrite(9,LOW);
if(hunit == 4 || hunit == 5 || hunit == 6 || hunit == 7) {
digitalWrite(10, HIGH);
digitalWrite(10,LOW);
if(hunit == 8 || hunit == 9) {
digitalWrite(11, HIGH);
digitalWrite(11,LOW);
//hour
if(hour >= 10 && hour < 20) {
digitalWrite(12, HIGH);
digitalWrite(12,LOW);
if(hour >= 20 && hour < 24) {
digitalWrite(13, HIGH);
digitalWrite(13,LOW);
