live2
1
Hello how do I correctly convert a double value into my byte array? I would like to use BCD for this. Thanks for your support!
float temperature = 24.12;
float humidity = 60.12;
byte message[5];
message[0] = 12; //sensor id 12
float temperature1 = floor(temperature);
float temperature2 = (temperature - temperature1) * 100;
Serial.println(temperature1, 0);
Serial.println(temperature2, 0);
message[1] //?? temperature1
message[2] //?? temperature2
float humidity1 = floor(humidity);
float humidity2 = (humidity - humidity1) * 100;
message[3] //?? humidity1
message[4] //?? humidity2
LarryD
2
Search the forum for BCD.
There was a thread a few weeks ago.
b707
3
this variables should be int, not float
and after that convert it to BCD, assuming you mean a 4 bits per digit:
message[1] = ((temperature1/10) <<4) | (temperature1 %10);
Take the conversion of temperature2 as your homework;
Do you want byte packed BCD, or not? Why BCD? What is the requirement for it?
Perhaps 4 BITS per digit????
You say double but code has float. Humidity can't normally be measured to the 1/100 of a percent. So it's a waste to encode it that way.
live2
8
I use lora for data transfer to another module and therefore need as small a package as possible
live2
9
Yes, you're right, a two-digit number without decimal places would probably be sufficient here
gfvalvo
10
Then why not send it in binary?
Then why a floating point type at all? A byte would be more than sufficient.
system
Closed
11
