Binary Cube problems
hey I programmed a Binary cube with 3 leds. when i push the button a short time the arduino set a random value (1-7) and the leds light up. when i push the button all the time the leds are lighting up very fast but the value 7 (all leds are on) is lighting up longer an brighter than the other values (for example value 5 first and third led. can you help me?
int ledpin = 5;
int ledpin1 = 6;
int ledpin2 = 7;
int taster = 10;
long randNumber;
  pinMode(ledpin, OUTPUT);
  pinMode(ledpin1,OUTPUT);
  pinMode(ledpin2,OUTPUT);
  pinMode(taster,INPUT);
  if   (digitalRead(taster)==HIGH){
      randNumber = random(1, 8);
      Serial.println(randNumber);
      delay(100);
       digitalWrite(taster, LOW);
  if (randNumber == 1){
      digitalWrite(ledpin, HIGH);}
  else {digitalWrite(ledpin, LOW);
      digitalWrite(ledpin1, LOW);
      digitalWrite(ledpin2, LOW);}
  if (randNumber == 2){
      digitalWrite(ledpin1, HIGH);}
  else{ digitalWrite(ledpin, LOW);
  if (randNumber == 3){
  if (randNumber == 4){
      digitalWrite(ledpin2, HIGH);}
  if (randNumber == 5){
  if (randNumber == 6){
  if (randNumber == 7){
and the circiut
loop() executes thousands of times a second, so a random number is generated thousands of times a second .
Why ?
oh sry i tried something
this is not important
and can i set a "slower loop"?
No. But you can put our random number generator within a "blink without delay" millis() timer.
if(digitalRead(taster) == HIGH) {
  const unsigned long interval = 1000;
  static unsigned long lastRandomNumber;
  if(millis() -lastRandomNumber >= interval)
    lastRandomNumber = millis();
    byte randNumber = random(1, 8);
hey thanks but i dont know how to add this to my code^^
because im a newbie at arduino
Being newbie does not prevent you from reading the code and thinking things through. :slight_smile:
Where do you think it should go?
Your code
      delay(100);
my suggested modification
hey i asked because the leds arent lighting up but the serial monitor shows me random values do you have a idea why?
Pick a randNumber.
Step through each if (randNumber == [i]N[/i]) ··· .
What happens?
I messed up with the variable scope when I wrote the snippet which I tested alone and not as part of your program. :frowning: In your program there may be two variables randNumber with different scope and only the local one is changing and getting printed.
See if this works.
int ledpin = 5;
int ledpin1 = 6;
int ledpin2 = 7;
int taster = 10;
//long randNumber;
byte randNumber;
  pinMode(ledpin1, OUTPUT);
  pinMode(ledpin2, OUTPUT);
  pinMode(taster, INPUT);
       delay(100);
  if (digitalRead(taster) == HIGH) {
    if (millis() - lastRandomNumber >= interval)
      // byte randNumber = random(1, 8);
    // delay(100);
    // digitalWrite(taster, LOW);
  if (randNumber == 1) {
  else {
  if (randNumber == 2) {
  else {
  if (randNumber == 3) {
  else {
  if (randNumber == 4) {
  else {
  if (randNumber == 5) {
  else {
  if (randNumber == 6) {
  else {
  if (randNumber == 7) {
  else {
hey thanks nice its working now
