binary data write wav file sd card
Hello, I want to receive binary data through TCP socket communication and save it as a wav file on the SD card.
It is possible to save, but even if you directly run the file in the SD card, it cannot be played back. Please let me know what is wrong.
Board used: arduino mkr zero, arduino mkr ethernet shild
=========================> my arduino code (server) <==========================
#include <SPI.h>
#include <Ethernet.h>
#include <SD.h>
File myFile;
byte mac[ ] = {
0x00, 0xAA, 0xBB, 0xCC, 0xDE, 0x02
IPAddress ip(172, 30, 1, 150);
IPAddress myDns(168, 126, 63, 1);
IPAddress gateway(172, 30, 1, 254);
IPAddress subnet(255, 255, 255, 0);
EthernetServer server(6000);
boolean gotAMessage = false;
Ethernet.init(5);
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
// start the Ethernet connection:
Serial.println("Trying to get an IP address using DHCP");
if (Ethernet.begin(mac) == 0) {
Serial.println("Failed to configure Ethernet using DHCP");
// Check for Ethernet hardware present
if (Ethernet.hardwareStatus() == EthernetNoHardware) {
Serial.println("Ethernet shield was not found. Sorry, can't run without hardware. :(");
while (true) {
delay(1); // do nothing, no point running without Ethernet hardware
if (Ethernet.linkStatus() == LinkOFF) {
Serial.println("Ethernet cable is not connected.");
// initialize the Ethernet device not using DHCP:
Ethernet.begin(mac, ip, myDns, gateway, subnet);
// print your local IP address:
Serial.print("My IP address: ");
Serial.println(Ethernet.localIP());
// start listening for clients
server.begin();
if (!SD.begin()) {
Serial.println("SD initialization failed!");
while (1);
Serial.println("SD initialization success!");
delay(1);
if (client) {
if (!gotAMessage) {
Serial.println("We have a new client");
gotAMessage = true;
Serial.print("Writing voice.wav...");
myFile = SD.open("voice.wav", FILE_WRITE);
while (client.available()) {
Serial.print("read >> ");
Serial.print(client.read());
myFile.write(client.read());
Serial.print("\n");
// close the file:
myFile.close();
Serial.println("done.");
// echo the bytes to the server as well:
Ethernet.maintain();
=========================> my java code (client) <==========================
@Transactional(rollbackFor = Exception.class)
public boolean sendVoice(CommandMap params, MultipartFile file, Locale locale) throws RequestResolveException {
if(file != null) {
UserInfo user = getUserInfo();
params.put("svcKey", user.getSvcKey());
if(params.isEmptyValue("svcKey")){
throw new RequestResolveException(ErrorCode.INVALID_PARAMETER, getMessage("common.msg.notfound", locale, null));
if(params.isEmptyValue("skbKey")) {
int port = Integer.parseInt("6000");
String serverIp = "172.30.1.51";
byte[] buffer = new byte[DEFAULT_BUFFER_SIZE];
int readBytes;
long fileSize = file.getSize();
long totalReadBytes = 0;
double startTime = 0;
Socket socket = null;
FileInputStream fis = null;
OutputStream os = null;
try {
fis = (FileInputStream) file.getInputStream();
socket = new Socket(serverIp, port);
if(!socket.isConnected()){
throw new RequestResolveException(ErrorCode.INVALID_PARAMETER, getMessage("sk.api.msg.fail", locale, null));
os = socket.getOutputStream();
while ((readBytes = fis.read(buffer)) > 0) {
os.write(buffer, 0, readBytes);
totalReadBytes += readBytes;
System.out.println("In progress: " + totalReadBytes + "/" + fileSize + " Byte(s) (" + (totalReadBytes * 100 / fileSize) + " %)");
} catch (UnknownHostException e) {
e.printStackTrace();
} catch (IOException e) {
} finally {
try { if(fis != null) fis.close(); } catch (Exception e) { e.printStackTrace(); }
try { if(os != null) os.close(); } catch (Exception e) { e.printStackTrace(); }
try { if(socket != null) socket.close(); } catch (Exception e) { e.printStackTrace(); }
throw new RequestResolveException(ErrorCode.EMPTY_PARAMETER, getMessage("common.msg.requirevalue", locale, "common.file"));
return true;
