char msg[]="hello";
char binary[512];
char* charbin[64];
char temp[]="00000000";
Serial.begin(9600); // open serial port at 9600 baud
for(int i=0; i<5; i++){
byte c = msg[i]; // read one character
for(int i=0; i<8; i++) {
if ((c%2)==0){
binary[i]='0'; // print the least significant bit
c /= 2;
else if((c%2)==1){ // move to next significant bit
binary[i]='1';
c /= 2;
for (int i=0; i<64; i++){
for (int a=0; a<8; a++){
temp[a]=binary[a];
charbin[i] = temp;
Serial.println(charbin);
delay(2000);
all i want to do i break the sting of 64 chars to binary ( so 8*64=512 right?????? 0 and 1 );
and then reconstract the original sting again.
msg="hello" value in my code is for test only.
i don't understand what is wrong actualy with my code.
i get this conpilation error but i don't understand why.
A string is readable text. So the digits of "010101010" are ascii characters, not numbers.
The hexadecimal value of zero = 0x30, and one = 0x31.
So when the string "010101010" is received, the received values are : 0x30, 0x31, 0x30, 0x31, 0x30, 0x31, 0x30, 0x31, 0x30
A binary value is in my opinion just a variable with a certain value. For example: int i = 170;
The binary value of 170 = 010101010
We used to have to do these sorts of exercises in CS year 1 (early on) to make use realise that data has the meaning you attach to it. Ultimately its all just bits. That was many years ago!
i would like to brake a string of characters to zeros and ones and then reconstract from the zeros and ones the initial string.
my first thought is to brake every character to it's ASCII code binary by using one FOR LOOP
if ((c%2)==0){ //if it is 0,
binary[i]='0'; // right it to the binary[i]
c /= 2; // move to next significant bit
else if((c%2)==1){ // if it is 1,
binary[i]='1'; //right it to binary[i]
and until this point everything works great.
if i try a Serial.print(binary) i get a sting of 40 zeros and ones
my problem starts when i try to break every 8 bits to an Array of strings. ( i am thinking that it would be nice to have them organised in on string( for example "01010101","10101010")
and my problem startson the reconstruction. i have this loop
temp[a]=binary[a]; // put every bit in order inside temp
charbin[i] = temp; / write temp in to charbin[i]
but i get this compilation error : call of overloaded 'println(char*[64])' is ambiguous.
am i thinking correct ?
wouldn't this be the way to do it ?
if not what could i do to break 64 characters in to zeros and ones and how can i reconstruct from zeros and ones the same sting of 64 chars ?
can any one tell me why i get this compilation error?
No.
Where is there a call to println() in that snippet?
if ((c%2)==0){
c /= 2;
binary[i]='1';
c /= 2;
temp[a]=binary[a];
charbin[i] = temp;
delay(2000);
The println() method does not have an overload that can print an array of strings. You could print the ith element of the array (in a for loop, if needed).
