Hi everyone,
I'm a bit new to C# and data types. I'm attempting to control a chip via SPI via an 8-bit serial word.
According to the documentation (https://datasheets.maximintegrated.com/en/ds/MAX5408-MAX5411.pdf ) that would look something like 10111111 in binary.
In the above example, the first three digits are used to select what is bring controlled, and the next five what changes need to be made.
So for the above command, I would like to XXX + YYYYY.
I would like to maintain them as separate variables, and concatenate them before sending the SPI transfer. I believe I have to add a "B" to the
Something like:
String concatenatedString = "";
concatenatedString = "B" + String(XXX) + String(YYYYY);
SPI.transfer(concatenatedString);
What is the most valid way to do so?
uint8_t top = some_number;
uint8_t bottom = some_number;
uint8_t command = (uint8_t) ((top << 5) | (bottom & 0x1F));
Thank you for the answer!
Would you mind explaining what's happening here?
Lets say your top value is 0x01 or 00000001
0x01 << 5 will shift the bits to the left 5 times
0x01 << 5 = 00100000
You do binary OR to combine the lower and top value
00100000 | some_number
So if some_number is 00000101
00100000 | 00000101 = 00100101
const byte XXX = 0b101 << 5;
const byte YYYYY = 0b11111;
SPI.transfer(XXX+YYYYY);
Since they have no 1-bits in common you can use either '+' or '|' (bitwise OR) interchangeably.
Thanks @johnwasser . Trying to think back to my digital electronics classes here.
I would guess since I am using variables here, it would be safer to use the bitwise operator? It's only this specific example that would be safe?
As long as the two fields being merged don't share any 1 bits you can merge them with +.
0 | 0 == 0 + 0 == 0
0 | 1 == 0 + 1 == 1
1 | 0 == 1 + 0 == 1
The only problem is if they share a 1 bit:
1 | 1 == 1
1 + 1 == 0 with a carry
Thank you for the explanation.
Given the following code:
void digitalPotWrite(int address, int command) {
// take the SS pin low to select the chip:
digitalWrite(slaveSelectPin, LOW);
delay(100);
const byte XXX = address;
const byte YYYYY = command;
SPI.transfer(XXX | YYYYY);
Serial.println(XXX | YYYYY, BIN);
delay(100);
// take the SS pin high to de-select the chip:
digitalWrite(slaveSelectPin, HIGH);
Serial.println(XXX | YYYYY, BIN); is returning a 7-bit string, rather than an 8. E.g.: Expecting 0 1000000 but get 1000000
Is this a result of Serial.println or do I have an issue?
How can I be sure the chip is getting the correct value?
Try the following to see the missing leading zero:
byte x = XXX | YYYYY;
for(int i = 7; i>=0; i--)
Serial.print(bitRead(x, i), BIN);
Serial.println() always suppresses leading zeroes. You can rest assured that any bits on the left that aren't shown are zeroes.
SPI.transfer() only sends 8-bit values.
SPI.transfer() also returns 8-bit data.
system
Closed
July 24, 2022, 6:47pm
12
