Bipolar DC motor not working
Currently using two DAGU Robots DG01D motor with Intel Edison. Had made it worked once but after a few days the motor is not running with no connection changes made. Am sure that the motors are not spoiled. Am i doing something wrong like the programs or the connection?
Thank You.
zaqwerty:
If you knew nothing at all about your problem and you read your Post would you know how to answer that question?
  • Post a link to the datasheet for the motor.
  • Post a link to the datasheet for the motor driver.
  • Make a pencil drawing showing how everything is connected and post a photo of the drawing.
  • Post your program code.
...R
Motor link : 检测中
motor shield link:http://www.elecrow.com/motor-stepper-shield-for-arduino-p-843.html
program :
Stepper Motor Control - one revolution
This program drives a unipolar or bipolar stepper motor.
The motor is attached to digital pins 8 - 11 of the Arduino.
The motor should revolve one revolution in one direction, then
one revolution in the other direction.
Created 11 Mar. 2007
Modified 30 Nov. 2009
by Tom Igoe
#include <Stepper.h>
const int stepsPerRevolution = 200; // change this to fit the number of steps per revolution
// for your motor
// initialize the stepper library on pins 8 through 11:
Stepper myStepper(stepsPerRevolution, 8, 9, 10, 11);
// set the speed at 60 rpm:
myStepper.setSpeed(60);
// initialize the serial port:
// step one revolution in one direction:
Serial.println("clockwise");
myStepper.step(stepsPerRevolution);
// step one revolution in the other direction:
Serial.println("counterclockwise");
myStepper.step(-stepsPerRevolution);
Sorry for posting the question above. I got the motor working with program i got from Elecrow website.
Sorry and Thank You for replying
const int pinI1=8;//I1
const int pinI2=11;//I2
const int speedpinA=9;//EA(PWM)to control the motor_1 speed
const int pinI3=12;//I3
const int pinI4=13;//I4
const int speedpinB=10;//EB(PWM]) to control the motor_2 speed
for(int i=0;i<20;i++)
pinMode(i,OUTPUT); //set to output
Test_Load_Left();
delay(3000);
clean_Output();
Test_Load_Right();
delay(3000);
/Set the motor1 clockwise and motor2 anticlockwise, with speed 150/
void Test_Load_Left()
analogWrite(speedpinA,150);
analogWrite(speedpinB,150);
digitalWrite(pinI4,HIGH);
digitalWrite(pinI3,LOW);
digitalWrite(pinI2,HIGH);
digitalWrite(pinI1,LOW);
/*Set the motor1 clockwise and motor2 anticlockwise, with speed 100 */
void Test_Load_Right()
analogWrite(speedpinA,100);
analogWrite(speedpinB,100);
digitalWrite(pinI1,HIGH);
digitalWrite(pinI2,LOW);
digitalWrite(pinI3,HIGH);
digitalWrite(pinI4,LOW);
/*Stop the motors */
void clean_Output()
digitalWrite(speedpinA,LOW);// full PWM 255
digitalWrite(speedpinB,LOW);
As you have probably figured out now, those are not stepper motors. They are just simple DC motors.
...R
