First of all, if you are starting, you need to get used to the "rules" when you write code. Look how it looks after select the option "Auto-format" from the "Tools" menu:
int ledPin = 9;
int gndPin = 8;
int gnd = 7;
int bt = 6;
int etat = LOW;
int cpt = 0;
pinMode(ledPin, OUTPUT);
pinMode(gndPin, OUTPUT);
pinMode(gnd, OUTPUT);
pinMode(bt, INPUT);
digitalWrite(gndPin, LOW);
digitalWrite(bt, LOW);
digitalWrite(gnd, HIGH);
etat = digitalRead(bt);
if (etat == HIGH) {
cpt++;
do {
digitalWrite(ledPin, HIGH);
if (digitalRead(bt) == HIGH && cpt == 1) {
digitalWrite(ledPin, LOW);
} while (1);
EDIT:
2nd I like (but is a personal question) to have the ' { ' of the if in the same line (it can solve you many hours of debugging too).
3rd I don't like the while (1) and the break. I prefer use something like:
do {
// do something
if (some_var == some_value) {
exit = true;
} while (exit==false);
Your program don't do what you what because of this line:
if (etat == HIGH) {
You must look for the change of state, and not for the 'HIGH' state.
byte LEDpin = 13; //on-board LED
byte ButtonPin = 2; //digital pin 2
boolean button, lastState = LOW;
boolean latch = false;
pinMode(LEDpin, OUTPUT);
pinMode(ButtonPin, INPUT);
button = digitalRead(ButtonPin); // read the button state
if (button != lastState) // compare the button state to an old state
if(button == HIGH) // if the button is different from its old state, see if the button is HIGH
latch = !latch; // 0 -> 1, 1 -> 0
if(latch == 1)
digitalWrite(LEDpin, HIGH);
digitalWrite(LEDpin, LOW);
//OR.
//digitalWrite(LEDpin, latch);
//OR..
//digitalWrite(LEDpin, !digitalRead(LEDpin) );
//OR...
//latch ? digitalWrite(LEDpin, HIGH): digitalWrite(LEDpin, LOW); //Equal to above IF/ELSE statement.
lastState = button; // update old state
The StateChangeDetection example sketch demonstrates how to read a digital input, debounce it and detect state transitions.
In the example, it is counting button presses. Here, you would want to replace that code with something to toggle the state of an output pin. The following code will toggle the pin for you:
I would like to push the button one time to get the LED ON, she's stay in this state until i press the button a second time.
Sorry for bad explanation and thank you for your help !
HazardsMind, the "if thing" that I describe in the first post. For me, and even more if we are trying to teach the language to someone fresh coming, I like to write (and teach to them to write):
luisilva:
if (some_condition) {
//some code
instead of:
if (some_condition)
//some code
They are both established code layout schemes, each with pros and cons. In my opinion, the benefits of the second layout outweigh the benefits of the first layout.
Yes it is, and I’m not saying that. The rule 14.9 from MISRA 2004 says:
An if (expression) construct shall be followed by a compound statement. The else keyword shall be followed by either a compound statement, or another if statement.
if ( test1 )
x = 1; /* Even a single statement must be in braces /
else if ( test2 ) / No need for braces in else if /
x = 0; / Single statement must be in braces /
x = 3; / This was (incorrectly) not enclosed in braces /
y = 2; / This line was added later but, despite the
appearance (from the indent), it is actually
not part of the else, and is executed unconditionally */
luisilva:
So, this bug will never “born” if you had used to do the for loop like:
The second layout doesn’t prevent the problem - it merely changes how it would appear (it makes it slightly less obvious, in my opinion, since the spurious semicolon is no longer at the end of the line):
for (int i=0; i<MAX; i++) ;{
However, I would expect that sort of mistake to be glaringly obvious to any experienced programmer scanning the code using either layout. The benefit of the second layout IMO is that it is far easier to visually match up matching pairs of brace characters so that the control structure of the code can be verified against the structure implied by the indentation.
PeterH:
It depends what time is it, and how many hours you sleep, I think. If there are 02:00 and you sleep 4h the last night there are some mistakes that are obvious than others. Or this or I'm not an experienced programmer.
