I am working on a project where i need to create a byte from several bits and then send that data to PORTL on the mega as a HEX value(this is being written to an 8254 to read/write high freq)
I'm not sure what I've got wrong.
Any help would be appreciated.
int dataLines[8] = { 49,48,47,46,45,43,42 }; // datalines can either be input or output, need to set mode before performing operation
int A_0 = 37;
int A_1 = 36;
int RD = 34;
int WR = 35;
int CS[8] = { 26,27,28,29,30,31,32,33 };
//Data to send/receive from PORTL
//bits 7-6 counter select
//0 0 -> Counter 0
//0 1 -> Counter 1
//1 0 -> Counter 2
//1 1 -> Read Back Command
//bits 5-4 read/write
//0 0 -> Latch
//0 1 -> LSB only
//1 0 -> MSB only
//1 1 -> LSB followed by MSB
//bits 3-1
//mode -> see data sheet for all
//0 1 1 -> mode 3 (freq generator)
//bit 0 BCD mode
//0 -> Binary counter 16 bit
//1 -> BCD(4 decades)
int controlWord[8] = {0,0,0,0,0,0,0,0};
for (int i = 0; i < 9; i++) {//chip select lines
pinMode(CS[i], OUTPUT);
setDataLines_RW(false);
setChipRW(0);
selectChip(10);
selectChip(0);
setChipRW(2);
selectChipCounter(0);
setControlWordCounter(0);
setControlReadWrite(3);
setControlMode(3);
setControlBCDMode(0);
for (int i = 0; i <= 7; i++) {
Serial.print(i);
Serial.print(" : ");
Serial.println(controlWord[i]);
Serial.println((byte)controlWord, HEX);
delay(100);
//0 0 -> Counter 0
//0 1 -> Counter 1
//1 0 -> Counter 2
void setControlWordCounter(int mode) {
switch (mode)
case 0: //counter 0
controlWord[7] = 0;
controlWord[6] = 0;
case 1: //counter 1
controlWord[7] = 0;
controlWord[6] = 1;
case 2: //counter 2
controlWord[7] = 1;
controlWord[6] = 0;
case 3: //control word register
controlWord[7] = 1;
controlWord[6] = 2;
//bits 5-4 RW Select
//mode 0 -> Latch
//mode 1 -> LSB only
//mode 2-> MSB only
//mode 3 -> LSB followed by MSB
void setControlReadWrite(int mode) {
switch (mode)
case 0:
controlWord[5] = 0;
controlWord[4] = 0;
case 1:
controlWord[5] = 0;
controlWord[4] = 1;
case 2:
controlWord[5] = 1;
controlWord[4] = 0;
case 3:
controlWord[5] = 1;
controlWord[4] = 1;
default:
//bits 3-1 mode select
//mode 0 -> Interrupt on Terminal Count
//mode 1 -> Hardware Re-Triggerable One-Shot
//mode 2 -> Rate Generator
//mode 3 -> Square Wave Mode(freq generator)
//mode 4 -> Softwar Triggered Strobe
//mode 5 -> Hareware Triggered Strobe
void setControlMode(int mode) {
switch (mode)
case 0:
controlWord[3] = 0;
controlWord[2] = 0;
controlWord[1] = 0;
case 1:
controlWord[3] = 0;
controlWord[2] = 0;
controlWord[1] = 1;
case 2:
controlWord[3] = 0;
controlWord[2] = 1;
controlWord[1] = 0;
case 3:
controlWord[3] = 0;
controlWord[2] = 1;
controlWord[1] = 1;
case 4:
controlWord[3] = 1;
controlWord[2] = 0;
controlWord[1] = 0;
case 5:
controlWord[3] = 1;
controlWord[2] = 0;
controlWord[1] = 1;
default:
//bit 0 BCD Select
//0 -> Binary counter 16 bit (65535)
//1 -> BCD(4 decades) (10000)
void setControlBCDMode(int mode) {
switch (mode)
case 0:
controlWord[0] = 0;
case 1:
controlWord[0] = 1;
default:
//id -> chip to read/write from
//id=10 -> turn off all chips
void selectChip(int id) {
if (i != id) {
digitalWrite(CS[i], HIGH); //make sure other chips are turned off
if (id != 10) {
digitalWrite(CS[id], LOW);//turn on this chip
//Select counter to read/write from
//0 -> Counter 0
//1 -> Counter 1
//2 -> Counter 2
//3 -> Control Word Register
void selectChipCounter(int counter) {
switch (counter)
case 0: //counter 0
digitalWrite(A_1, LOW);
digitalWrite(A_0, LOW);
case 1: //counter 1
digitalWrite(A_0, HIGH);
case 2: //counter 2
digitalWrite(A_1, HIGH);
running the code as is gives me this result
0 : 0
1 : 1
2 : 1
3 : 0
4 : 1
5 : 1
6 : 0
7 : 0
43 <- this number i believe is wrong
I think it should be 36
The bits look to be set correctly, but the expected output is not what I'm getting.
36 HEX -> 0011 0110 Binary
43 HEX -> 0100 0011 Binary
Not sure how I got this result.
Thank you!
