Bit-Banging UNI/O Bus with Arduino Uno [Failing]
Hey Guys!
I just managed to set everything up to bit-bang my UNI/O driven EEPROM. Sadly I have not managed to get it to work properly.
Some information for you if you want to help out:
The Datasheet of my EEPROM The UNI/O Bus Spec sheet
What I did so far?
I was about to do some Adress Polling |500x197
It is a way I can actually debug stuff since I receive a SAK if the device is adressable. I've setup my code here to do the first example of the address polling. After sending the NoMAK after the address byte I was about to receive a SAK. But I only receive NoSAK the whole time. My problem is now that I can't figure out the error source because debugging seems pretty tricky here. Rather impossible for me. I'm about to receive a Oszilloskop in a few days to at least check out my frequencies. But to be honest I'm sure my frequencies won't be the issue here because its all about a minimum of µs and I cleared all doubts by adding an offset of 5µs at every time constant.
Maybe you guys have an idea where the issue may be. I really want to finish this tryout and don't want to give up.
#define TSTBY 605 // StandBy-Pulse 600µs + 5µs offset
#define TSS 15 // StartHeader setup time 10µs + 5µs offset
#define THDR 10 // StartHeader low pulse time 5µs + 5µs offset
#define TE 15 // BitPeriod time 10µs + 5µs offset
#define BUSPIN 9 // Pin to communicate with set to 9
int fstEdgeSample = 0;
int sndEdgeSample = 0;
    pinMode(BUSPIN, OUTPUT);
    digitalWrite(BUSPIN, LOW);
    StandByPulse();
    StartHeaderPulse();
    MAK();
    if (isSAK()) Serial.println("SAK"); else Serial.println("NoSAK");
    AdressPulse();
    NoMAK();
  /* add main program code here */
void BitOne()
    delayMicroseconds(TE / 2);
    digitalWrite(BUSPIN, HIGH);
void BitZero()
void MAK()
    BitOne();
void NoMAK()
    BitZero();
void TransmitByte(uint8_t value)
    if (value & 0x80) BitOne(); else BitZero();
    if (value & 0x40) BitOne(); else BitZero();
    if (value & 0x20) BitOne(); else BitZero();
    if (value & 0x10) BitOne(); else BitZero();
    if (value & 0x08) BitOne(); else BitZero();
    if (value & 0x04) BitOne(); else BitZero();
    if (value & 0x02) BitOne(); else BitZero();
    if (value & 0x01) BitOne(); else BitZero();
void StandByPulse()
    digitalWrite(BUSPIN, HIGH); // Write high digital signal
    delayMicroseconds(TSTBY); // let standby-pulse time pass
void StartHeaderPulse()
    digitalWrite(BUSPIN, LOW); // High to Low transition for THDR
    delayMicroseconds(THDR); // THDR Time
    TransmitByte(0b01010101);
void AdressPulse()
    TransmitByte(0b10100000);
bool isSAK()
    pinMode(BUSPIN, INPUT);
    delayMicroseconds(TE / 4); // Trimmed-Bit-Period
    fstEdgeSample = digitalRead(BUSPIN);
    delayMicroseconds(TE / 2); // Trimmed-Bit-Period
    sndEdgeSample = digitalRead(BUSPIN);
    if (fstEdgeSample == LOW && sndEdgeSample == HIGH)
        return true;
        return false;
That is not easy at all, the clock can be 10us to 100us.
A digitalWrite() is already 5us, and a digitalRead() takes 3.5us.
The OneWire, DHT11/DHT22, NeoPixel, and others, they all use a single wire bit-banging timing based protocol.
Did you see the timing section of the NeoPixel library ?
Are you sure you are the first person to implement UNI/O for Arduino ?
Is this helpful : GitHub - sde1000/NanodeUNIO: Driver for Microchip UNI/O devices on Nanode (eg. the MAC address chip)
Hey there!
No I'm not the first person :D But that's also not my goal. I want to learn the mechanics to the core. And therefore I just want to do it like it would be a new thing ;)
I see the issues with the timing here. Where did you have the µs-values for a digitalWrite() and a digitalRead() ?
http://forum.arduino.cc/index.php?topic=326944.0 http://playground.arduino.cc/Main/ShowInfo
Thanks for the informations!
I just figured out theres a PortRegister Constant which I can manipulate to get faster results:
https://www.arduino.cc/en/Reference/PortManipulation
