Bit of a loop problem
Can you have two “void loop()” in your code?
Trying to blink an led faster than printing to the serial monitor.
Here’s my code:
//variables
float tempC;
float tempF;
int tempPin = 0; // setting LM35 pin to analog 0
int ledPin = 9; // led pin set to digital 9
  Serial.begin(9600);   //start serial port
  pinMode(ledPin, OUTPUT); // set led pin as output
  tempC = analogRead(tempPin); // read value from sensor
  tempC = (5 * tempC * 100) / 1024; //convert voltage to Celcius
  tempF = (tempC * 9) / 5 + 32;    // convert Celcius to Fahrenheit
  Serial.print(tempF);Serial.println(" F");    // print to serial monitor
  delay(3000);      //wait a few seconds
  if (tempF < 82)  // check tempF
    digitalWrite (ledPin, HIGH); // turn led on
    delay (200) ; //pause
    digitalWrite (ledPin, LOW); //turn led off
    delay(200) ; // pause
The led blinks at the same rate of “Serial.print”,(delay 3000).
It seems to ignore “(delay 200)” for the led.
Is that because it’s in the same loop?
Tried putting the “if” statement in it’s own “void(loop)”, but I got a
re-definition error.
I think you answered your own question.
   [glow]{[/glow]<<<- remove
  if (tempF < 82)  [glow]{[/glow]  <<<put it here//
Oh yes the curly bracket I put in the wrong place, thanks for the help. But the led still blinks at delay(3000), not delay (200). Any more suggestions?
Do you mean that the LED is on for 3 seconds, then off for three seconds, or that it waits 3 seconds to come on, and then goes off 2/10 of a second later?
Upon reaching the end of loop(), the program will start again from the beginning of loop, doing another 3000ms delay. Maybe you need something like this:
    for (byte i=0; i<10; ++i) {
The second part. It waits 3 seconds to come on.
Ahh, I think I'm beginning to understand. So how do I separate the 2 ? If that's even possible. I want the led to blink at 200, while the serial monitor updates every 3000.
You first get rid of the delay calls. During a call to delay, NOTHING else happens (except that interrupts are processed). Look at the infamous Blink Without Delay example for how to blink an LED without using delay.
Then, expand that concept to have two tests for whether it is time to do something (serial output or light on/off) as well as two variables to hold the time of the last action (serial output or light on/off).
It's really quite simple, once you get the hang of it.
That kinda works, I never would of thought of using a ‘For Loop’.
I’ll have to look into that and give a read.
Thanks for the help guys.
Read the blinking with out delay and thought I'd give it a try, but I'm back to blinking at 3000 not 200. http://www.arduino.cc/en/Tutorial/BlinkWithoutDelay
//variables
float tempC;
float tempF;
int ledState = LOW;
long prevMill = 0;
long interval = 200;
  unsigned long currentMill = millis();
  if (currentMill - prevMill > interval) {
    prevMill = currentMill;
    if (ledState == LOW)
      ledState = HIGH;
       ledState = LOW;
     digitalWrite(ledPin,ledState);
I wonder why.
DOH! :P I totally forgot to put the serial print in it's own non-delay.
