Bit Shift Tutorial - Question.
I am working through Heather Dewey-Hagborg’s tutorial on software serial and can mostly follow along except for the bit highlighted below.
I am struggling to understand how the for loop will iterate through 8 bits by the use of the mask and bit shift statement.
As far as I can tell mask will always be greater than 0 so this loop will never end.
I have run this code and it works so what am I not understanding about this for loop?
Any one here care to shed some light to help my brain with this?
Cheers
Peter B.
void SWprint(int data)
byte mask;
//startbit
digitalWrite(tx,LOW);
delayMicroseconds(bit9600Delay);
for (mask = 0x01; mask>0; mask <<= 1) {
if (data & mask){ // choose bit
digitalWrite(tx,HIGH); // send 1
else{
digitalWrite(tx,LOW); // send 0
}[/quote]
mask is a byte, so as soon as the 1 is shifted off the end, it will be zero.
The value in mask is initially 0b00000001. After 1 shift, it is 0b00000010. After several more shifts, it is 0b10000000. What happens when another shift occurs? The 1 gets shifted out, and mask becomes 0b00000000.
Groove and PaulS; Thanks for your response, I had missed the point about the 8th left shift operation will mean that mask will then be equal to 0. Seems obvious now.
Cheers
Peter B.
An alternate implementation, that I find easier to read, is -
    // transmit start-bit
    digitalWrite(tx, LOW);
    byte bit_mask = b00000001;
    do
        digitalWrite(tx, ((data & bit_mask) ? HIGH : LOW));
    } while ( bit_mask <<= 1 );
lloyddean;
Thanks for the follow up, however I am not sure what the line
digitalWrite(tx, ((data & bit_mask) ? HIGH : LOW)); is attempting to do.
I guess this is where you are anding the mask with the data, but what is the ? HIGH : LOW doing?
Cheers
Peter B.
is a short-notation for an if statement
if (data & bit_mask) HIGH else LOW
can also be (cryptically) written
digitalWrite(tx, !!(data & bit_mask));
robtillart;
OK thanks, every time I write a new piece of code or interpret someone else's efforts I learn a new way of doing things. Thank you for the shortcut statement.
Cheers
Peter B.
AWOL;
Thanks also to you. But why would you do it that way? to save a few keystrokes or what! Does it save memory if you use shorter notation to get the result?
Peter B.
In fact, to save most, simply this:
digitalWrite(tx, data & bit_mask);
will work.
(this is only because the kind author of "digitalWrite" put the double-NOT (!!) inside "digitalWrite". If they changed the implementation of digitalWrite so that it only accepted HIGH or LOW, the code above would cease to work.)
