I have the following code.
Serial.print(dht_dat[0], DEC);
This works get when printing dht_dat out via serial. The result is that the serial port prints out an interger. dht_dat is an array that stores 8bits in each value. I want to store this value as a int to use later in the program. I'm not having any success with this however. Any help would be great!
Here is the code to generate the dht_dat array. Sorry this isn't my code and I just started using it so I don't know that much about it.
//This is the call to make the array
for (i=0; i<5; i++)
dht_dat = read_dht_dat();
//This is the read_dht_dat function that places the values into the array
byte read_dht_dat() {
- //Collect 8 bits from datastream, return them interpreted*
- //as a byte. I.e. if 0000.0101 is sent, return decimal 5.*
- //Code expects the system to have recently entered the*
- //dataline low condition at the start of every data bit's*
- //transmission BEFORE this function is called.*
- byte i = 0;*
- byte result=0;*
- for (i=0; i< 8; i++) {*
- //We enter this during the first start bit (low for 50uS) of the byte*
- //Next: wait until pin goes high*
- while(digitalRead(TEMP_RH_PIN)==LOW);*
- delayMicroseconds(30);*
- if (digitalRead(TEMP_RH_PIN)==HIGH)*
- result |=(1<<(7-i));*
- while (digitalRead(TEMP_RH_PIN)==HIGH);*
- return result;*
