bitlash - how to deceleration input string to function
I’m using bitlash.
Why this code doesn’t recognize the input “?” symbol?
void io(int num,  char state) {
      int digital_value;
      num = getarg(1);
      state = getarg(2);
        switch (state){
         case 0:
         pinMode(num,1);
         digitalWrite(num,0);
         case 1:
         pinMode(num,1);
         digitalWrite(num,1);
         case '?':
         pinMode(num,INPUT);
         digital_value = digitalRead(num);
         Serial.println(digital_value);
So in terminal I type for example: io(33,?)
I get: unexpected char
Thanks in advance.
Why did you not post all of your code ?
tried io(33, '?') with quotes?
disclaimer: no bitlash user/expert.
robtillaart: tried io(33, '?') with quotes?
Thanks robtillaart that's work!
There is any way that it can work without '?' io(33, '?') just io(33, ?) without ' '
So my next question is:
How can I recognize string ? for example:
         case 'abc':
         pinMode(num,INPUT);
What I need to config in the function ? void io(int num, string state) ? char * ?
It will be enclosed in double quotes, and cannot be used in a switch/case..
In this way?
If (strcmp(state,  "abc")  == 0)
What I need to definition in the function? How to declare the string?
void mx_io(int num, char* state) {
      int digital_value;
        if (strcmp(state, "0") == 0) {
           pinMode(num,1);
           Serial.println("done");
        else if (strcmp(state, "abc") == 0) {
           pinMode(num,1);
           Serial.println("abc");
        else if (strcmp(state, "?") == 0 ) {
           pinMode(num,INPUT);
          Serial.println("problem");
When I run this I got:
> mx_io(33,"abc")
problem
> mx_io(33,'abc')
expected >
I tried “abc” and ‘abc’ and none of them works.
Please try this variation that print out state and its length
      int digital_value;
           pinMode(num,1);
           pinMode(num,1);
           pinMode(num,INPUT);
           Serial.println(digital_value, DEC);
         Serial.println(len(state));
         Serial.println(state);
This option not compile:
Maybe because the char* state?
How to config input string for function by bitlash?
I tried "abc" and 'abc'.
BTW this return ' symbol
len should be strlen sorry my mistake, did a lot of python lately :)
Thanks robtillaart
When I tried "abc" the output strlen=0.
So what I need to do?
That means the pointer state points to nowhere...
do the "0" and the "?" work ?
Nope. :disappointed_relieved:
that means that char* state parameter does not work how you intended it.
I think this is caused by these missing lines
num = getarg(1); state = getarg(2);
These somehow take care that the parameters are passed. where is getarg() defined? And what does it return?
What I need to define to fix this issue ?
Please use my code above.
Thanks.
      num = getarg(1);
      state = getarg(2);
I got compile error:
error: invalid conversion from 'numvar' to 'char*'
I'm out of options (as I wont dive into bitlash depths), Sorry
Nobody knows how to declaration char* string input to function in bitlash? :|
Getarg returns a numvar, but you can cast the result of getarg to another type:
    char *foo = (char *) getarg(2);
-br
