Bitlashsd error
I trying to learn Bitlash to make a websever, storing pages on a SD card. Currently I am working on bitlashsd at the moment to understand SD using bitlash. I'm getting the following errors:
bitlash\bitlash.cpp.o: In function scriptfileexists': C:\arduino-1.0.1\libraries\bitlash\/src/bitlash-instream.c:50: multiple definition ofscriptfileexists(char*)' bitlashsd.cpp.o:C:\Users\jim\AppData\Local\Temp\build8548542757815330962.tmp/bitlashsd.cpp:142: first defined here bitlashsd.cpp.o: In function setup': bitlashsd.cpp:(.text.setup+0x40): undefined reference tosdcat()' bitlashsd.cpp:(.text.setup+0x42): undefined reference to sdcat()' bitlashsd.cpp:(.text.setup+0x64): undefined reference tofunc_fprintf()' bitlashsd.cpp:(.text.setup+0x66): undefined reference to func_fprintf()' bitlashsd.cpp.o: In functionsdappend()': bitlashsd.cpp:(.text._Z8sdappendv+0x40): undefined reference to `sdwrite(char*, char*, unsigned char)'
I'm using the SDFat library referred in the documentation and the Sd card on an ethernet shield with a Mega 2560.
Jim
Hello:
I wonder if you did this little necessary surgery described at the top of the bitlashsd sketch:
- Edit bitlash/src/bitlash.h to turn on the SDFILE define: at or near line 340, make this:
        //#define SDFILE
look like this:
        #define SDFILE
- If you are using a Mega2560, edit SdFat/SdFatConfig.h @ line 85, make this change:
    #define MEGA_SOFT_SPI 1
If you haven't already, try that and report back on whether your compile works better...
Best luck with your project!
-br
PS: Update. OOPS: The define needs to be enabled, not disabled. I've fixed fix the doc bug and have amended the text above. For avoidance of doubt, please make line 340 look like:
#define SDFILE
billroy: PS: Update. OOPS: The define needs to be enabled, not disabled. I've fixed fix the doc bug and have amended the text above. For avoidance of doubt, please make line 340 look like: /quote] The OOPS did the trick! Thanks! Great Language, but for a old dummy like probably a steep learning curve.
Jim
The program runs and it will display the directory. I have a file called sdtest.txt on the sd, but type sd.test.txt or exists sdtest.txt both return a dashed line then missing arg.
Jim
Let's check the syntax. Bear in mind that the SD card functions are proper functions that require parentheses for their arguments:
> dir()
> dir        // you can omit the parens if there are no args
> type("sdtest.txt")
> exists("sdtest.txt")
Does that help?
-br
