I have a simple problem and have no doubt that the solution is simple but I can't see the wood for the trees in this sketch
for (uint8_t x = 0; x < 20; x++)
uint32_t test = 1UL << x;
Serial.print("bit position : ");
Serial.print(x);
Serial.print("\t");
printFullBin(test);
void printFullBin(uint32_t value)
for (int bit = (sizeof(value) * 8) - 1; bit >= 0; bit--)
uint32_t mask = value & (1 << bit);
if (mask & value)
Serial.print(1);
Serial.print(0);
Its purpose is to print the value of a bit in an unsigned long variable with a view to testing the value and taking action based upon it
The output from the sketch is
bit position : 0 00000000000000000000000000000001
bit position : 1 00000000000000000000000000000010
bit position : 2 00000000000000000000000000000100
bit position : 3 00000000000000000000000000001000
bit position : 4 00000000000000000000000000010000
bit position : 5 00000000000000000000000000100000
bit position : 6 00000000000000000000000001000000
bit position : 7 00000000000000000000000010000000
bit position : 8 00000000000000000000000100000000
bit position : 9 00000000000000000000001000000000
bit position : 10 00000000000000000000010000000000
bit position : 11 00000000000000000000100000000000
bit position : 12 00000000000000000001000000000000
bit position : 13 00000000000000000010000000000000
bit position : 14 00000000000000000100000000000000
bit position : 15 00000000000000001000000000000000
bit position : 16 00000000000000001000000000000000
bit position : 17 00000000000000001000000000000000
bit position : 18 00000000000000001000000000000000
bit position : 19 00000000000000001000000000000000
All goes well until we reach bit 16 and I can't or the life of me see what I have done wrong. Perhaps a fresh set of eyes will spot the problem and point out what is probably blindingly obvious
