bits and pins
I'm trying to make something like this: http://www.instructables.com/id/Yet-Another-Daft-Punk-Coffee-TableDisplay/ What i do not understand is how are byte values related to arduino pins. This guy is using 8 bits, but how are they mapped to pinout ports?
He is using direct port access, using PORTB, you can read a bit more about direct port access here: http://hekilledmywire.wordpress.com/2011/02/23/direct-port-manipulation-using-the-digital-ports-tutorial-part-3/
Thank you, that helped. Now i'm clear what does PORTD do. However, PORTB remains mistery :)
So i have two more questions. What does pins 6 & 7 do with PORTD? What does PORTB = B00100000 activates? 13?
As i see it port map would look like this |PORTD | PORTB | |0 1 2 3 4 5 6 7| 8 9 10 11 12 13 __ __|
Yes, but
PORTB |= (1<<PINB5);
or
PORTB |= B00100000;
is usually better because it doesn’t clear the other pins.
EDIT. Sorry typo, should have been |=
Rob
Yes, but
PORTB != (1<<5);
or
Better still:
PORTB |= (1<<5);
Use
PORTB &= ~(1<<5);
to clear it.
I'm little bit confused now...I'm reading this: http://arduino.cc/en/Reference/BitwiseAnd It says: "So if we write PORTD = B00110001; we have made pins 2,3 & 7 HIGH. "
Arent' 0,4,5 HIGH?
Yes, that is wrong - maybe it was referring to an earlier processor's pins, and not Arduino pins.
Ok. Everything is much clearer now.
