Funny title huh? :o
I’m looking at ways to make my own bldc controller and found this link
http://elabz.com/bldc-motor-with-arduino-circuit-and-software/
I understand what he’s doing here and to me pwm looks like a good way, but what I would like some help with is understanding the “limitations” of the MCU.
So I know the ATmega328P has a clock speed of 16 mHz and a that it provide 8 bit PWM output.
So in this example how can I know that I stay within these boundaries and for example calculate what speed I would be able to output or maybe amount of steps…
And is there any other way a similar solution could be made with higher speeds or steps?
Driving a DVD drive spindle three-phase motor
This code was used for the stroboscope project
This example code is in the public domain. Based on several Arduino code samples
http://elabz.com/
// constants won't change. They're used here to
// set pin numbers:
const int buttonPin = 8;// the number of the direction pushbutton pin
const int ledPin = 7; // the number of the status LED pin (not the flash LED)
const int potPin = 0; // pot controls the RPM speed
const int potPinFlash = 1; // pot controls the flash speed
const int motorPin1 =9;
const int motorPin2 =10;
const int motorPin3 =11;
const int flashPin =12;
const int motorDelay=5; // together with pot controls the RPM
const int flashDelay=2; // controls duration of flash
const int frames=12; // has to be divisible by 3 in this version
const int serialDelay = 2000; //debug only
long serialLast =0; //debug only
// Variables will change:
boolean ledState = false; // the current state of the status LED output pin
int buttonState; // the current reading from the direction input pin
int potState; // the current reading from the RPM speed potentiometer
int potStateFlash; // the current reading from the flash rate potentiometer
int lastButtonState = LOW;
int debounceDelay = 50; // the debounce time; increase if the output flickers
boolean direct = true; // direction true=forward, false=backward
int pwmSin[] = {127,110,94,78,64,50,37,26,17,10,4,1,0,1,4,10,17,26,37,50,64,78,94,110,127,144,160,176,191,204,217,228,237,244,250,253,254,253,250,244,237,228,217,204,191,176,160,144,127
}; // array of PWM duty values for 8-bit timer - sine function
int pwmSin[]={511,444,379,315,256,200,150,106,68,39,17,4,0,4,17,39,68,106,150,200,256,315,379,444,511,578,643,707,767,822,872,916,954,983,1005,1018,1022,1018,1005,983,954,916,872,822,767,707,643,578,511
}; // array of PWM duty values for 10-bit timer - sine function
int increment;
int flashIncrement = 0;
int currentFlash=0;
int currentStepA=0;
int currentStepB=16;
int currentStepC=32;
// the following variables are long's because the time, measured in miliseconds,
// will quickly become a bigger number than can be stored in an int.
long lastDebounceTime = 0; // the last time the output pin was toggled
long motorDelayActual = 0; // the actual delay, based on pot value and motor delay set above
long flashDelayActual = 0;
long flashDelayPerCycle = 0;
long lastMotorDelayTime = 0;
long flashTime = 0; // how long has flash been ON
long flashTimeOFF = 0; // how long has flash been OFF
TCCR1B = TCCR1B & 0b11111000 | 0x01; // set PWM frequency @ 31250 Hz for Pins 9 and 10
TCCR2B = TCCR2B & 0b11111000 | 0x01; // set PWM frequency @ 31250 Hz for Pins 11 and 3 (3 not used)
// ICR1 = 255 ; // 8 bit resolution
ICR1 = 1023 ; // 10 bit resolution
pinMode(buttonPin, INPUT);
pinMode(potPin, INPUT);
pinMode(potPinFlash, INPUT);
pinMode(ledPin, OUTPUT);
pinMode(motorPin1, OUTPUT);
pinMode(motorPin2, OUTPUT);
pinMode(motorPin3, OUTPUT);
pinMode(flashPin, OUTPUT);
digitalWrite(flashPin, LOW);
// read the state of the switch into a local variable:
int reading = digitalRead(buttonPin);
// check to see if you just pressed the button
// (i.e. the input went from LOW to HIGH), and you've waited
// long enough since the last press to ignore any noise:
// If the switch changed, due to noise or pressing:
if (reading != lastButtonState) {
// reset the debouncing timer
lastDebounceTime = millis();
if ((millis() - lastDebounceTime) > debounceDelay) {
// whatever the reading is at, it's been there for longer
// than the debounce delay, so take it as the actual current state:
buttonState = reading;
direct = !direct;
ledState = !ledState;
lastButtonState = reading;
// set the LED using the state of the button:
digitalWrite(ledPin, ledState);
// save the reading. Next time through the loop,
// it'll be the lastButtonState:
potStateFlash = analogRead(potPinFlash);
potState = analogRead(potPin);
motorDelayActual = potState * motorDelay / 100;
// flashDelayActual = flashDelay+potStateFlash/200; // if we were controlling it with a POT
flashDelayActual = flashDelay;
move();
void move()
if((millis() - flashTime) > flashDelayActual)
digitalWrite(flashPin, HIGH);
if((millis() - lastMotorDelayTime) > motorDelayActual)
{ // delay time passed, move one step
if (direct==true)
increment = 1;
increment = -1;
currentStepA = currentStepA + increment;
if(currentStepA > 47) currentStepA = 0;
if(currentStepA<0) currentStepA =47;
currentStepB = currentStepB + increment;
if(currentStepB > 47) currentStepB = 0;
if(currentStepB<0) currentStepB =47;
currentStepC = currentStepC + increment;
if(currentStepC > 47) currentStepC = 0;
if(currentStepC<0) currentStepC =47;
lastMotorDelayTime = millis();
//flashDelayPerCycle = flashDelayPerCycle + flashDelayPerCycle;
currentFlash = currentFlash + 1;
if(currentFlash>24)
currentFlash=0;
flashTime = millis();
flashDelayActual = millis();
analogWrite(motorPin1, pwmSin[currentStepA]);
analogWrite(motorPin2, pwmSin[currentStepB]);
analogWrite(motorPin3, pwmSin[currentStepC]);
