Hey a question for those that are more familiar with c++ than i.
Im trying to convert this code and expand it so i can use 4 sensors instead of 1.
Currently the code is (works perfectly as is)…
unsigned char val1;
unsigned char val2;
//gnarly code to turn the int into two bytes
val1 = value &0xFF;
val2 = (value >> 8) &0xFF;
//send both bytes
Serial.print(val1, BYTE);
Serial.print(val2, BYTE);
and then in on the other end (openFrameWorks) it’s converted back to…
sensor_01 = ( (unsigned char)bytesReadString[1] << 8 | (unsigned char)bytesReadString[0] );
I found a really helpful post on this issue, but at my current level it is above me… (hopefully not for long =D )
Any help would be greatly appreciated, thanks!
