Bizarre wave with no input
I'm using an older Arduino Eleven (works the same as Uno), and I'm trying to get a sound input from a tablet. I'm using an AUX cable with an alligator clip on the tip, connecting it through a jumper wire to the analog pin 0, but even when nothing's connected to the cable on the non-Arduino end, I'm geting a wave going from 0 to 1023 that doesn't seem to change at all...
The code I'm using to test is:
int sound = 0;
sound = analogRead(0);
Serial.println(sound);
Can someone please tell me what I'm doing wrong? I apologise if this is in the wrong section. Thanks!
Probably, 50/60 Hz AC noise. Connect the input to ground and it will go away.
