Dear community,
can anyone explain to me what could possibly be the reason for this bizarre behavior in the sketch below?
If I enable the "Global" "char TemperatureTextC[6] = {0};" then the counter does NOT increment.
However, If I enable(declare?) it in the "local" loop, it does indeed increment.
I'm not a programmer and "just" a Diesel mechanic therefore my understanding of C++ is equivalent to an amoeba I guess :o (So is my programming skill)
Here's the code that does NOT work:
float Celcius = 55.55;
char TemperatureTextC[6] = {0}; // If LOCAL - does work
long counter = 0;
static unsigned long Timer1 = 0;
unsigned long Interval1 = 1000; // every 1 second(s)
if (millis() - Timer1 >= Interval1) {
Timer1 = millis();
counter = counter + 1;
Serial.println(counter);
//char TemperatureTextC[6] = {0}; // If GLOBAL - does not work
dtostrf(Celcius, 6, 2, &TemperatureTextC[0]);// dtostrf(val, width, precision, TemperatureTextC
And here the code that DOES work:
//char TemperatureTextC[6] = {0}; // If LOCAL - does work
long counter = 0;
Timer1 = millis();
Any insight is highly appreciated
(Solved)
