c:/users/balon/documents/arduinodata/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-3-20ed2b9/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: core\core.a(core_esp8266_main.cpp.o): in function do_global_ctors': C:\Users\balon\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.5.2\cores\esp8266/core_esp8266_main.cpp:149: undefined reference to
setup'
c:/users/balon/documents/arduinodata/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-3-20ed2b9/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: core\core.a(core_esp8266_main.cpp.o): in function loop_wrapper()': C:\Users\balon\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.5.2\cores\esp8266/core_esp8266_main.cpp:117: undefined reference to
setup'
collect2.exe: error: ld returned 1 exit status
exit status 1
Błąd kompilacji dla płytki Generic ESP8266 Module.
#define BLYNK_PRINT Serial
#include <ESP8266WiFi.h>
#include <BlynkSimpleEsp8266.h>
// You should get Auth Token in the Blynk App.
// Go to the Project Settings (nut icon).
char auth[] = "******";
// Your WiFi credentials.
// Set password to "" for open networks.
char ssid[] = "";
char pass[] = "*";
int prawy = V0;
int lewy = V1;
BLYNK_WRITE(V0)
int pinValue = param.asInt(); // assigning incoming value from pin V1 to a variable
// You can also use:
// String i = param.asStr();
// double d = param.asDouble();
digitalWrite(16, pinValue);
Serial.print("V0 Slider value is: ");
Serial.println(pinValue);
BLYNK_WRITE(V1)
digitalWrite(5, pinValue);
Serial.print("V1 Slider value is: ");
void stetup() // Debug console
Blynk.begin(auth, ssid, pass);
Blynk.run();
setup'
setup'
exit status 1
"void setup()"
@nargilami I have merged your two topics and I note that you did not follow the advice given in How to get the best out of this forum as requested
Please use code tags when posting code in future
