Hello there,
I am quite new to Arduino, but I really need some help. I started with a few tutorials and got the starter kit. Now, I am working on the default 'Hello World' on an LC Display, but the Screen is just empty. I looked over my wires several times, but I cannot find any mistakes.
What am I doing wrong? Please help quickly
#include <LiquidCrystal.h>
const int rs = 7, en = 8, d4 = 9, d5 = 10, d6 = 11, d7 = 12;
LiquidCrystal lcd(d7, d6, d5, d4, en, rs);
lcd.begin(16, 2);
// Print a message to the LCD.
lcd.print("hello, world!");
lcd.setCursor(0, 1);
lcd.print(millis() / 1000);
Here is a picture of my setting:
Thanks for the good photo.
Look at the blue line on the breadboard. There is a gap between row 30 and 32.
Join each half of the broken blue line with a jumper.
Join each half of the broken red line with a jumper.
Or just move the red and black jumper wires for the pot to row 32 on the blue and red bus lines.
David.
Hi David,
Thanks a lot for your quick answer. I totally understood it, but neither of your suggestions solved my problem, even though it was one big mistake I made.
Is it possible that there is some problem with my potentiometer or the connection to it?
Forget about the potentiometer.
Just connect pin #3 (VO) to GND. e.g. pin#1
If that does not work, test every jumper wire by replacing pin#16 jumper wire.
David.
Oops. Your constructor was:
It should be as shown in Libaries documentation:
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
Yes, that helped... One jumper was just broken!
