Blank LCD display
Hey!
I'm using a 16x2 LCD display (Basic 16x2 Character LCD - RGB Backlight 5V - LCD-10862 - SparkFun Electronics) with a serial enabled backpack (https://www.sparkfun.com/products/258).
However, it doesn't work, and regardless how much I try, the display stays totally blank.
Shouldn't I be able to see black squares if it got power?
I've tried to change the contrast, but It's still blank..
Current is flowing trough the backpack GND/5V pins as well, so I'm afraid that there's something wrong with the display.
Help is appreciated !
Is your backlight working? I know that some displays, specifically the ones with white characters on a blue background, are virtually impossible to use without the backlight. I don't know about this one, but that could be your problem.
How did you deal with the fact that the LCD has 18 pins but the serial backpack is designed for a 16 pin display?
Don
No, the backlight doesn't work, which I think is strange since It should lit if the display has power.
Maybe the LED is turned off if not enabling it trough programming.
The display got 18 pins because of the 2 extra LED colours, since it's RGB.
The backpack is only connected to the red LED, which means that you have to connect the other LED's separately if you need them.
My display is still dead tough.. :confused:
You should have +5 Volts to the Red, Blue or Green (16,17,18) anode for the back light.
Pin 15 or the cathode (K) should go to a resistor (Try 220 ohm).
The other end of the resistor goes to 0 Volts.
If Red is not working try one of the other 2 colours.
The thing is that nothing on the display seems to work.. and neither do the LED's.
Characters on the display should be visible without backlight as well.
It's like it's not receiving any power from the backpack even tough I measured the current from the backpack pins to 5v.
Would you show us a picture of your wiring?
I strongly dispute that.
In an earlier discussion, liudr indicated that s/he has a sparkfun white/blue lcd that remains readable in direct sunlight, without the backlight. and s/he has a picture to prove it.
While liudr hasn't provided the picture yet, I take his words over yours.
dhenry:
While liudr hasn’t provided the picture yet, I take his words over yours.
Perhaps you should go back and read that post again → http://arduino.cc/forum/index.php/topic,125666.msg944902.html#msg944902
Don’t forget to scroll down a bit to this part → http://arduino.cc/forum/index.php/topic,125666.msg952237.html#msg952237
Dr. Liu is a ‘he’.
Don
In that post, liudr said, re white/blue display:
But if I turned off the back light, I can see outdoors.
liudr wins and you lose.
I guess you forgot to scroll down to the part where he said "I got my first and only white on blue from adafruit. It was slow and needs back light in well-lit indoor environmenit "
Here’s a quick and dirty comparison using a project I found in my drawer. The ancient 16x2 display has no backlight. The other three photos show the 20x4 display with no power to the backlight under my normal (bright) desk lighting and with simulated sunlight (the only kind we have here in much of the time) from a Maglite. The last picture is with the backlight powered.
The un-backlit 20x4 display seems to show up better in the pictures than it normally appears.
Don
I guess you didn't realize that this is a conversation about white/blue lcd in OUTDOOR environmenit, not INDOOR environmenit.
What he said about INDOOR environmenit is probably irrelevant to this discussion.
Sounds like liudr wins and you lose.
Here's a quick and dirty comparison
I guess there is this possibility that liudr has superman vision.
But without a picture of his white/blue lcd outdoor, we can never tell.
No it is not. The original poster did not mention anything about his environment.
This forum really is not about who wins and who looses, it is about helping people get their projects working.
The original poster was concerned that the display on his LCD appeared to be totally blank. I looked at the description of his display and saw that not only did it have three backlight LEDs (with two extra terminals for the two extra LEDs) but that it also appeared to be one of those displays that is difficult to read when the backlight is off.
I had a similar experience when I first encountered one of these types of LCDs. When I first used my backlit 20x4 I too thought it was dead but I had the advantage of knowing that my circuit and code were correct since I had merely replaced one display with the other just as I did in the series of photographs last night.
The original poster asked for help with a display that appeared to be dead and I suspected that the backlight, or more specifically the lack of a backlight, might also be his problem. You might dispute the fact that these displays are virtually impossible to use without the backlight functioning but that has not been my experience with my display.
The original poster has indicated that his backlight is not functioning and I think it would be best to pursue fixing that problem since I don't think that he wants to be restricted to operating his display only in direct sunlight.
Don
Let me just bring back some memory for you.
and I followed up to say that liudr's experience would dispute that, as he said:
I never suggested if such a display would be readable (or not) indoors with or without backlight. I only focused on outdoor use without a backlight, as liudr did.
Sounds like liudr prevails once again.
dhenry:
This isn’t some sort of bizarre game, with winners and losers.
We are trying to help resolve problems here. We “win” if we help the person who asked the question, who also wins if the suggestions work. If not, we need to explore other options.
The original post is a bit vague:
However, it doesn’t work, and regardless how much I try, the display stays totally blank.
Shouldn’t I be able to see black squares if it got power?
It isn’t clear if the backlight is on or not, from that. Also, wiring errors (eg. to the contrast pin) could account for what you are seeing.
The backlight does NOT work, and neither does the rest of the display.
When it comes to the wiring error, it seems unlikley since the backpack pins are connected to the right spots into the display from 1 to 16.
It seems more likely that the display itself (for some reason), doesn’t recieve power even tough i measured the voltage on the GND/5V pins from the backpack to 5v.
If if the display had power, the backlight would work, it would show black squares instead of characters, and the green and blue backlight on pin 17 and 18 would work, since they’re grounded trough the backpack.
I might try to desolder the backpack from the display and see if it works with normal wires. It did work with normal wires (without the backpack) for a couple of weeks ago, but I didn’t test it after that, or before soldering on the backpack.
The displays I have, have totally different wires to the backlight and the display. So you might have no backlight, but the LCD shows stuff (if you can see it) and vice-versa. It doesn't necessarily show black squares. Often enough I have seen "nothing" until I got the contrast right. So it could be multiple things.
Back in reply #5, just before we were sidetracked, LarryD recommended that you post a picture. That remains a good idea because it will help us determine if you really did everything as you intended. For example, you are connecting an 18-pin device to a 16-pin backpack. This should work as long as you really did implement pins 1 <–> 16 as intended and not 3 <–> 18 and this is a place where another set of eyes could help.
I was going to suggest this but it is a lot of work if you don’t have decent de-soldering equipment. It would be a good idea for you to check your soldering for cold joints, bridges, etc.
If if the display had power, the backlight would work, it would show black squares instead of characters, …
Not necessarily. The backlight is turned on by software and since it is off the black squares may be difficult or impossible to see (I think more people will agree with me about this, including liudr, than will disagree).
… and the green and blue backlight on pin 17 and 18 would work, since they’re grounded trough the backpack.
I don’t see how this could be the case since, the way I am picturing things, pins 17 and 18 are not connected to the backpack. Also, they would have to be powered, not grounded, since they are connected to the LED anodes.
Don
