All fixed now, thanks for your help. Turns out Digital Pin 3 wasn't working correctly. A new board and an upload of MCUFRIEND_kbv library and it's working well now.
I have exactly the same product littlebigcj. The photo is attached and link to product is;
When I run the graphics test sketch, the serial monitor reads;
TFT LCD test
Using Adafruit 2.4" TFT Breakout Board Pinout
TFT size is 240x320
Unknown LCD driver chip: 0
If using the Adafruit 2.4" TFT Arduino shield, the line:
#define USE_ADAFRUIT_SHIELD_PINOUT
should appear in the library header (Adafruit_TFT.h).
If using the breakout board, it should NOT be #defined!
Also if using the breakout, double-check that all wiring
matches the tutorial.
The size and resolution is wrong and says "Unknown LCD driver chip"
I also tried to work on Nextion Editor and upload it says;
Connection failed Forced interrupt!
When I run LCD_ID_readreg.ino, serial screen reads;
⸮Read Registers on MCUFRIEND UNO shield
controllers either read as single 16-bit
e.g. the ID is at readReg(0)
or as a sequence of 8-bit values
in special locations (first is dummy)
reg(0x0000) 00 00 ID: ILI9320, ILI9325, ILI9335, ...
reg(0x0004) 00 00 00 00 Manufacturer ID
reg(0x0009) 00 00 61 00 00 Status Register
reg(0x000A) 08 08 Get Power Mode
reg(0x000C) 66 66 Get Pixel Format
reg(0x0061) 00 00 RDID1 HX8347-G
reg(0x0062) 00 00 RDID2 HX8347-G
reg(0x0063) 00 00 RDID3 HX8347-G
reg(0x0064) 00 00 RDID1 HX8347-A
reg(0x0065) 00 00 RDID2 HX8347-A
reg(0x0066) 00 00 RDID3 HX8347-A
reg(0x0067) 00 00 RDID Himax HX8347-A
reg(0x0070) 00 00 Panel Himax HX8347-A
reg(0x00A1) 00 00 00 00 00 RD_DDB SSD1963
reg(0x00B0) 00 00 RGB Interface Signal Control
reg(0x00B4) 00 00 Inversion Control
reg(0x00B6) 00 00 00 00 00 Display Control
reg(0x00B7) 00 00 Entry Mode Set
reg(0x00BF) 00 02 04 94 81 FF ILI9481, HX8357-B
reg(0x00C0) 00 10 3B 00 02 11 00 00 00 Panel Control
reg(0x00C8) 00 00 44 06 11 44 55 0A 08 17 33 77 11 GAMMA
reg(0x00CC) 00 00 Panel Control
reg(0x00D0) 00 00 43 Power Control
reg(0x00D2) 00 01 22 00 00 NVM Read
reg(0x00D3) 00 01 22 00 ILI9341, ILI9488
reg(0x00D4) 00 01 22 00 Novatek ID
reg(0x00DA) 00 00 RDID1
reg(0x00DB) 00 00 RDID2
reg(0x00DC) 00 00 RDID3
reg(0x00E0) 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 GAMMA-P
reg(0x00E1) 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 GAMMA-N
reg(0x00EF) 00 00 00 00 00 00 ILI9327
reg(0x00F2) 00 00 00 00 00 00 00 00 00 00 00 00 Adjust Control 2
reg(0x00F6) 00 00 00 00 Interface Control
