Blank screen on Arduino IDE
Getting blank screen on Arduino IDE .
Was having the issue with previous version (not sure 2.XX ,it was 7 months old)and updated to latest (2.3.3) hoping to fix the issue, but it is the same. Saw similar threads on forum but no solution.
Warning: PowerShell detected that you might be using a screen reader and has disabled PSReadLine for compatibility purposes. If you want to re-enable it, run 'Import-Module PSReadLine'.
PS C:\Program Files\Arduino IDE> & ".\Arduino IDE"
Arduino IDE 2.3.3
Checking for frontend application configuration customizations. Module path: C:\Program Files\Arduino IDE\resources\app\lib\backend\electron-main.js, destination 'package.json': C:\Program Files\Arduino IDE\resources\app\package.json
Setting 'theia.frontend.config.appVersion' application configuration value to: "2.3.3" (type of string)
Setting 'theia.frontend.config.cliVersion' application configuration value to: "1.0.4" (type of string)
Setting 'theia.frontend.config.buildDate' application configuration value to: "2024-09-25T09:41:18.242Z" (type of string)
Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{}},"defaultLocale":"","validatePreferencesSchema":false,"preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.3.3","cliVersion":"1.0.4","buildDate":"2024-09-25T09:41:18.242Z"}
Starting backend process. PID: 5696
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///c%3A/Users/john/.arduinoIDE'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2024-10-21T01:27:59.568Z root INFO Backend Object.initialize: 40.1 ms [Finished 1.978 s after backend start]
2024-10-21T01:27:59.682Z root INFO Backend Object.configure: 44.5 ms [Finished 1.984 s after backend start]
2024-10-21T01:27:59.682Z root INFO Backend a.onStart: 9.4 ms [Finished 1.984 s after backend start]
2024-10-21T01:27:59.694Z root INFO Backend a.configure: 0.5 ms [Finished 2.042 s after backend start]
2024-10-21T01:27:59.695Z root INFO Backend d.onStart: 0.3 ms [Finished 2.042 s after backend start]
2024-10-21T01:27:59.697Z root INFO Backend d.configure: 0.2 ms [Finished 2.042 s after backend start]
2024-10-21T01:27:59.699Z root WARN Backend d.initialize took longer than the expected maximum 50 milliseconds: 57.8 ms [Finished 2.043 s after backend start]
2024-10-21T01:27:59.700Z root INFO Backend c.onStart: 0.5 ms [Finished 2.043 s after backend start]
2024-10-21T01:27:59.701Z root WARN Backend s.configure took longer than the expected maximum 50 milliseconds: 114.6 ms [Finished 2.157 s after backend start]
2024-10-21T01:27:59.731Z config INFO >>> Initializing CLI configuration...
2024-10-21T01:27:59.731Z root INFO Backend c.initialize: 1.2 ms [Finished 2.168 s after backend start]
2024-10-21T01:27:59.732Z root INFO Backend x.onStart: 12.1 ms [Finished 2.170 s after backend start]
2024-10-21T01:27:59.733Z config INFO Loading CLI configuration from c:\Users\john\.arduinoIDE\arduino-cli.yaml...
2024-10-21T01:27:59.734Z daemon INFO Starting daemon from C:\Program Files\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-10-21T01:27:59.734Z root INFO Backend s.initialize: 0.8 ms [Finished 2.171 s after backend start]
2024-10-21T01:27:59.734Z root INFO Backend w.onStart: 3.0 ms [Finished 2.174 s after backend start]
2024-10-21T01:27:59.734Z root INFO Backend r.configure: 4.7 ms [Finished 2.174 s after backend start]
2024-10-21T01:27:59.735Z discovery-log INFO start
2024-10-21T01:27:59.735Z discovery-log INFO start new deferred
2024-10-21T01:27:59.735Z root INFO Backend d.initialize: 1.3 ms [Finished 2.176 s after backend start]
2024-10-21T01:27:59.735Z root INFO Backend y.onStart: 31.1 ms [Finished 2.206 s after backend start]
2024-10-21T01:27:59.735Z root INFO Backend r.configure: 30.2 ms [Finished 2.206 s after backend start]
2024-10-21T01:27:59.735Z root INFO Backend s.onStart: 0.9 ms [Finished 2.209 s after backend start]
2024-10-21T01:27:59.735Z root INFO Backend h.configure: 0.8 ms [Finished 2.209 s after backend start]
2024-10-21T01:27:59.735Z root INFO Backend a.configure: 0.2 ms [Finished 2.210 s after backend start]
2024-10-21T01:27:59.735Z root INFO Backend l.configure: 0.1 ms [Finished 2.210 s after backend start]
2024-10-21T01:27:59.742Z root INFO Theia app listening on http://127.0.0.1:50220.
2024-10-21T01:27:59.742Z root INFO Finished starting backend application: 7.0 ms [Finished 2.216 s after backend start]
2024-10-21T01:27:59.743Z root WARN The local plugin referenced by local-dir:/c%3A/Users/john/.arduinoIDE/plugins does not exist.
2024-10-21T01:27:59.744Z root WARN The local plugin referenced by local-dir:/c%3A/Users/john/.arduinoIDE/extensions does not exist.
2024-10-21T01:27:59.746Z root WARN The local plugin referenced by local-dir:C:\Users\john\.arduinoIDE\plugins does not exist.
2024-10-21T01:27:59.766Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":[]},"build_cache":{"compilations_before_purge":10,"ttl":"720h0m0s"},"daemon":{"port":"50051"},"directories":{"data":"C:\\Users\\john\\AppData\\Local\\Arduino15","downloads":"C:\\Users\\john\\AppData\\Local\\Arduino15\\staging","user":"C:\\Users\\john\\Documents\\Arduino"},"library":{"enable_unsafe_install":false},"logging":{"file":"","format":"text","level":"info"},"metrics":{"addr":":9090","enabled":true},"output":{"no_color":false},"sketch":{"always_export_binaries":false},"updater":{"enable_notification":true}}
2024-10-21T01:27:59.766Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2024-10-21T01:27:59.766Z config INFO Loaded the CLI configuration.
2024-10-21T01:28:02.360Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/john/AppData/Local/Arduino15","sketchDirUri":"file:///c%3A/Users/john/Documents/Arduino","additionalUrls":[],"network":"none","locale":"en"}
2024-10-21T01:28:02.360Z config INFO Validating the CLI configuration...
2024-10-21T01:28:02.380Z config INFO The CLI config is valid.
2024-10-21T01:28:02.381Z config INFO <<< Initialized the CLI configuration.
2024-10-21T01:28:02.602Z root INFO Resolve plugins list: 2869.1 ms [Finished 5.076 s after backend start]
Restoring workspace roots: c:\Users\john\Documents\Arduino\Proyectos\EspTuya\EspTuya
isTempSketch: false. Input was c:\Users\john\Documents\Arduino\Proyectos\EspTuya\EspTuya\Commandes.ino
2024-10-21T01:28:06.913Z daemon INFO time="2024-10-20T22:28:06-03:00" level=info msg="arduino-cli version 1.0.4"
2024-10-21T01:28:07.099Z daemon INFO time="2024-10-20T22:28:06-03:00" level=info msg="Using config file: c:\\Users\\john\\.arduinoIDE\\arduino-cli.yaml"
time="2024-10-20T22:28:06-03:00" level=info msg="Executing `arduino-cli daemon`"
Daemon is now listening on 127.0.0.1:50226
{"IP":"127.0.0.1","Port":"50226"}
2024-10-21T01:28:07.099Z daemon INFO Daemon is running.
2024-10-21T01:28:08.702Z daemon INFO time="2024-10-20T22:28:08-03:00" level=info msg="Checking signature" index="C:\\Users\\john\\AppData\\Local\\Arduino15\\package_index.json" signatureFile="C:\\Users\\john\\AppData\\Local\\Arduino15\\package_index.json.sig" trusted=true
2024-10-21T01:28:08.704Z daemon INFO time="2024-10-20T22:28:08-03:00" level=info msg="Loading hardware from: C:\\Users\\john\\AppData\\Local\\Arduino15\\packages"
2024-10-21T01:28:08.706Z daemon INFO time="2024-10-20T22:28:08-03:00" level=info msg="Loading package arduino from: C:\\Users\\john\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware"
2024-10-21T01:28:08.783Z daemon INFO time="2024-10-20T22:28:08-03:00" level=info msg="Missing signature file" index="C:\\Users\\john\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\installed.json"
2024-10-21T01:28:09.017Z daemon INFO time="2024-10-20T22:28:09-03:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
2024-10-21T01:28:09.017Z daemon INFO time="2024-10-20T22:28:09-03:00" level=info msg="Loaded platform" platform="arduino:avr@1.8.6"
time="2024-10-20T22:28:09-03:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\john\\AppData\\Local\\Arduino15\\packages\\arduino\\tools"
time="2024-10-20T22:28:09-03:00" level=info msg="Loading tools from dir: C:\\Users\\john\\AppData\\Local\\Arduino15\\packages\\arduino\\tools"
2024-10-21T01:28:09.019Z daemon INFO time="2024-10-20T22:28:09-03:00" level=info msg="Loaded tool" tool="arduino:arduinoOTA@1.3.0"
2024-10-21T01:28:09.019Z daemon INFO time="2024-10-20T22:28:09-03:00" level=info msg="Loaded tool" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
2024-10-21T01:28:09.020Z daemon INFO time="2024-10-20T22:28:09-03:00" level=info msg="Loaded tool" tool="arduino:avrdude@6.3.0-arduino17"
2024-10-21T01:28:09.020Z daemon INFO time="2024-10-20T22:28:09-03:00" level=info msg="Loaded tool" tool="arduino:dfu-util@0.11.0-arduino5"
2024-10-21T01:28:09.021Z daemon INFO time="2024-10-20T22:28:09-03:00" level=info msg="Loading package builtin from: C:\\Users\\john\\AppData\\Local\\Arduino15\\packages\\builtin"
2024-10-21T01:28:09.022Z daemon INFO time="2024-10-20T22:28:09-03:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\john\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
time="2024-10-20T22:28:09-03:00" level=info msg="Loading tools from dir: C:\\Users\\john\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
2024-10-21T01:31:03.404Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 3974.5 ms [Finished 169.722 s after frontend start]
2024-10-21T01:31:03.817Z root WARN A command editor.action.toggleStickyScroll is already registered.
2024-10-21T01:31:03.817Z root WARN Frontend commands.onStart took longer than the expected maximum 100 milliseconds: 658.0 ms [Finished 170.381 s after frontend start]
2024-10-21T01:31:03.888Z root WARN Frontend keybindings.onStart took longer than the expected maximum 100 milliseconds: 466.7 ms [Finished 170.849 s after frontend start]
2024-10-21T01:31:04.215Z root WARN Frontend h.onStart took longer than the expected maximum 100 milliseconds: 234.7 ms [Finished 171.101 s after frontend start]
2024-10-21T01:31:04.300Z sketches-service WARN Warning! The request sketch path was different than the response sketch path from the CLI. This could be a potential bug. Request: <c:\Users\john\Documents\Arduino\Proyectos\EspTuya\EspTuya\Commandes.ino>, response: <c:\Users\john\Documents\Arduino\Proyectos\EspTuya\EspTuya>.
2024-10-21T01:31:04.505Z root WARN Frontend u.onStart took longer than the expected maximum 100 milliseconds: 249.3 ms [Finished 171.482 s after frontend start]
2024-10-21T01:31:04.966Z root WARN Frontend D.onStart took longer than the expected maximum 100 milliseconds: 453.2 ms [Finished 171.941 s after frontend start]
2024-10-21T01:31:06.011Z root WARN Frontend c.onStart took longer than the expected maximum 100 milliseconds: 1042.8 ms [Finished 172.987 s after frontend start]
2024-10-21T01:31:06.211Z root WARN Frontend p.onStart took longer than the expected maximum 100 milliseconds: 120.4 ms [Finished 173.116 s after frontend start]
2024-10-21T01:31:08.645Z root INFO [hosted-plugin: 6576] PLUGIN_HOST(6576) starting instance
2024-10-21T01:31:09.127Z root INFO Start frontend contributions: 8525.8 ms [Finished 173.127 s after frontend start]
2024-10-21T01:31:09.131Z root INFO Changed application state from 'init' to 'started_contributions'.
2024-10-21T01:31:09.490Z root INFO [e1668d56-b39a-4c9f-ae87-975566e25313] Waiting for backend deployment: 2739.8 ms [Finished 175.732 s after frontend start]
2024-10-21T01:31:14.703Z root INFO [e1668d56-b39a-4c9f-ae87-975566e25313] Sync of 23 plugins: 5647.4 ms [Finished 181.490 s after frontend start]
2024-10-21T01:31:42.912Z root INFO Changed application state from 'started_contributions' to 'attached_shell'.
2024-10-21T01:31:42.913Z root INFO >>> Restoring the layout state...
2024-10-21T01:31:42.919Z root INFO ------- SERIALIZED LAYOUT DATA -------
2024-10-21T01:31:42.920Z root INFO {"version":5,"mainPanel":{"main":{"type":"tab-area","widgets":[{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///c%3A/Users/john/Documents/Arduino/Proyectos/EspTuya/EspTuya/EspTuya.ino"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":true,\"selectionStart\":{\"lineNumber\":7,\"column\":68},\"position\":{\"lineNumber\":6,\"column\":68}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":1,\"column\":1},\"firstPositionDeltaTop\":0},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":333,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///c%3A/Users/john/Documents/Arduino/Proyectos/EspTuya/EspTuya/Commandes.ino"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":1,\"column\":1},\"position\":{\"lineNumber\":1,\"column\":1}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":1,\"column\":1},\"firstPositionDeltaTop\":0},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":325,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///c%3A/Users/john/Documents/Arduino/Proyectos/EspTuya/EspTuya/Crypto.ino"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":1,\"column\":1},\"position\":{\"lineNumber\":1,\"column\":1}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":1,\"column\":1},\"firstPositionDeltaTop\":0},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":179,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///c%3A/Users/john/Documents/Arduino/Proyectos/EspTuya/EspTuya/Functions.ino"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":1,\"column\":1},\"position\":{\"lineNumber\":1,\"column\":1}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":1,\"column\":1},\"firstPositionDeltaTop\":0},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":392,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///c%3A/Users/john/Documents/Arduino/Proyectos/EspTuya/EspTuya/GetKey.ino"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":1,\"column\":1},\"position\":{\"lineNumber\":1,\"column\":1}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":1,\"column\":1},\"firstPositionDeltaTop\":0},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":176,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"}],"currentIndex":0}},"mainPanelPinned":[false,false,false,false,false],"bottomPanel":{"config":{"main":{"type":"tab-area","widgets":[{"constructionOptions":{"factoryId":"serial-monitor"}}],"currentIndex":0}},"pinned":[false],"size":79,"expanded":true},"leftPanel":{"type":"sidepanel","items":[{"widget":{"constructionOptions":{"factoryId":"arduino-sketchbook-widget"}},"rank":1,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"boards-list-widget"}},"rank":2,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"library-list-widget"}},"rank":3,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"debug"},"innerWidgetState":"{\"parts\":[{\"partId\":\"debug:threads:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:threads\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:frames:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:frames\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:variables:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:variables\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:watch:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:watch\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:breakpoints:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:breakpoints\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"plugin-view:cortex-debug.peripherals\",\"collapsed\":true,\"hidden\":true,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"plugin-view\",\"options\":{\"id\":\"plugin-view:cortex-debug.peripherals\",\"viewId\":\"cortex-debug.peripherals\"}},\"innerWidgetState\":\"{\\\"label\\\":\\\"Cortex Peripherals\\\",\\\"widgets\\\":[],\\\"suppressUpdateViewVisibility\\\":false,\\\"currentViewContainerId\\\":\\\"debug\\\"}\"}},{\"partId\":\"plugin-view:cortex-debug.registers\",\"collapsed\":true,\"hidden\":true,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"plugin-view\",\"options\":{\"id\":\"plugin-view:cortex-debug.registers\",\"viewId\":\"cortex-debug.registers\"}},\"innerWidgetState\":\"{\\\"label\\\":\\\"Cortex Registers\\\",\\\"widgets\\\":[],\\\"suppressUpdateViewVisibility\\\":false,\\\"currentViewContainerId\\\":\\\"debug\\\"}\"}}],\"title\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}}"},"rank":4,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"search-view-container"},"innerWidgetState":"{\"parts\":[{\"partId\":\"search-in-workspace\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"search-view-container\",\"originalContainerTitle\":{\"label\":\"Search\",\"iconClass\":\"codicon codicon-search\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"search-in-workspace\"},\"innerWidgetState\":\"{\\\"matchCaseState\\\":{\\\"className\\\":\\\"codicon codicon-case-sensitive\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Match Case\\\"},\\\"wholeWordState\\\":{\\\"className\\\":\\\"codicon codicon-whole-word\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Match Whole Word\\\"},\\\"regExpState\\\":{\\\"className\\\":\\\"codicon codicon-regex\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Use Regular Expression\\\"},\\\"includeIgnoredState\\\":{\\\"className\\\":\\\"codicon codicon-eye\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Include Ignored Files\\\"},\\\"showSearchDetails\\\":false,\\\"searchInWorkspaceOptions\\\":{\\\"matchCase\\\":false,\\\"matchWholeWord\\\":false,\\\"useRegExp\\\":false,\\\"includeIgnored\\\":false,\\\"include\\\":[],\\\"exclude\\\":[],\\\"maxResults\\\":2000},\\\"searchTerm\\\":\\\"\\\",\\\"replaceTerm\\\":\\\"\\\",\\\"showReplaceField\\\":false,\\\"searchHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"replaceHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"includeHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"excludeHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0}}\"}}],\"title\":{\"label\":\"Search\",\"iconClass\":\"fa fa-arduino-search\",\"closeable\":true}}"},"rank":5,"expanded":false,"pinned":false}]},"rightPanel":{"type":"sidepanel","items":[]},"activeWidgetId":"code-editor-opener:file:///c%3A/Users/john/Documents/Arduino/Proyectos/EspTuya/EspTuya/EspTuya.ino:0"}
2024-10-21T01:31:42.921Z root INFO ------- END SERIALIZED LAYOUT DATA -------
2024-10-21T01:32:03.029Z root INFO <<< The layout has been successfully restored.
2024-10-21T01:32:03.539Z root INFO Initialize the workbench layout: 20601.3 ms [Finished 230.017 s after frontend start]
2024-10-21T01:32:03.548Z root INFO Changed application state from 'attached_shell' to 'initialized_layout'.
2024-10-21T01:32:03.548Z root INFO [e1668d56-b39a-4c9f-ae87-975566e25313] Loading plugin contributions
2024-10-21T01:32:03.551Z root INFO [e1668d56-b39a-4c9f-ae87-975566e25313] Load contributions of 23 plugins: 501.8 ms [Finished 230.521 s after frontend start]
2024-10-21T01:32:08.126Z root WARN 'cpp' language is remapped from 'source.cpp.embedded.macro' to 'source.cpp' scope
2024-10-21T01:32:08.126Z root WARN a registered grammar configuration for 'cpp' language is overridden
2024-10-21T01:32:10.810Z root INFO Frontend application start: 68099.0 ms [Finished 253.283 s after backend start]
Checking for update
Update for version 2.3.3 is not available (latest version: 2.3.3, downgrade is allowed).
2024-10-21T01:32:21.659Z root INFO Replace loading indicator with ready workbench UI (animation): 5120.3 ms [Finished 235.653 s after frontend start]
2024-10-21T01:32:21.659Z root INFO Changed application state from 'initialized_layout' to 'ready'.
2024-10-21T01:32:21.659Z root WARN Linked preference "workbench.colorCustomizations" not found.
2024-10-21T01:32:23.422Z daemon INFO time="2024-10-20T22:32:23-03:00" level=info msg="Updating index" url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
2024-10-21T01:32:23.717Z daemon INFO time="2024-10-20T22:32:23-03:00" level=info msg="Starting download" url="https://downloads.arduino.cc/libraries/library_index.tar.bz2"
2024-10-21T01:32:23.749Z root INFO core-client-provider [library-index] Downloading index: library_index.tar.bz2
2024-10-21T01:32:23.769Z daemon INFO time="2024-10-20T22:32:23-03:00" level=info msg="Starting download" url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
2024-10-21T01:32:23.771Z root INFO core-client-provider [platform-index] Downloading index: package_index.tar.bz2
2024-10-21T01:32:25.390Z root ERROR ---- !!!SLOW!!! DURATION: search took 3733.752 ms. Args: [{"type":"Updatable"}] ----
2024-10-21T01:32:25.640Z daemon INFO time="2024-10-20T22:32:25-03:00" level=info msg="Starting monitor process" monitor=serial-monitor
2024-10-21T01:32:27.161Z daemon INFO time="2024-10-20T22:32:27-03:00" level=info msg="Tool required for debug" tool="esp32:esp-x32@2302"
2024-10-21T01:32:27.161Z daemon INFO time="2024-10-20T22:32:27-03:00" level=info msg="Tool required for debug" tool="esp32:openocd-esp32@v0.12.0-esp32-20240318"
time="2024-10-20T22:32:27-03:00" level=info msg="Tool required for debug" tool="esp8266:mklittlefs@3.1.0-gcc10.3-e5f9fec"
time="2024-10-20T22:32:27-03:00" level=info msg="Tool required for debug" tool="builtin:mdns-discovery@1.0.9"
time="2024-10-20T22:32:27-03:00" level=info msg="Tool required for debug" tool="esp32:riscv32-esp-elf-gcc@gcc8_4_0-esp-2021r2-patch3"
time="2024-10-20T22:32:27-03:00" level=info msg="Tool required for debug" tool="esp32:esp-rv32@2302"
time="2024-10-20T22:32:27-03:00" level=info msg="Tool required for debug" tool="esp32:esp32-arduino-libs@idf-release_v5.1-b6b4727c58"
time="2024-10-20T22:32:27-03:00" level=info msg="Tool required for debug" tool="esp32:xtensa-esp32s2-elf-gcc@gcc8_4_0-esp-2021r2-patch3"
2024-10-21T01:32:27.162Z daemon INFO time="2024-10-20T22:32:27-03:00" level=info msg="Tool required for debug" tool="builtin:ctags@5.8-arduino11"
time="2024-10-20T22:32:27-03:00" level=info msg="Tool required for debug" tool="builtin:serial-discovery@1.4.1"
2024-10-21T01:32:27.248Z daemon INFO time="2024-10-20T22:32:27-03:00" level=info msg="Tool required for debug" tool="arduino:dfu-util@0.11.0-arduino5"
2024-10-21T01:32:27.249Z daemon INFO time="2024-10-20T22:32:27-03:00" level=info msg="Tool required for debug" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
time="2024-10-20T22:32:27-03:00" level=info msg="Tool required for debug" tool="arduino:avrdude@6.3.0-arduino17"
2024-10-21T01:32:27.249Z daemon INFO time="2024-10-20T22:32:27-03:00" level=info msg="Tool required for debug" tool="esp32:esptool_py@4.6"
time="2024-10-20T22:32:27-03:00" level=info msg="Tool required for debug" tool="esp8266:mkspiffs@3.1.0-gcc10.3-e5f9fec"
2024-10-21T01:32:27.249Z daemon INFO time="2024-10-20T22:32:27-03:00" level=info msg="Tool required for debug" tool="esp32:xtensa-esp32s3-elf-gcc@gcc8_4_0-esp-2021r2-patch3"
2024-10-21T01:32:27.250Z daemon INFO time="2024-10-20T22:32:27-03:00" level=info msg="Tool required for debug" tool="esp32:esp-xs2@2302"
2024-10-21T01:32:27.251Z daemon INFO time="2024-10-20T22:32:27-03:00" level=info msg="Tool required for debug" tool="esp8266:xtensa-lx106-elf-gcc@3.1.0-gcc10.3-e5f9fec"
2024-10-21T01:33:12.057Z monitor-service INFO No port configuration changes have been detected. No need to send configure commands to the running monitor serial:COM8.
[9788:1020/223312.397:ERROR:raster_implementation.cc(320)] Failed to serialize op in 16777152 bytes.
2024-10-21T01:33:12.457Z root INFO [hosted-plugin: 6576] PLUGIN_HOST(6576): PluginManagerExtImpl/loadPlugin(C:\Program Files\Arduino IDE\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\jsonMain)
2024-10-21T01:33:17.053Z sketches-service WARN Mismatching sketch file <Crypto.ino> and sketch folder name <EspTuya>. Skipping
2024-10-21T01:33:17.053Z sketches-service WARN Mismatching sketch file <GetKey.ino> and sketch folder name <EspTuya>. Skipping
2024-10-21T01:33:17.053Z sketches-service WARN Mismatching sketch file <Commandes.ino> and sketch folder name <EspTuya>. Skipping
2024-10-21T01:33:17.053Z sketches-service WARN Mismatching sketch file <Functions.ino> and sketch folder name <EspTuya>. Skipping
2024-10-21T01:33:17.053Z sketches-service WARN Mismatching sketch file <I2C.ino> and sketch folder name <src>. Skipping
2024-10-21T01:33:17.053Z sketches-service WARN Mismatching sketch file <Misc.ino> and sketch folder name <src>. Skipping
2024-10-21T01:33:17.053Z sketches-service WARN Mismatching sketch file <_C001.ino> and sketch folder name <src>. Skipping
2024-10-21T01:33:17.053Z sketches-service WARN Mismatching sketch file <_C002.ino> and sketch folder name <src>. Skipping
2024-10-21T01:33:17.053Z sketches-service WARN Mismatching sketch file <_C003.ino> and sketch folder name <src>. Skipping
2024-10-21T01:33:17.053Z sketches-service WARN Mismatching sketch file <_C004.ino> and sketch folder name <src>. Skipping
2024-10-21T01:33:17.053Z sketches-service WARN Mismatching sketch file <_C005.ino> and sketch folder name <src>. Skipping
2024-10-21T01:33:17.053Z sketches-service WARN Mismatching sketch file <_C006.ino> and sketch folder name <src>. Skipping
2024-10-21T01:33:17.053Z sketches-service WARN Mismatching sketch file <_C007.ino> and sketch folder name <src>. Skipping
2024-10-21T01:33:17.053Z sketches-service WARN Mismatching sketch file <_C008.ino> and sketch folder name <src>. Skipping
2024-10-21T01:33:17.054Z sketches-service WARN Mismatching sketch file <_C009.ino> and sketch folder name <src>. Skipping
2024-10-21T01:33:17.054Z sketches-service WARN Mismatching sketch file <_C010.ino> and sketch folder name <src>. Skipping
2024-10-21T01:33:17.054Z sketches-service WARN Mismatching sketch file <_C011.ino> and sketch folder name <src>. Skipping
2024-10-21T01:33:17.054Z sketches-service WARN Mismatching sketch file <_C012.ino> and sketch folder name <src>. Skipping
2024-10-21T01:33:17.054Z sketches-service WARN Mismatching sketch file <_C013.ino> and sketch folder name <src>. Skipping
2024-10-21T01:33:17.054Z sketches-service WARN Mismatching sketch file <_C014.ino> and sketch folder name <src>. Skipping
2024-10-21T01:33:17.054Z sketches-service WARN Mismatching sketch file <_C015.ino> and sketch folder name <src>. Skipping
2024-10-21T01:33:17.054Z sketches-service WARN Mismatching sketch file <_C016.ino> and sketch folder name <src>. Skipping
2024-10-21T01:33:32.112Z daemon INFO time="2024-10-20T22:33:32-03:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2024-10-20T22:33:32-03:00" level=info msg="Loaded platform" platform="esp32:esp32@3.0.4"
2024-10-21T01:33:32.112Z daemon INFO time="2024-10-20T22:33:32-03:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\john\\AppData\\Local\\Arduino15\\packages\\esp32\\tools"
time="2024-10-20T22:33:32-03:00" level=info msg="Loading tools from dir: C:\\Users\\john\\AppData\\Local\\Arduino15\\packages\\esp32\\tools"
2024-10-21T01:33:32.114Z daemon INFO time="2024-10-20T22:33:32-03:00" level=info msg="Loaded tool" tool="esp32:esp-rv32@2302"
2024-10-21T01:33:32.114Z daemon INFO time="2024-10-20T22:33:32-03:00" level=info msg="Loaded tool" tool="esp32:esp-x32@2302"
2024-10-21T01:33:32.115Z daemon INFO time="2024-10-20T22:33:32-03:00" level=info msg="Loaded tool" tool="esp32:esp-xs2@2302"
2024-10-21T01:33:32.115Z daemon INFO time="2024-10-20T22:33:32-03:00" level=info msg="Loaded tool" tool="esp32:esp-xs3@2302"
2024-10-21T01:33:32.118Z daemon INFO time="2024-10-20T22:33:32-03:00" level=info msg="Loaded tool" tool="esp32:esp32-arduino-libs@idf-release_v5.1-b6b4727c58"
2024-10-21T01:33:32.119Z daemon INFO time="2024-10-20T22:33:32-03:00" level=info msg="Loaded tool" tool="esp32:esptool_py@4.2.1"
2024-10-21T01:33:32.119Z daemon INFO time="2024-10-20T22:33:32-03:00" level=info msg="Loaded tool" tool="esp32:esptool_py@4.6"
2024-10-21T01:33:32.151Z daemon INFO time="2024-10-20T22:33:32-03:00" level=info msg="Loaded tool" tool="esp32:mklittlefs@3.0.0-gnu12-dc7f933"
2024-10-21T01:33:32.152Z daemon INFO time="2024-10-20T22:33:32-03:00" level=info msg="Loaded tool" tool="esp32:mkspiffs@0.2.3"
2024-10-21T01:33:32.152Z daemon INFO time="2024-10-20T22:33:32-03:00" level=info msg="Loaded tool" tool="esp32:openocd-esp32@v0.12.0-esp32-20240318"
2024-10-21T01:33:32.153Z daemon INFO time="2024-10-20T22:33:32-03:00" level=info msg="Loaded tool" tool="esp32:riscv32-esp-elf-gcc@gcc8_4_0-esp-2021r2-patch3"
2024-10-21T01:33:32.154Z daemon INFO time="2024-10-20T22:33:32-03:00" level=info msg="Loaded tool" tool="esp32:riscv32-esp-elf-gdb@12.1_20231023"
2024-10-21T01:33:32.154Z daemon INFO time="2024-10-20T22:33:32-03:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp-elf-gdb@12.1_20231023"
2024-10-21T01:33:32.158Z daemon INFO time="2024-10-20T22:33:32-03:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp32-elf-gcc@gcc8_4_0-esp-2021r2-patch3"
2024-10-21T01:33:32.163Z daemon INFO time="2024-10-20T22:33:32-03:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp32s2-elf-gcc@gcc8_4_0-esp-2021r2-patch3"
2024-10-21T01:33:32.165Z daemon INFO time="2024-10-20T22:33:32-03:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp32s3-elf-gcc@gcc8_4_0-esp-2021r2-patch3"
2024-10-21T01:33:32.166Z daemon INFO time="2024-10-20T22:33:32-03:00" level=info msg="Loading package esp8266 from: C:\\Users\\john\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware"
2024-10-21T01:33:32.417Z daemon INFO time="2024-10-20T22:33:32-03:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2024-10-20T22:33:32-03:00" level=info msg="Loaded platform" platform="esp8266:esp8266@3.1.2"
2024-10-21T01:33:32.417Z daemon INFO time="2024-10-20T22:33:32-03:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\john\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools"
time="2024-10-20T22:33:32-03:00" level=info msg="Loading tools from dir: C:\\Users\\john\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools"
2024-10-21T01:33:32.483Z daemon INFO time="2024-10-20T22:33:32-03:00" level=info msg="Loaded tool" tool="esp8266:mklittlefs@3.1.0-gcc10.3-e5f9fec"
2024-10-21T01:33:32.483Z daemon INFO time="2024-10-20T22:33:32-03:00" level=info msg="Loaded tool" tool="esp8266:mkspiffs@3.1.0-gcc10.3-e5f9fec"
2024-10-21T01:33:32.490Z daemon INFO time="2024-10-20T22:33:32-03:00" level=info msg="Loaded tool" tool="esp8266:python3@3.7.2-post1"
2024-10-21T01:33:32.502Z daemon INFO time="2024-10-20T22:33:32-03:00" level=info msg="Loaded tool" tool="esp8266:xtensa-lx106-elf-gcc@3.1.0-gcc10.3-e5f9fec"
[9788:1020/223337.525:ERROR:raster_implementation.cc(320)] Failed to serialize op in 16777152 bytes.
[9788:1020/223338.693:ERROR:raster_implementation.cc(320)] Failed to serialize op in 16777152 bytes.
2024-10-21T01:33:49.305Z daemon INFO time="2024-10-20T22:33:48-03:00" level=info msg="sending command" command=CLOSE monitor=serial-monitor
2024-10-21T01:33:49.306Z daemon INFO time="2024-10-20T22:33:49-03:00" level=info msg="received message" error=false event_type=close message=OK monitor=serial-monitor
2024-10-21T01:33:49.306Z daemon INFO time="2024-10-20T22:33:49-03:00" level=info msg="sending command" command=QUIT monitor=serial-monitor
time="2024-10-20T22:33:49-03:00" level=info msg="received message" error=false event_type=quit message=OK monitor=serial-monitor
2024-10-21T01:33:49.306Z daemon INFO time="2024-10-20T22:33:49-03:00" level=info msg="Killing monitor process" monitor=serial-monitor
2024-10-21T01:33:49.306Z daemon INFO time="2024-10-20T22:33:49-03:00" level=error msg="Sent kill signal" error="TerminateProcess: Access is denied." monitor=serial-monitor
2024-10-21T01:33:49.307Z daemon INFO time="2024-10-20T22:33:49-03:00" level=error msg="stopped decode loop: EOF" monitor=serial-monitor
2024-10-21T01:33:49.308Z daemon INFO time="2024-10-20T22:33:49-03:00" level=info msg="Monitor process killed" monitor=serial-monitor
2024-10-21T01:33:49.310Z monitor-service INFO monitor to COM8 using serial closed by server
2024-10-21T01:33:49.312Z discovery-log INFO {"eventType":"remove","port":{"matchingBoardsList":[],"port":{"address":"COM8","label":"COM8","protocol":"serial","protocolLabel":"Serial Port (USB)","propertiesMap":[],"hardwareId":""}},"error":""}
2024-10-21T01:33:49.338Z daemon INFO time="2024-10-20T22:33:49-03:00" level=info msg="Discovery event channel closed builtin:serial-discovery. Exiting goroutine."
2024-10-21T01:33:49.354Z daemon INFO time="2024-10-20T22:33:49-03:00" level=error msg="Waiting discovery process termination: exit status 1" discovery="builtin:serial-discovery"
time="2024-10-20T22:33:49-03:00" level=info msg="Closed and removed discovery builtin:serial-discovery"
2024-10-21T01:33:49.355Z daemon INFO time="2024-10-20T22:33:49-03:00" level=info msg="Discovery event channel closed builtin:mdns-discovery. Exiting goroutine."
2024-10-21T01:33:49.362Z daemon INFO time="2024-10-20T22:33:49-03:00" level=error msg="Waiting discovery process termination: exit status 1" discovery="builtin:mdns-discovery"
time="2024-10-20T22:33:49-03:00" level=info msg="Closed and removed discovery builtin:mdns-discovery"
2024-10-21T01:33:49.616Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"COM8","label":"COM8","protocol":"serial","protocolLabel":"Serial Port (USB)","propertiesMap":[["pid","0x7523"],["serialNumber",""],["vid","0x1A86"]],"hardwareId":""}},"error":""}
2024-10-21T01:33:50.297Z daemon INFO time="2024-10-20T22:33:50-03:00" level=info msg="Adding libraries dir" dir="C:\\Users\\john\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.4\\libraries" isSingleLibrary=false location=platform
2024-10-21T01:33:50.303Z daemon INFO time="2024-10-20T22:33:50-03:00" level=info msg="Adding libraries dir" dir="C:\\Users\\john\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries" isSingleLibrary=false location=platform
2024-10-21T01:33:50.310Z daemon INFO time="2024-10-20T22:33:50-03:00" level=info msg="Adding libraries dir" dir="C:\\Users\\john\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries" isSingleLibrary=false location=platform
2024-10-21T01:33:50.311Z daemon INFO time="2024-10-20T22:33:50-03:00" level=info msg="Loading libraries index file" index="C:\\Users\\john\\AppData\\Local\\Arduino15\\library_index.json"
2024-10-21T01:33:52.069Z daemon INFO time="2024-10-20T22:33:52-03:00" level=info msg="Adding libraries dir" dir="C:\\Users\\john\\AppData\\Local\\Arduino15\\libraries" isSingleLibrary=false location=ide
2024-10-21T01:33:52.070Z daemon INFO time="2024-10-20T22:33:52-03:00" level=info msg="Adding libraries dir" dir="C:\\Users\\john\\Documents\\Arduino\\libraries" isSingleLibrary=false location=user
Error sending from webFrameMain:  Error: Render frame was disposed before WebFrameMain could be accessed
    at WebFrameMain.send (node:electron/js2c/browser_init:2:93682)
    at WebContents.send (node:electron/js2c/browser_init:2:79161)
    at e.sendWindowEvent (C:\Program Files\Arduino IDE\resources\app\lib\backend\electron-main.js:2:1188040)
    at BrowserWindow.<anonymous> (C:\Program Files\Arduino IDE\resources\app\lib\backend\electron-main.js:2:1194279)
    at BrowserWindow.emit (node:events:526:35)
2024-10-21T01:34:31.509Z root ERROR [hosted-plugin: 6576] Promise rejection not handled in one second: Error: Connection got disposed. , reason: Error: Connection got disposed.
2024-10-21T01:34:31.509Z root ERROR [hosted-plugin: 6576] With stack trace: Error: Connection got disposed.
    at Object.dispose (C:\Program Files\Arduino IDE\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\jsonMain.js:1:71722)
    at Object.dispose (C:\Program Files\Arduino IDE\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\jsonMain.js:1:54996)
    at C:\Program Files\Arduino IDE\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\jsonMain.js:1:51610
I see some msgs expressing delay >Not sure if related,but my pc is slow....
BTW, could not paste the whole file sinceit was too long . It is 1364 lines.....
Hi @zenonmb.
Unfortunately the logs you provided don't give me any clues about what is causing the problem. I would like to look at the whole thing in case the parts you removed might contain that clue.
In cases where text is longer than the forum software will allow to be added to a post, you can instead save it to a .txt file and then attach that file to a reply here.
  1. Open any text editor program.
  2. Paste the copied output into the text editor.
  3. Save the file in .txt format.
  4. Open a forum reply here by clicking the "Reply" button.
  5. Click the "Upload" icon (Upload icon) on the post composer toolbar:
    The "Open" dialog will open.
  6. Select the .txt file you saved from the "Open" dialog.
  7. Click the "Open" button.
    The dialog will close.
  8. Click the "Reply" button to publish the post.
Alternatively, instead of using the "Upload" icon on the post composer toolbar as described in steps (5) - (7) above, you can simply drag and drop the .txt file onto the post composer field to attach it.
Sorry it took too long.here is
error arduino.txt (188,6 KB)
the file
