Hello !
I've a problem to display something on my tft screen.
The screen is : url to the product screen
I test the code with the arduino Uno and no problem. It works.
But when I want to run the code with my Nano, I've a white screen and I don't understand why.
I do on my NANO :
3.3v => 3.3v
SCK => D13
SDA MOSI => D11
A0 => D9
RESET => D8
CS => D10
GND => GND
VCC => 5V
I've you got any idea ? I think I don't do the right connection pin with my nano and when I initialize the TFT with the CS / DC and reset pin it fails. But I don't know how to do the right connection.
Yeah TFT is just to check that everything is fine.
Thank you for your reply ! But I have a connection to you. I am a software developer BUT in electronics I am not really good and I cannot find a good example for nano! The Uno that I have but with the nano impossible to find a good tutorial. If you've got this ... because everything I've been doing for the past few days is failing. Ah ah. Pity.
There is nothing different between a Nano and a Uno.
The pins are marked 0-13 and A0-A5 on a Uno
The pins are marked D0-D13 and A0-A7 on a Nano
The current Nano Bootloader gives the same amount of Flash memory as the Uno.
The Old Nano Bootloader gave smaller Flash memory.
Hi ! Thanks for your answer.
Yeah TFT lib was just to check that all is ok. Agree with you for Adafruit_ST7735.h library.
But sorry I'm a software developer and the electronic seems not really easy for me. Do you have a great tutorial with breadboard schema for the uno and this type of screen ? Because all I found since few days fails.
I don't know why with the arduino Uno all is ok and not the nano but your answer help me. But if you have a great tutorial which explain where to connect the resistor ect it will be amazing !
Make sure that they have "level shifter" of some description. i.e. with components that you already own.
Most people have some resistors. You should feel happy with the French / English Tutorial.
Ask if you want help. say what resistors you have available i.e what values.
It seems that you are using a sketch for a LCD. The ST7735 is a TFT display!
TFT.h is a library for ST7735 TFT. Hint. Look at the name.
TFT stands for Thin-film-transistor liquid-crystal display
Having said that. TFT.h is a completely crap TFT library that is packaged with the Arduino IDE.
I strongly advise you to use Adafruit_ST7735.h or similar third party library.
