BLDC ESC without all of the RC nonsense
I have a project where I want to use an ESC (cost, etc) but want to use a 12 volt power supply to drive the circuit. However, I don't want all of the arming, battery attach nonsense that comes with an esc. Do such controllers exist? Or do I need to build my own?
Currently I'm using a 360 watt, 12 volt power supply with a HobbyKing 40A sbec esc, and a uno with servo libraries.
Thanks,
Ben
I think the firmware for the ESCs (at least some of them) is open-source.
So you can modify as needed and re-flash an ESC.
https://oscarliang.com/esc-firmware-protocols/
Yes, I've seen the blue hole people say there's is open source. I've also checked out the 'kiss' stuff but they say that there Regen braking can damage a power supply.
So don't put regen braking into the ESC code when you modify it. Simple.
Yes, if I go to that level of effort I will leave that out.
