BLDC Motor Control
I have a BLDC motor which is coupled to the linear actuator through gears. The feedback from the linear actuator displacement sensor is between 0 and 3.3 volts, I understand I can connect it to the ADC port to close the loop. My question is related to which power electronics IC I would require to connect with aurduino to drive the BLDC motor.
Thanks,
Aero.
Get a data sheet for your motor, and find the operating voltage and maximum current drawn. These are the parameters for the driver module choice.
