BLE 33 Sense isn't finding port
I have tried this in both Windows and Mint and so far can't get my nano BLE 33 Sense to find a port. When I open the IDE all I get is a grayed (greyed?) out option with ports and no way of selecting or changing a port.
The IDE says at the bottom of the frame "Arduino Nano 33 BLE on COM1" but as mentioned, the option is not available under tools.
How do I get a port?
If not mistaken, your board uses a microUSB connector. If so, microUSB cables come in two flavours, charge-only cables and data cables. Use a data cable (e.g. the one that you use to download pictures from yur phone).
I am using a cable off of my digitial camera - complete with a choke.
Original post was for installation and then I saw this -
The IDE will say that regardless of whether a board is connected.
Check your USB cable. Shorter is usually better and make sure it is not just a power cable without data lines.
You should hear a connect sound in Windows when you connect your Arduino to your PC.
Check your Windows Device Manager. You should see a COM port with Arduino Nano 33 BLE ... . When you check the driver it should say Arduino SA.
You should be able to switch between normal (single click on Reset button) and bootloader mode (double click) and see two different COM ports. And you should hear Windows connect sounds.
Are your LEDs active (green power), orange blinking when in bootloader mode?
The Arduino Nano 33 IOT and BLE use native USB. The USB stack is handled by the same processor that your sketch runs on. It is handled in the background, but that means your sketch can break the USB stack. In that case switch to bootloader mode and program a new sketch.
Just to be through I checked under each possible item in Device Manager and didn't see anything showing a com port for Arduino.
LEDs are going from red to green. One flickers to green very quickly, the other is fairly rythmic.
@im_back
Your two topics on the same or similar subject have been merged.
Please do not duplicate your questions as doing so wastes the time and effort of the volunteers trying to help you as they are then answering the same thing in different places.
Please create one topic only for your question and choose the forum category carefully. If you have multiple questions about the same project then please ask your questions in the one topic as the answers to one question provide useful context for the others, and also you won’t have to keep explaining your project repeatedly.
Repeated duplicate posting could result in a temporary or permanent ban from the forum.
Could you take a few moments to Learn How To Use The Forum
Thank you.
