BLE and TFLite micro simultaneously
Is it possible to run both BLE and TinyML inference inside the loop() function? If so will I have to set a flag for when I need to switch to bluetooth. The pseudo code for what i propose is,
loop() {
    if ble is enabled
        do BLE Functionalities
        run ML inference
    end if
Yes. I would also investigate the interrupt service routines available through the NRF52840 on the Nano 33 BLE (& SENSE). You can find more information here:
UPDATE: After working through interrupts on an Arduino Nano 33 BLE a bit, I have found some of the IRQ Handlers disabled. This is due to Arduino's mbed's implementation blocking weak link access to them. If attempting to call a weak IRQHandler causes a compiling error on your board, look into the pal_bb.h file in the mbed os library to access some IRQHandlers directly instead through callbacks.
Here are all the available IRQs:
/* -------------------------  Interrupt Number Definition  ------------------------ */
typedef enum {
/* -------------------  Cortex-M4 Processor Exceptions Numbers  ------------------- */
  Reset_IRQn                    = -15,              /*!<   1  Reset Vector, invoked on Power up and warm reset                 */
  NonMaskableInt_IRQn           = -14,              /*!<   2  Non maskable Interrupt, cannot be stopped or preempted           */
  HardFault_IRQn                = -13,              /*!<   3  Hard Fault, all classes of Fault                                 */
  MemoryManagement_IRQn         = -12,              /*!<   4  Memory Management, MPU mismatch, including Access Violation
                                                         and No Match                                                          */
  BusFault_IRQn                 = -11,              /*!<   5  Bus Fault, Pre-Fetch-, Memory Access Fault, other address/memory
                                                         related Fault                                                         */
  UsageFault_IRQn               = -10,              /*!<   6  Usage Fault, i.e. Undef Instruction, Illegal State Transition    */
  SVCall_IRQn                   =  -5,              /*!<  11  System Service Call via SVC instruction                          */
  DebugMonitor_IRQn             =  -4,              /*!<  12  Debug Monitor                                                    */
  PendSV_IRQn                   =  -2,              /*!<  14  Pendable request for system service                              */
  SysTick_IRQn                  =  -1,              /*!<  15  System Tick Timer                                                */
/* ---------------------  nrf52840 Specific Interrupt Numbers  -------------------- */
  POWER_CLOCK_IRQn              =   0,              /*!<   0  POWER_CLOCK                                                      */
  RADIO_IRQn                    =   1,              /*!<   1  RADIO                                                            */
  UARTE0_UART0_IRQn             =   2,              /*!<   2  UARTE0_UART0                                                     */
  SPIM0_SPIS0_TWIM0_TWIS0_SPI0_TWI0_IRQn=   3,      /*!<   3  SPIM0_SPIS0_TWIM0_TWIS0_SPI0_TWI0                                */
  SPIM1_SPIS1_TWIM1_TWIS1_SPI1_TWI1_IRQn=   4,      /*!<   4  SPIM1_SPIS1_TWIM1_TWIS1_SPI1_TWI1                                */
  NFCT_IRQn                     =   5,              /*!<   5  NFCT                                                             */
  GPIOTE_IRQn                   =   6,              /*!<   6  GPIOTE                                                           */
  SAADC_IRQn                    =   7,              /*!<   7  SAADC                                                            */
  TIMER0_IRQn                   =   8,              /*!<   8  TIMER0                                                           */
  TIMER1_IRQn                   =   9,              /*!<   9  TIMER1                                                           */
  TIMER2_IRQn                   =  10,              /*!<  10  TIMER2                                                           */
  RTC0_IRQn                     =  11,              /*!<  11  RTC0                                                             */
  TEMP_IRQn                     =  12,              /*!<  12  TEMP                                                             */
  RNG_IRQn                      =  13,              /*!<  13  RNG                                                              */
  ECB_IRQn                      =  14,              /*!<  14  ECB                                                              */
  CCM_AAR_IRQn                  =  15,              /*!<  15  CCM_AAR                                                          */
  WDT_IRQn                      =  16,              /*!<  16  WDT                                                              */
  RTC1_IRQn                     =  17,              /*!<  17  RTC1                                                             */
  QDEC_IRQn                     =  18,              /*!<  18  QDEC                                                             */
  COMP_LPCOMP_IRQn              =  19,              /*!<  19  COMP_LPCOMP                                                      */
  SWI0_EGU0_IRQn                =  20,              /*!<  20  SWI0_EGU0                                                        */
  SWI1_EGU1_IRQn                =  21,              /*!<  21  SWI1_EGU1                                                        */
  SWI2_EGU2_IRQn                =  22,              /*!<  22  SWI2_EGU2                                                        */
  SWI3_EGU3_IRQn                =  23,              /*!<  23  SWI3_EGU3                                                        */
  SWI4_EGU4_IRQn                =  24,              /*!<  24  SWI4_EGU4                                                        */
  SWI5_EGU5_IRQn                =  25,              /*!<  25  SWI5_EGU5                                                        */
  TIMER3_IRQn                   =  26,              /*!<  26  TIMER3                                                           */
  TIMER4_IRQn                   =  27,              /*!<  27  TIMER4                                                           */
  PWM0_IRQn                     =  28,              /*!<  28  PWM0                                                             */
  PDM_IRQn                      =  29,              /*!<  29  PDM                                                              */
  MWU_IRQn                      =  32,              /*!<  32  MWU                                                              */
  PWM1_IRQn                     =  33,              /*!<  33  PWM1                                                             */
  PWM2_IRQn                     =  34,              /*!<  34  PWM2                                                             */
  SPIM2_SPIS2_SPI2_IRQn         =  35,              /*!<  35  SPIM2_SPIS2_SPI2                                                 */
  RTC2_IRQn                     =  36,              /*!<  36  RTC2                                                             */
  I2S_IRQn                      =  37,              /*!<  37  I2S                                                              */
  FPU_IRQn                      =  38,              /*!<  38  FPU                                                              */
  USBD_IRQn                     =  39,              /*!<  39  USBD                                                             */
  UARTE1_IRQn                   =  40,              /*!<  40  UARTE1                                                           */
  QSPI_IRQn                     =  41,              /*!<  41  QSPI                                                             */
  CRYPTOCELL_IRQn               =  42,              /*!<  42  CRYPTOCELL                                                       */
  PWM3_IRQn                     =  45,              /*!<  45  PWM3                                                             */
  SPIM3_IRQn                    =  47               /*!<  47  SPIM3                                                            */
} IRQn_Type;
This is an example of an IRQ Handler for the SWI3 in the EGU (Event Generator Unit):
void SWI3_EGU3_IRQHandler(void)
    // Clear SWI Event.
    if (NRF_EGU3->EVENTS_TRIGGERED[0] == 1)
        NRF_EGU3->EVENTS_TRIGGERED[0] = 0;
Also be sure to enable interrupts and set their priority. This is done via the NVIC.
NVIC_SetPriority(IRQ_NUMBER,PRIORITY (Out of 8 options - default is 6));
NVIC_EnableIRQ(IRQ_NUMBER);
