Hello,
I would like to have on one side (i) an Arduino Nano BLE Sense connected to some sensors (temperature, PPG...) , and on the other side (ii) a Wio Terminal to display the datas. That is to say that the Arduino Nano is the peripheral/server and that the Wio Terminal is the client/central. For now I am only using the integrated accelerometer and thermometer, I have managed to make possible the sending and display. However, I need to improve some points:
the range is very short, less than 1m. It is better than for the communication between 2 Arduino Nano BLE Sense. I have found some discussion about it. BLE very weak signal I checked and it looks like no component are missing on the antenna part.
My final goal is to use the 2 without connecting to computer, however the BLE doesn't seem to work if I just plug the device to sector (like with a phone chargor). Any idea how to fix that?
I have posted here regarding the Wio Terminal program to optimize the connexion process but I haven't get any answer so far...
Modification of the BLEClient program of WioTerminal to communicate with an Arduino Nano BLE - #2 by asalice - Wio Terminal - Seeed Forum
I am also wondering if using callback function is really a plus.
I would be very grateful if anyone had some advice about any of these 3 points .
Here are my codes:
* Device: Arduino Nano 33 BLE Sense
* Peripheral
* The values of the integrated temperature sensor and
* accelerometer are sent using BLE.
#include <ArduinoBLE.h>
#include <Arduino_LSM9DS1.h> //accelerometer sensor
#include <Arduino_HTS221.h> // temperature sensor
int const d_a=1; //number of decimal to keep for the accelerometer
int const d_t=0; //number of decimal to keep for the temperature
int const d_m=2*d_a; //number of decimal to keep for the temperature
//float values read by the sensor
float xSensor=0;
float ySensor=0;
float zSensor=0;
float mSensor=0;
float tSensor=37;
//integer variables to send via BLE
int xBLE=xSensor*pow(10,d_a);
int yBLE=ySensor*pow(10,d_a);
int zBLE=zSensor*pow(10,d_a);
int mBLE=mSensor*pow(10,d_m);
int tBLE=tSensor*pow(10,d_t);
//int t_i=t_f*100;
//int x_i=x_f*100;
//int y_i=y_f*100;
//int z_i=z_f*100;
BLEService SensorService("1101");
//BLEService SensorService("FEE0");
BLEUnsignedIntCharacteristic XChar("2101", BLERead | BLENotify);
BLEUnsignedIntCharacteristic YChar("2102", BLERead | BLENotify);
BLEUnsignedIntCharacteristic ZChar("2103", BLERead | BLENotify);
BLEUnsignedIntCharacteristic TChar("2104", BLERead | BLENotify);
BLEUnsignedIntCharacteristic MChar("2105", BLERead | BLENotify);
//BLEUnsignedIntCharacteristic TChar("2A2B", BLERead | BLENotify);
IMU.begin();
HTS.begin();
while (!Serial);
// if (!HTS.begin()){
// Serial.println("Failed to start the HTS221 sensor.");
// while(1);
// if (!IMU.begin()) {
// Serial.println("Failed to start the LSM9DS sensor.");
// while (1);
pinMode(LED_BUILTIN, OUTPUT);
if (!BLE.begin()) {
Serial.println("BLE failed to Initiate");
//delay(500);
while (1);
BLE.setLocalName("Arduino XYZT (peripheral)");
BLE.setAdvertisedService(SensorService);
SensorService.addCharacteristic(XChar);
SensorService.addCharacteristic(YChar);
SensorService.addCharacteristic(ZChar);
SensorService.addCharacteristic(MChar);
SensorService.addCharacteristic(TChar);
BLE.addService(SensorService);
XChar.writeValue(xBLE);
YChar.writeValue(yBLE);
ZChar.writeValue(zBLE);
MChar.writeValue(mBLE);
TChar.writeValue(tBLE);
BLE.advertise();
Serial.println("Arduino XYZT peripheral device is now active, waiting for connections...");
BLEDevice central = BLE.central();
if (central) {
Serial.print("Connected to central: ");
Serial.print("* Device MAC address: ");
Serial.println(central.address());
Serial.println(" ");
digitalWrite(LED_BUILTIN, HIGH);
while (central.connected()) {
//delay(200);
//read_sensor();
if (IMU.accelerationAvailable()) {
IMU.readAcceleration(xSensor, ySensor, zSensor);
mSensor=xSensor*xSensor+ySensor*ySensor+zSensor*zSensor;
tSensor=HTS.readTemperature();
Serial.print("xSensor ");
Serial.print(xSensor);
Serial.print(" - ySensor ");
Serial.print(ySensor);
Serial.print(" - zSensor ");
Serial.print(zSensor);
Serial.print(" - mSensor ");
Serial.print(mSensor);
Serial.print(" - tSensor ");
Serial.println(tSensor);
Serial.println("");
mBLE=zSensor*pow(10,d_m);
//int t_i=t_f*100;
//int x_i=x_f*100;
//int y_i=y_f*100;
//int z_i=z_f*100;
//writeCharacteristicValue (Tchar, Xchar, Ychar, Zchar);
Serial.print("xBLE ");
Serial.print(xBLE);
Serial.print(" - yBLE ");
Serial.print(yBLE);
Serial.print(" - zBLE ");
Serial.print(zBLE);
Serial.print(" - mBLE ");
Serial.print(mBLE);
Serial.print(" - tBLE ");
Serial.println(tBLE);
Serial.println("");
//Serial.println("At Main Function");
Serial.print("XChar ");
Serial.print(XChar.value());
Serial.print(" - YChar ");
Serial.print(YChar.value());
Serial.print(" - ZChar ");
Serial.print(ZChar);
Serial.print(" - MChar ");
Serial.print(MChar);
Serial.print(" - TChar ");
Serial.println(TChar.value());
Serial.println("");
Serial.println("");
//Serial.println("");
delay(100);
else {
delay(100);
digitalWrite(LED_BUILTIN, LOW);
Serial.print("Disconnected from central: ");
BLE.advertise();
//void read_sensor(){
//if (IMU.accelerationAvailable()) {
//IMU.readAcceleration(x_f, y_f, z_f);
//t_f=HTS.readTemperature();
//Serial.print("x_f ");
//Serial.print(x_f);
//Serial.print(" - y_f ");
//Serial.print(y_f);
//Serial.print(" - z_f ");
//Serial.print(z_f);
//Serial.print(" - t_f ");
//Serial.println(t_f);
////x_i=x_f*pow(10,d);
////y_i=y_f*pow(10,d);
////z_i=z_f*pow(10,d);
////t_i=t_f*pow(10,d);
//int t_i=t_f;
//int x_i=x_f;
//int y_i=y_f;
//int z_i=z_f;
//Serial.print("x_i ");
//Serial.print(x_i);
//Serial.print(" - y_i ");
//Serial.print(y_i);
//Serial.print(" - z_i ");
//Serial.print(z_i);
//Serial.print(" - t_i ");
//Serial.println(t_i);
Wio Terminal
* A BLE client example that is rich in capabilities.
* There is a lot new capabilities implemented.
* author unknown
* updated by chegewara
#include "rpcBLEDevice.h"
#include <BLEScan.h>
#include <BLEAdvertisedDevice.h>
#include"TFT_eSPI.h"
TFT_eSPI tft;
// The remote service we wish to connect to.
//static BLEUUID serviceUUID(0xFEE0);
static BLEUUID serviceUUID(0x1101);
// The characteristic of the remote service we are interested in.
//static BLEUUID charUUID(0x2A2B);
static BLEUUID XcharUUID(0x2101);
static BLEUUID YcharUUID(0x2102);
static BLEUUID ZcharUUID(0x2103);
static BLEUUID TcharUUID(0x2104);
static BLEUUID McharUUID(0x2105);
static boolean doConnect = false;
static boolean connected = false;
static boolean doScan = false;
//static BLERemoteCharacteristic* pRemoteCharacteristic;
static BLERemoteCharacteristic* pTChar;
static BLERemoteCharacteristic* pXChar;
static BLERemoteCharacteristic* pYChar;
static BLERemoteCharacteristic* pZChar;
static BLERemoteCharacteristic* pMChar;
static BLEAdvertisedDevice* myDevice;
uint8_t bd_addr[6] = {0xD3, 0xE3, 0xAE, 0xC0, 0xB9, 0x38};
//uint8_t bd_addr[6] = {0x7d, 0x18, 0x1b, 0xf1, 0xf7, 0x2c}; // MAC address: 2c:f7:f1:1b:18:7d
BLEAddress BattServer(bd_addr);
float tmp_T(0),deltaTmp_T(0);
static void temperatureNotifyCallback(
BLERemoteCharacteristic* pTChar,
uint8_t* pTData,
size_t length,
bool isNotify) {
Serial.print("Notify callback for temperature characteristic ");
Serial.print(pTChar->getUUID().toString().c_str());
Serial.print(" of data length ");
Serial.println(length);
Serial.print("data: ");
Serial.println(*(uint8_t *)pTData);
Serial.println(*pTData);
Serial.println(pTData[0]);
tft.fillRect(0, 40, 100, 30, TFT_WHITE);
tft.drawString(String(*pTData), 0, 40);
deltaTmp_T=millis()-tmp_T;
Serial.print("deltaTmp_T:");
Serial.print(deltaTmp_T);
Serial.println("ms");
tmp_T=millis();
//Serial.println(pData);
static void accelerationModuleNotifyCallback(
BLERemoteCharacteristic* pMChar,
uint8_t* pMData,
size_t length,
bool isNotify) {
Serial.print("Notify callback for acceleration for module characteristic ");
Serial.print(pMChar->getUUID().toString().c_str());
Serial.println(*(uint8_t *)pMData);
Serial.println(*pMData);
Serial.println(pMData[0]);
//fillRect(int32_t x, int32_t y, int32_t w, int32_t h, uint32_t color);
tft.fillRect(0, 110, 100, 30, TFT_WHITE);
tft.drawString(String(*pMData), 0, 110);
class MyClientCallback : public BLEClientCallbacks {
void onConnect(BLEClient* pclient) {
void onDisconnect(BLEClient* pclient) {
connected = false;
Serial.println("onDisconnect");
bool connectToServer() {
Serial.print("Forming a connection to ");
Serial.println(myDevice->getAddress().toString().c_str());
BLEClient* pClient = BLEDevice::createClient();
Serial.println(" - Created client");
pClient->setClientCallbacks(new MyClientCallback());
// Connect to the remove BLE Server.
pClient->connect(myDevice); // if you pass BLEAdvertisedDevice instead of address, it will be recognized type of peer device address (public or private)
Serial.println(" - Connected to server");
// Obtain a reference to the service we are after in the remote BLE server.
BLERemoteService* pRemoteService = pClient->getService(serviceUUID);
Serial.println(serviceUUID.toString().c_str());
if (pRemoteService == nullptr) {
Serial.print("Failed to find our service UUID: ");
pClient->disconnect();
return false;
Serial.println(" - Found our service");
// Obtain a reference to the characteristic in the service of the remote BLE server.
//pRemoteCharacteristic = pRemoteService->getCharacteristic(charUUID);
pTChar = pRemoteService->getCharacteristic(TcharUUID);
pXChar = pRemoteService->getCharacteristic(XcharUUID);
pYChar = pRemoteService->getCharacteristic(YcharUUID);
pZChar = pRemoteService->getCharacteristic(ZcharUUID);
pMChar = pRemoteService->getCharacteristic(McharUUID);
if (pTChar == nullptr || pMChar == nullptr) {
Serial.print("Failed to find our characteristic UUID ");
// Serial.println(TcharUUID.toString().c_str());
// Serial.println(XcharUUID.toString().c_str());
// Serial.println(YcharUUID.toString().c_str());
// Serial.println(ZcharUUID.toString().c_str());
return false;
Serial.println(" - Found our characteristic");
// Read the temperature characteristic value
if(pTChar->canRead()) {
Serial.println(" - can read start");
std::string value = pTChar->readValue();
Serial.print("The characteristic value was: ");
Serial.println(value.c_str());
if(pTChar->canNotify())
pTChar->registerForNotify(temperatureNotifyCallback);
// Read the X characteristic value
if(pXChar->canRead()) {
std::string value = pXChar->readValue();
if(pXChar->canNotify())
pXChar->registerForNotify(notifyCallback);
// Read the Y characteristic value
if(pYChar->canRead()) {
std::string value = pYChar->readValue();
if(pYChar->canNotify())
pYChar->registerForNotify(notifyCallback);
// Read the Z characteristic value
if(pZChar->canRead()) {
std::string value = pZChar->readValue();
if(pZChar->canNotify())
pZChar->registerForNotify(notifyCallback);
// Read the acceleration module characteristic value
if(pMChar->canRead()) {
std::string value = pMChar->readValue();
Serial.print("The acceleration characteristic value was: ");
if(pMChar->canNotify())
pMChar->registerForNotify(accelerationModuleNotifyCallback);
connected = true;
return true;
* Scan for BLE servers and find the first one that advertises the service we are looking for.
* Also in BLEscan example but with a shorter onresult
class MyAdvertisedDeviceCallbacks: public BLEAdvertisedDeviceCallbacks { // crée une classe MyAdvertisedDeviceCallbacks qui hérite de la classe BLEAdvertisedDeviceCallbacks
* Called for each advertising BLE server.
void onResult(BLEAdvertisedDevice advertisedDevice) {
Serial.print("BLE Advertised Device found: ");
Serial.println(advertisedDevice.toString().c_str());
// We have found a device, let us now see if it contains the service we are looking for.
//int memcmp ( const void * ptr1, const void * ptr2, size_t num );
//: Compares the first num bytes of the block of memory pointed by ptr1 to the first num bytes pointed by ptr2,
//returning zero if they all match or a value different from zero representing which is greater if they do not.
if (memcmp(advertisedDevice.getAddress().getNative(),BattServer.getNative(), 6) == 0) {
Serial.print("BATT Device found: ");
BLEDevice::getScan()->stop();
Serial.println("new BLEAdvertisedDevice");
myDevice = new BLEAdvertisedDevice(advertisedDevice);
Serial.println("new BLEAdvertisedDevice done");
doConnect = true;
doScan = true;
} // onResult
}; // MyAdvertisedDeviceCallbacks
//initialisation of the screen
tft.begin();
tft.setRotation(3);//
tft.fillScreen(TFT_WHITE);
tft.setTextSize(2); //sets the size of text
tft.setTextColor(TFT_BLACK); //sets the text colour to black
tft.drawString("Temperature", 0, 10);
tft.drawString("Acceleration Module", 0, 80);
//initialisation of the serial connection
while(!Serial){};
//delay(2000);
Serial.println("Starting Arduino BLE Client application...");
BLEDevice::init("");
// Retrieve a Scanner and set the callback we want to use to be informed when we
// have detected a new device. Specify that we want active scanning and start the
// scan to run for 5 seconds.
BLEScan* pBLEScan = BLEDevice::getScan(); // get scanner from our client device
pBLEScan->setAdvertisedDeviceCallbacks(new MyAdvertisedDeviceCallbacks()); // behaviour of the scanner each time it find another bluetooth device
//setAdvertisedDeviceCallbacks, setInterval, setWindow, setActiveScan methods from the librairy BLEscan
pBLEScan->setInterval(1349); // period between 2 active scans
pBLEScan->setWindow(449); // active scan time range
pBLEScan->setActiveScan(true);//beginning of the scan
pBLEScan->start(5, false);
} // End of setup.
// This is the Arduino main loop function.
// If the flag "doConnect" is true then we have scanned for and found the desired
// BLE Server with which we wish to connect. Now we connect to it. Once we are
// connected we set the connected flag to be true.
if (doConnect == true) {//static boolean initialized as false
if (connectToServer()) {
Serial.println("We are now connected to the BLE Server.");
Serial.println("We have failed to connect to the server; there is nothin more we will do.");
doConnect = false;
//display time information
//Serial.println(".");
//delay(1000);
} // End of loop
