BLE doesn't work / won't start
Hi y'all,
I bought an Arduino nano 33 IoT a few days ago and started experimenting with it's BLE functionalities. This worked for a while and I managed to test a few programs like powering a led via my phone. However, when I tried it this morning I got an error message 'starting BLE failed'. I wonder why this happens, as it has worked for me the last couple of days. I figure it has something to do with this part of the code:
if (!BLE.begin()) {
Serial.println("starting BLE failed!");
while (1);
I have included an example code (LED control via bluetooth device) and hope some of you can help.
  LED
  This example creates a BLE peripheral with service that contains a
  characteristic to control an LED.
  The circuit:
  - Arduino MKR WiFi 1010, Arduino Uno WiFi Rev2 board, Arduino Nano 33 IoT,
    Arduino Nano 33 BLE, or Arduino Nano 33 BLE Sense board.
  You can use a generic BLE central app, like LightBlue (iOS and Android) or
  nRF Connect (Android), to interact with the services and characteristics
  created in this sketch.
  This example code is in the public domain.
#include <ArduinoBLE.h>
BLEService ledService("19B10000-E8F2-537E-4F6C-D104768A1214"); // BLE LED Service
// BLE LED Switch Characteristic - custom 128-bit UUID, read and writable by central
BLEByteCharacteristic switchCharacteristic("19B10001-E8F2-537E-4F6C-D104768A1214", BLERead | BLEWrite);
const int ledPin = LED_BUILTIN; // pin to use for the LED
  while (!Serial);
  // set LED pin to output mode
  pinMode(ledPin, OUTPUT);
  // begin initialization
  if (!BLE.begin()) {
    while (1);
  // set advertised local name and service UUID:
  BLE.setLocalName("LED");
  BLE.setAdvertisedService(ledService);
  // add the characteristic to the service
  ledService.addCharacteristic(switchCharacteristic);
  // add service
  BLE.addService(ledService);
  // set the initial value for the characeristic:
  switchCharacteristic.writeValue(0);
  // start advertising
  BLE.advertise();
  Serial.println("BLE LED Peripheral");
  // listen for BLE peripherals to connect:
  BLEDevice central = BLE.central();
  // if a central is connected to peripheral:
  if (central) {
    Serial.print("Connected to central: ");
    // print the central's MAC address:
    Serial.println(central.address());
    // while the central is still connected to peripheral:
    while (central.connected()) {
      // if the remote device wrote to the characteristic,
      // use the value to control the LED:
      if (switchCharacteristic.written()) {
        if (switchCharacteristic.value()) {   // any value other than 0
          Serial.println("LED on");
          digitalWrite(ledPin, HIGH);         // will turn the LED on
        } else {                              // a 0 value
          Serial.println(F("LED off"));
          digitalWrite(ledPin, LOW);          // will turn the LED off
    // when the central disconnects, print it out:
    Serial.print(F("Disconnected from central: "));
Did you use an appropriate current-limiting resistor with the LED (7 mA maximum current draw)?
If not, the Nano may have been damaged. Remove all extra components and start over again with the most basic, unmodified BLE example.
