BLE -> MQTT gateway LilyGo T-SIM7000G
I am trying to setup a BLE to MQTT gateway that uses a cellular modem. The code will scan for BLE devices, and will publish them via MQTT. But, if there is a problem with publishing one of the messages, the watchdog timer reboots the device.
If I add a small delay between MQTT messages (50ms), then the unit will no longer reboot. BUT, it seems to hang during the BLE scan.
 #define TINY_GSM_MODEM_SIM7000
// Set serial for debug console (to the Serial Monitor, default speed 115200)
#define SerialMon Serial
// Set serial for AT commands (to the module)
// Use Hardware Serial on Mega, Leonardo, Micro
#define SerialAT Serial1
// See all AT commands, if wanted
//#define DUMP_AT_COMMANDS
// Define the serial console for debug prints, if needed
#define TINY_GSM_DEBUG SerialMon
// set GSM PIN, if any
#define GSM_PIN ""
// Your GPRS credentials, if any
const char apn[]      = "iot.1nce.net";
const char gprsUser[] = "";
const char gprsPass[] = "";
// MQTT details
const char *broker = "mqtt.lstxsa.com";
const char *topicGps       = "g1/869951035779390/gps";
const char *topicInit      = "g1/869951035779390/init";
const char *topicBle = "g1/869951035779390/ble";
#include <TinyGsmClient.h>
#include <PubSubClient.h>
#include <Ticker.h>
#include <SPI.h>
#include <BLEDevice.h>
#include <BLEUtils.h>
#include <BLEScan.h>
#include <BLEAdvertisedDevice.h>
int scanTime = 5; //In seconds
BLEScan* pBLEScan;
#define BAT_ADC     35
#define SOLAR_ADC   36
#define uS_TO_S_FACTOR 1000000ULL  // Conversion factor for micro seconds to seconds
#define TIME_TO_SLEEP  60          // Time ESP32 will go to sleep (in seconds)
#define UART_BAUD   115200
#define PIN_DTR     25
#define PIN_TX      27
#define PIN_RX      26
#define PWR_PIN     4
#define LED_PIN     12
#ifdef DUMP_AT_COMMANDS
#include <StreamDebugger.h>
StreamDebugger debugger(SerialAT, SerialMon);
TinyGsm        modem(debugger);
#else
TinyGsm        modem(SerialAT);
#endif
TinyGsmClient client(modem);
PubSubClient  mqtt(client);
class MyAdvertisedDeviceCallbacks: public BLEAdvertisedDeviceCallbacks {
    void onResult(BLEAdvertisedDevice advertisedDevice) {
      String UUID = advertisedDevice.toString().c_str();
      int RSSI = abs(advertisedDevice.getRSSI());
      String beacon = String(UUID + " RSSI: " + RSSI);
      Serial.println(beacon);
      mqtt.publish(topicBle, beacon.c_str());
      //delay(100);
void getBattery(){
  int vref = 1100;
  uint16_t volt = analogRead(35);
  float battery_voltage = ((float)volt / 4095.0) * 2.0 * 3.3 * (vref);
  Serial.printf("battery : %f\n", battery_voltage);
  char tempString[10];
  dtostrf(battery_voltage, 8, 2, tempString);
  mqtt.publish(topicInit, tempString);
  delay(100);
boolean mqttConnect()
    SerialMon.print("Connecting to ");
    SerialMon.print(broker);
    boolean status = mqtt.connect("GsmClientName", "lst", "lst2021");
    if (status == false) {
        SerialMon.println(" failed to connect to MQTT broker");
        return false;
    SerialMon.println(" successfully connected to MQTT broker");
    //mqtt.publish(topicInit, "GsmClientTest started");
    return mqtt.connected();
  Serial.println("Scanning...");
  BLEDevice::init("");
  pBLEScan = BLEDevice::getScan(); //create new scan
  pBLEScan->setAdvertisedDeviceCallbacks(new MyAdvertisedDeviceCallbacks());
  pBLEScan->setActiveScan(true); //active scan uses more power, but get results faster
  pBLEScan->setInterval(100);
  pBLEScan->setWindow(99);  // less or equal setInterval value
  pinMode(PWR_PIN, OUTPUT);
  digitalWrite(PWR_PIN, HIGH);
  delay(300);
  digitalWrite(PWR_PIN, LOW);
  SerialAT.begin(UART_BAUD, SERIAL_8N1, PIN_RX, PIN_TX);
    // Restart takes quite some time
    // To skip it, call init() instead of restart()
  Serial.println("Initializing modem...");
  if (!modem.restart()) {
      Serial.println("Failed to restart modem, attempting to continue without restarting");
  String name = modem.getModemName();
  DBG("Modem Name:", name);
  String modemInfo = modem.getModemInfo();
  DBG("Modem Info:", modemInfo);
  // Unlock your SIM card with a PIN if needed
  if (GSM_PIN && modem.getSimStatus() != 3) {
      modem.simUnlock(GSM_PIN);
  SerialMon.print(F("Connecting to "));
  SerialMon.print(apn);
  if (!modem.gprsConnect(apn, gprsUser, gprsPass)) {
      SerialMon.println(" fail");
      delay(10000);
      return;
  SerialMon.println(" success");
  if (modem.isGprsConnected()) {
      SerialMon.println("GPRS connected");
  mqtt.setServer(broker, 1883);
  mqttConnect();
  BLEScanResults foundDevices = pBLEScan->start(scanTime, false);
  Serial.print("Devices found: ");
  Serial.println(foundDevices.getCount());
  Serial.println("Scan done!");
  pBLEScan->clearResults();   // delete results fromBLEScan buffer to release memory
  getBattery();
  mqtt.publish(topicInit, "Scan Complete, sleeping for 10 sec");
  delay(10000);
