Hello, I am trying to send a random number over BLE from my Arduino Nano 33 IOT to an ESP32. Previously, I have used two Nano IOT's to send sensor data over BLE and had no problems whatsoever. I am using the same code to send data on my IOT and I am using the BLE_client example for the ESP32. I have tried modifying the BLE_client example and have tried hacking together other examples, but so far no luck.
I have inserted my send code and my receive code. I have also attached a screenshot of serial monitor when I use this code. I should be receiving a random number between 1 and 100, but it looks like I'm getting ascii characters. I've tried converting this to integers but when I do that, I get all 0's. Is this ascii problem my only problem? Does anyone have an example of for ESP32 receiving data? I haven't found any good examples yet. Any help is appreciated. Thank you.
//Send from IOT to ESP32
#include <ArduinoBLE.h>
#include <Arduino_LSM6DS3.h>
BLEService IMUservice("1101");
BLEUnsignedCharCharacteristic pitchChar("2101", BLERead | BLENotify);
BLEUnsignedCharCharacteristic rollChar("3101", BLERead | BLENotify);
pinMode(LED_BUILTIN, OUTPUT);
if (!BLE.begin())
while (1);
BLE.setLocalName("IMU");
BLE.setAdvertisedService(IMUservice);
IMUservice.addCharacteristic(pitchChar);
IMUservice.addCharacteristic(rollChar);
BLE.addService(IMUservice);
BLE.advertise();
BLEDevice central = BLE.central();
if (central)
digitalWrite(LED_BUILTIN, HIGH);
while (central.connected()) {
// //pitch+=1;
// //roll-=1;
int Pitch=random(99);
int Roll=random(99);
pitchChar.writeValue(Pitch);
Serial.print(Pitch);
rollChar.writeValue(Roll);
Serial.print(Roll);
delay(1);
digitalWrite(LED_BUILTIN, LOW);
* A BLE client example that is rich in capabilities.
* There is a lot new capabilities implemented.
* author unknown
* updated by chegewara
#include "BLEDevice.h"
//#include "BLEScan.h"
// The remote service we wish to connect to.
static BLEUUID serviceUUID("4fafc201-1fb5-459e-8fcc-c5c9c331914b");
// The characteristic of the remote service we are interested in.
static BLEUUID charUUID("beb5483e-36e1-4688-b7f5-ea07361b26a8");
static boolean doConnect = false;
static boolean connected = false;
static boolean doScan = false;
static BLERemoteCharacteristic* pRemoteCharacteristic;
static BLEAdvertisedDevice* myDevice;
static void notifyCallback(
BLERemoteCharacteristic* pBLERemoteCharacteristic,
uint8_t* pData,
size_t length,
bool isNotify) {
Serial.print("Notify callback for characteristic ");
Serial.print(pBLERemoteCharacteristic->getUUID().toString().c_str());
Serial.print(" of data length ");
Serial.println(length);
Serial.print("data: ");
Serial.println((char*)pData);
class MyClientCallback : public BLEClientCallbacks {
void onConnect(BLEClient* pclient) {
void onDisconnect(BLEClient* pclient) {
connected = false;
Serial.println("onDisconnect");
bool connectToServer() {
Serial.print("Forming a connection to ");
Serial.println(myDevice->getAddress().toString().c_str());
BLEClient* pClient = BLEDevice::createClient();
Serial.println(" - Created client");
pClient->setClientCallbacks(new MyClientCallback());
// Connect to the remove BLE Server.
pClient->connect(myDevice); // if you pass BLEAdvertisedDevice instead of address, it will be recognized type of peer device address (public or private)
Serial.println(" - Connected to server");
// Obtain a reference to the service we are after in the remote BLE server.
BLERemoteService* pRemoteService = pClient->getService(serviceUUID);
if (pRemoteService == nullptr) {
Serial.print("Failed to find our service UUID: ");
Serial.println(serviceUUID.toString().c_str());
pClient->disconnect();
return false;
Serial.println(" - Found our service");
// Obtain a reference to the characteristic in the service of the remote BLE server.
pRemoteCharacteristic = pRemoteService->getCharacteristic(charUUID);
if (pRemoteCharacteristic == nullptr) {
Serial.print("Failed to find our characteristic UUID: ");
Serial.println(charUUID.toString().c_str());
return false;
Serial.println(" - Found our characteristic");
// Read the value of the characteristic.
if(pRemoteCharacteristic->canRead()) {
std::string value = pRemoteCharacteristic->readValue();
Serial.print("The characteristic value was: ");
Serial.println(value.c_str());
if(pRemoteCharacteristic->canNotify())
pRemoteCharacteristic->registerForNotify(notifyCallback);
connected = true;
return true;
* Scan for BLE servers and find the first one that advertises the service we are looking for.
class MyAdvertisedDeviceCallbacks: public BLEAdvertisedDeviceCallbacks {
* Called for each advertising BLE server.
void onResult(BLEAdvertisedDevice advertisedDevice) {
Serial.print("BLE Advertised Device found: ");
Serial.println(advertisedDevice.toString().c_str());
// We have found a device, let us now see if it contains the service we are looking for.
if (advertisedDevice.haveServiceUUID() && advertisedDevice.isAdvertisingService(serviceUUID)) {
BLEDevice::getScan()->stop();
myDevice = new BLEAdvertisedDevice(advertisedDevice);
doConnect = true;
doScan = true;
} // Found our server
} // onResult
}; // MyAdvertisedDeviceCallbacks
Serial.println("Starting Arduino BLE Client application...");
BLEDevice::init("");
// Retrieve a Scanner and set the callback we want to use to be informed when we
// have detected a new device. Specify that we want active scanning and start the
// scan to run for 5 seconds.
BLEScan* pBLEScan = BLEDevice::getScan();
pBLEScan->setAdvertisedDeviceCallbacks(new MyAdvertisedDeviceCallbacks());
pBLEScan->setInterval(1349);
pBLEScan->setWindow(449);
pBLEScan->setActiveScan(true);
pBLEScan->start(5, false);
} // End of setup.
// This is the Arduino main loop function.
// If the flag "doConnect" is true then we have scanned for and found the desired
// BLE Server with which we wish to connect. Now we connect to it. Once we are
// connected we set the connected flag to be true.
if (doConnect == true) {
if (connectToServer()) {
Serial.println("We are now connected to the BLE Server.");
Serial.println("We have failed to connect to the server; there is nothin more we will do.");
doConnect = false;
// If we are connected to a peer BLE Server, update the characteristic each time we are reached
// with the current time since boot.
if (connected) {
String newValue = "Time since boot: " + String(millis()/1000);
Serial.println("Setting new characteristic value to \"" + newValue + "\"");
// Set the characteristic's value to be the array of bytes that is actually a string.
pRemoteCharacteristic->writeValue(newValue.c_str(), newValue.length());
}else if(doScan){
BLEDevice::getScan()->start(0); // this is just eample to start scan after disconnect, most likely there is better way to do it in arduino
delay(1000); // Delay a second between loops.
} // End of loop
