BLE SENSE REV 2 with SeeedStudio MAX3185K
I am trying to upload this Example code in my Nano BLE Sense Rev 2 and the moment i upload this code it gives me an error that Connected USB Malfunctioned but it works fine for other codes.
Also if i upload the same code to UNO it works perfectly fine
#include <OneWire.h>
#include <DallasTemperature.h>
// Data wire is plugged into port 3 on the Arduino
// Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs)
OneWire oneWire(D3);
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
void setup(void) {
    sensors.begin();
void loop(void) {
    // request to all devices on the bus
    Serial.print("Requesting temperatures...");
    sensors.requestTemperatures(); // Send the command to get temperatures
    Serial.println("DONE");
    Serial.print("Temperature for the device 1 (index 0) is: ");
    Serial.println(sensors.getTempCByIndex(0));
Welcome to the forum.
That does not mean anything. The Arduino UNO and the Arduino Nano 33 BLE have completely different hardware (32-bit ARM-Cortex-M) and software architectures (mbedOS).
You will need to do some test and debugging to see whether the library can work with this device.
I have a DALLAS sensor running with a Nano 33 IoT. It is also based on an ARM Cortex-M not the same as the Nano 33 BLE but does not use mbedOS, supports BLE and WiFi.
