I am receiving "ACK CMD SPI interface Error! END" with my Nano 33 BLE Sense V2 and the ArduCAM Mini 2 MP Plus. On-line searches have not turned up any solutions perhaps since this is a new combination of parts. Any help appreciated.
I stripped the example “ArduCAM_Mini_2MP_Plus_functions.ino” down to the essentials where the error is occurring (see code below). I only added the SPI.beginTransaction line since some on-line discussions and documentation was concerned about over-clocking the OV2640 controller since its max speed is 8 MHz. (This additional line does not change behavior.) Per instructions I modified memorysaver.h to only have #define OV2640_MINI_2MP_PLUS. The failure is a simple readback of 0x55 from the DDR. Numbers are coming back alternating between 67 and 85 (decimal) fairly consistently; these numbers change when SPI.beginTransaction parameters change. This appears to be an interface configuration problem of some sort. I have dug through the ArduCAM header and source files but haven’t found anything to help.
The protoboard has only the Nano 33 BLE Sense V2 and the ArduCAM Mini 2 MP Plus. There is no other hardware. Power is through the USB. The wiring is as follows:
The example code has been modified with CS on pin D10 (and I have confirmed it’s being controlled).
#include <Wire.h>
#include <ArduCAM.h>
#include <SPI.h>
#include "memorysaver.h"
const int CS = 10; // pin D7 in example; CS now D10
ArduCAM myCAM( OV2640, CS );
uint8_t read_fifo_burst(ArduCAM myCAM);
uint8_t temp;
Wire.begin();
Serial.begin(921600);
while (!Serial); // added this
Serial.println(F("ACK CMD ArduCAM Start! END"));
// set the CS as an output:
pinMode(CS, OUTPUT);
digitalWrite(CS, HIGH);
SPI.begin(); // required before SPI.beginTransaction()
SPI.beginTransaction(SPISettings(8000000, MSBFIRST, SPI_MODE0)); // added code
//Reset the CPLD
myCAM.write_reg(0x07, 0x80);
delay(100);
myCAM.write_reg(0x07, 0x00);
delay(100);
while(1){
//Check if the ArduCAM SPI bus is OK
myCAM.write_reg(ARDUCHIP_TEST1, 0x55);
temp = myCAM.read_reg(ARDUCHIP_TEST1);
if (temp != 0x55){
Serial.print(F("ACK CMD SPI interface Error! END "));
Serial.println(temp); // added this to see readback numbers
delay(2000);continue;
}else{
Serial.println(F("ACK CMD SPI interface OK. END"));break;
Serial.println(F("Entered infinite loop!"));
while(1);
