BLE UUID HELP programming arduino
Hello Everyone, I need help on connecting my sender and receiver BLE UUID. my microprocessor im using is Seeed NRF8240:
Sender code:
#include <ArduinoBLE.h>
#include "fix_fft.h"
#include <Wire.h>
#include "MAX30105.h"
#include "heartRate.h"
// Common BLE UUID
const char* bleUuid = "19B10000-E8F2-537E-4F6C-D104768A1215";
// EEG Variables
#define adc_input A0
const unsigned long eeg_sample_freq = 1024; // Hz (Max freq = 512Hz)
const short n = 64; // number of data points (must be power of 2)
const unsigned long eeg_sample_period = 1000000 / eeg_sample_freq; // uS
const short m = (short(log10(n) / log10(2))); // equivalent to m=log2(n) from which 2^m=n
char data[n]; // real values
char im[n]; // imaginary values
short dc_offset;
short dc_counter = 5;
bool eeg_data_valid = false;
short stressDetectedEEG = 0;  // Variable to store EEG stress detection
// Oximeter Variables
MAX30105 particleSensor;
const byte RATE_SIZE = 4;
byte rates[RATE_SIZE];
byte rateSpot = 0;
long lastBeat = 0;
float beatsPerMinute;
int beatAvg;
long irValue;
short stressDetectedOXY = 0;  // Variable to store Oximeter stress detection
// BLE Characteristic
BLECharacteristic combinedChar(bleUuid, BLERead | BLEWrite, 2);
// Timers and mode switch
unsigned long Timer1, Timer2;
unsigned long modeSwitchTimer = 0;
bool isEEGMode = true;
    // Initialize sensors
    pinMode(adc_input, INPUT);
    if (!particleSensor.begin(Wire, I2C_SPEED_FAST)) {
        Serial.println("MAX30105 was not found. Please check wiring/power.");
        while (1);
    particleSensor.setup();
    particleSensor.setPulseAmplitudeRed(0x0A);
    particleSensor.setPulseAmplitudeGreen(0);
    // BLE Initialization
    if (!BLE.begin()) {
        Serial.println("Starting BLE failed!");
        while (1);
    // Create a BLE service
    BLEService combinedService("19B10000-E8F2-537E-4F6C-D104768A1215"); // Use a unique UUID
    // Add the characteristic to the service
    combinedService.addCharacteristic(combinedChar);
    BLE.setLocalName("XIAO12");
    BLE.setAdvertisedServiceUuid(bleUuid);
    BLE.advertise();
    // Start timers
    Timer1 = micros() + eeg_sample_period;
    Timer2 = micros() + 1000000L;
    modeSwitchTimer = millis();
    BLEDevice central = BLE.central();
    if (central.connected()) {
        static bool firstCycleCompleted = false;
        if (millis() - modeSwitchTimer > 30000) {
            isEEGMode = !isEEGMode;
            if (!isEEGMode) {
                if (firstCycleCompleted) {
                    uint8_t finalStress = stressDetectedEEG && stressDetectedOXY;
                    uint8_t payload[2] = {finalStress, (uint8_t)min(255, beatAvg)};
                    combinedChar.writeValue(payload, sizeof(payload));
                    firstCycleCompleted = true;
        if (isEEGMode) {
            processEEGData();
            processOximeterData();
        Serial.println("Waiting for a connection...");
void processEEGData() {
  static short i = 0; // Sample counter
  static int eegThresholdViolations = 0; // Counts the number of threshold violations
  static bool firstRun = true; // Indicates if this is the first run
  // Reset the violation counter at the beginning of each EEG mode cycle
  if (firstRun) {
    firstRun = false;
  // Loop control
  while (micros() < Timer1); // Wheel-spin until next sample due
  Timer1 += eeg_sample_period; // Reset loop timer
  if (i < n) {
    // Acquire the data
    short value = analogRead(adc_input);
    data[i] = map(value, 0, 1023, 0, 255);
    im[i] = 0;
    i++;
    // Display data once per second
    if (micros() > Timer2) {
      Timer2 += 1000000L;
      // Process data
      fix_fft(data, im, m, 0);
      // Calculate amplitudes
      for (short j = 0; j < n / 2; j++) {
        data[j] = (sqrt(data[j] * data[j] + im[j] * im[j]));
      // Capture dc offset
      if (!eeg_data_valid && (dc_counter > 0)) {
        dc_counter--;
        if (dc_counter < 1) {
          eeg_data_valid = true;
          dc_offset = data[0];
      // Display the data
      if (eeg_data_valid) {
        // Remove dc offset
        data[0] -= dc_offset;
        // Send bin 1 to the Serial Plotter
        Serial.println((short)data[1]);
        // Stress detection logic
        if (data[1] >= 200) {
          eegThresholdViolations++;
    if (i == n - 1) { // Check if this is the last sample in the cycle
      if (eegThresholdViolations >= 2) { // If the value has gone over 200 two times within the cycle
        Serial.println("Stressed in Beta band");
        stressDetectedEEG = 1;
      firstRun = true; // Reset for the next EEG cycle
      eegThresholdViolations = 0; // Reset the count for the next cycle
    // Prepare for next sample
    i = 0; // Reset data acquisition
    Timer1 = micros() + eeg_sample_period; // Reset loop timer
void processOximeterData() {
    irValue = particleSensor.getIR();
    if (checkForBeat(irValue) == true) {
      long delta = millis() - lastBeat;
      lastBeat = millis();
      beatsPerMinute = 60 / (delta / 1000.0);
      if (beatsPerMinute < 255 && beatsPerMinute > 20) {
        rates[rateSpot++] = (byte)beatsPerMinute;
        rateSpot %= RATE_SIZE;
        beatAvg = 0;
        for (byte x = 0; x < RATE_SIZE; x++)
          beatAvg += rates[x];
        beatAvg /= RATE_SIZE;
    Serial.print("IR=");
    Serial.print(irValue);
    Serial.print(", BPM=");
    Serial.print(beatsPerMinute);
    Serial.print(", Avg BPM=");
    Serial.println(beatAvg);
    if (beatAvg > 60){
      stressDetectedOXY = 1;
Receiver code:
    delay(3000);
    Serial.println("Starting BLE setup...");
    if (!BLE.begin()) {
        while (1);
    Serial.println("BLE initialized");
    // Set receiver as central (unchanged)
    BLE.setLocalName("ReceiverDevice");
    Serial.println("Local name set");
    // Add the local name to scan for (unchanged)
    BLE.scanForName("XIAO12");
    Serial.println("Scanning for device named XIAO12");
    Serial.println("Bluetooth device active, waiting for connections...");
    // Check for BLE devices (unchanged)
    BLEDevice peripheral = BLE.available();
    if (peripheral) {
        // Check if the peripheral has the service we're interested in (unchanged)
        if (peripheral.hasService("19B10000-E8F2-537E-4F6C-D104768A1215")) {
            Serial.print("Found peripheral with desired service: ");
            Serial.println(peripheral.address());
            // Connect to the peripheral (unchanged)
            if (peripheral.connect()) {
                Serial.println("Connected to peripheral");
                // Discover the service (unchanged)
                if (peripheral.discoverService("19B10000-E8F2-537E-4F6C-D104768A1215")) {
                    // Retrieve the characteristic (unchanged)
                    BLECharacteristic charac = peripheral.characteristic("19b10001-e8f2-537e-4f6c-d104768a1215");
                    // Read data if the characteristic is valid (unchanged)
                    if (charac) {
                        uint8_t data[2]; // Buffer to store the read data
                        while (peripheral.connected()) {
                            if (charac.valueUpdated()) {
                                charac.readValue(data, sizeof(data));
                                uint8_t stress = data[0];
                                uint8_t avgBPM = data[1];
                                Serial.print("Stress: ");
                                Serial.println(stress ? "Yes" : "No");
                                Serial.print("Avg BPM: ");
                                Serial.println(avgBPM);
                        Serial.println("Peripheral disconnected");
Hello, do yourself a favour and please read How to get the best out of this forum and modify your post accordingly (including code tags and necessary documentation for your ask).
